    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee LC Tube Replacement
 (Page 3)
Page:
1 2 3 4 5 6
5.c Get a large clean container to collect your glycol. (Picture 5.c) I used a clean spaghetti sauce jar (approx 24oz) per tube.
Picture 5.c.
5.d Drain the glycol out of the fill screws into the container. (Picture 5.d) Note: In my picture, my glycol is slightly cloudy due to contamination. Cloudy glycol should be replaced with new glycol. If your glycol is clear, then it can be reused.
Picture 5.d.
5.e Reinstall the upper and lower pivot plates. (Picture 5.e)
Picture 5.e.
6. Removing the (mounting) silicone:
6.a Remove upper left corner screw. (Picture 6.a) This is to help allow the tube to lay flat in the next step.
Picture 6.a.
6.b Lay the tube face-down on your work table. (Picture 6.b)
Picture 6.b.
6.c Get a Dremel hand tool, a 1/8” drill bit, a thin section of metal (like a small metal ruler), and some safety glasses. (Picture 6.c)
Picture 6.c.
6.d Mount the drill bit into the Dremel with 1 ¾” to 2” extending from the Dremel mounting chuck. (Picture 6.d) I preferred the drill bit mounted at 2.0”.
Picture 6.d.
6.e Use the Dremel to drill out the silicone that’s holding the tube in place. (Picture 6.e.1) Occasionally stop and use the thin section of metal to help pry out the larger chunks of silicone. (Picture 6.e.2) This task will get very dirty, very quick, so it’s best done outside.
Picture 6.e.1.
Picture 6.e.2.
6.f Keep working out the silicone until all the silicone is removed completely around the perimeter of the tube. (Picture 6.f) On my third try (third tube), it only took me about 30 minutes to remove all the silicone and remove the tube.
Picture 6.f.
... Previous Page
Next Page ...
