    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Sony G70 (LC) Tube Swap
 (Page 4)
Page:
1 2 3 4 5 6 7 8 9 10
6. Transfer the glycol in the syringe into a CLEAN and DRY glass. Be very careful to not spill any glycol as it is very corrosive to just about everything  (including human skin!):
7. Repeat this glycol removal step three times removing approximately 50-60ml each time such that the quantity removed is approximately150-200ml. At each step, gently tilt the tube to let air bubbles enter the tank in the C-element chamber (which then re-fills the tank with glycol). At the end (and after replacing the glycol chamber screw!) the C-element looks like this:
8. After checking that the glycol chamber screw is correctly back in place, unscrew the four metal bracket screws 2 turn at a time alternating in diagonal/crossing order:
9. Do this until you can remove the metal bracket from the tube. Be careful to NOT move the glass tube itself from the LC housing:
Previous Page ...
Next Page ...
