    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Sony G70 (LC) Tube Swap
 (Page 9)
Page:
1 2 3 4 5 6 7 8 9 10
27. Now, carefully slide-in the complete assembly within the G70 unit, with one hand on LC housing and the other on the tube neck end. Check that every wire/connector is NOT stressed during this operation. Ensure that the HV lead comes in the right conduit. Then reconnect the C block to the tube neck. Ensure that the pins are well inserted within the C block tube’s socket by looking through the C block front grid holes. Then secure the neck screw:
28. Re-connect all of the tubes relevant coils wires/connectors. Do not forget to re-connect the HV lead end to the HV block:
29. Screw back in place all of the tube’s LC housing top screws (two long black screws and two short gold screws):
30. Screw back in place the top tube rotation screw with the chassis ground lead:
31. Slide the bottom rotation tube axis left and down:
32. Open your G70 service manual in section 3 (adjustments) and redo section 1.3.1 to 1.3.11 adjustments for the relevant (new) tube(s). This will takes around four hours to do all these necessary adjustments.
Also use a thick rubber glove to manipulate the coils during section 3 of the Service manual adjustments since there is around 150V on the DY/sub-DY coils.
That’s all for the tube replacement procedure. The next page describes the C block PCB update in case you wish to use Panasonic P16LJE07 or P16LJE06 tubes instead of the original Sony provided P16LJE08 tubes.
Previous Page ...
Next Page ...
