Curt Palme CRT Projectors
Sign up and receive the latest newsletters by email!     Join the CRT Forum discussions!
    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee LC Tube Replacement
 (Page 1)
Page:
1 2 3 4 5 6
For definitions of c-element, liquid coupling (LC), or air coupling (AC),  see this page.
This procedure was written by Pjackso on Jan 27, 2008. Thanks Paul!
The following document describes the necessary steps to replace a Liquid Coupled (LC) CRT tube from an Electrohome Marquee. It shows the basics, which will present a decent introduction for a novice. Hopefully, the pictures and tips will help make your job a little bit easier, or at least give you an idea of what to expect.
1. Remove the tube assembly from the projector:
1.a The steps for tube assembly removal are excellently described in Tim’s website E-Tech. See www.etechvideo.com. Refer to Tim’s website for tube assembly removal. http://www.etechvideo.com/techtip8.htm
1.b I used a plastic cap to help protect the C-element and keep dirt from getting inside. It’s from a Maxwell House coffee can. Not required, but quite handy.
1.c Following Tim’s removal instructions, you should have the tube assembly removed from the projector. (Picture 1.c.)
Picture 1.c.
2. Removing the top plastic cover:
2.a Remove the two (2) small access-plates (labeled “1” and “2” in Picture 2.a) on the top of the plastic cover. (Picture 2.a)
Picture 2.a.
2.b Use a Philips screwdriver to remove the six (6) Philips screws from the upper cover.
2.c Remove the upper cover. (See Picture 2.c)
Picture 2.c.
2.d Remove the two (2) large Philips screws from the bottom cover (Located in the aluminum housing.) and the two small screws in the bottom of the neck board basket.
2.e. Remove the neck board basket and lower plastic cover. (Picture 2.e)
Picture 2.e.
3. Removing the tube electronics: (Picture 3)
Picture 3.
3.a The Flare Yoke. Loosen clamp, twist to break the set-glue, and remove off the back of the tube with a firm left/right twisting motion. Using some tape and a pen - mark the yoke to indicate which tube it came from (R, G, B).
Note: The yokes on all three tubes are identical, but some of the plugs connectors are color identified (RGB) and the wires already have the appropriate ‘bends’ in the wire routing. So I recommend you keep the yokes with the appropriate tubes.
3.b The Focus Yoke. Loosen clamp, twist to break the set-glue, and remove off the back of the tube with a firm left/right twisting motion. (Picture 3.b) Using some tape and a pen - mark the yoke to indicate which tube it came from (R, G, B).
Picture 3.b.
3.c The Scan Yoke. Be careful with the scan yoke - it’s easily damaged. E-Tech has additional information on how to safely handle (remove) it: http://www.etechvideo.com/techtip9.htm
3.c.1 I carefully loosed all the set-glue on the scan yoke before trying to remove it. After loosening all the set-glue I loosen the clamp and removed it off the back of the tube with a left/right twisting motion. (Picture 3.c.1) Using some tape and a pen - mark the yoke to indicate which tube it came from (R, G, B).
Picture 3.c.1.
3.d Carefully (and slowly) remove the tube ground strap. (Picture 3.d.1) Once removed, safely store the ground strap in some wax paper for later usage. (Picture 3.d.2)
Picture 3.d.1.
Picture 3.d.2.
Next Page ...
