    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee LC Tube Replacement
 (Page 4)
Page:
1 2 3 4 5 6
7 Removal of the tube:
7.a There is a layer of silicone on the tube face that is still mounting the tube in the housing. (Picture 7.a) This layer of silicone is not easily accessible for removal, so instead – we shall use prying force to work the silicone loose and then remove the tube.
Picture 7.a.
7.b For this step we need 1) a metal wedge and 2) a hammer for tapping the wedge in place. I used the nail claw on my hammer as a convenient wedge. (Picture 7.b)
Picture 7.b.
7.c Place the wedge at the corner of the housing assembly and the tube. I strongly recommend you apply the wedge at the corner of the tube/assembly as it’s much stronger at the corner. (Picture 7.c)
Picture 7.c.
7.d Firmly tap the wedge between the tube and housing. Use only moderate tapping force - do not HAMMER the wedge in (we do not want to damage the housing or tube). (Picture 7.d) It may be helpful to occasionally pry the wedge back and forth to help loosen the tube.
Picture 7.d.
7.e You will be finished at each corner when the tube has been forced up to the housing on the opposite corner. (Note: Tube has no clearance left between the tube and housing – opposite the wedge.) (Picture 7.e)
Picture 7.e.
7.f Remove wedge, and repeat at next corner. (Picture 7.f.1) (Picture 7.f.2)
Picture 7.f.1.
Picture 7.f.2.
7.g After wedging both corners, the tube is ready for removal. (Picture 7.g)
Picture 7.g.
8 Cleaning the tube housing from remaining silicone and dirt:
8.a Most likely, during the tube removal process – there was some dirt/silicone that got into the glycol chamber. (Picture 8.a) Don’t worry about it; we will thoroughly clean the remaining silicone later.
Picture 8.a.
8.b For cleaning the remaining silicone, you will need: 1) a 1.5” flexible putty knife, and 2) a clean paint brush (soft bristle). (Picture 8.b)
***DO NOT USE A FLAT SCREWDRIVER!!!!*** If you use a screwdriver, you may easily slip and either gouge the C-element ($$$) or puncture the bellows ($$). A putty knife will be a lot easier to control, and will be less likely for an accident.
Picture 8.b.
... Previous Page
Next Page ...
