    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Electrohome Marquee Series
      >> Introduction
      >> Layout and Setup Tips
      >> Tim Martin Modified LVPS Installation
      >> Manuals / Downloads
 (Page 9)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Horizontal output board
Here is an overview of the HDM or horizontal deflection/output module. This board sits vertically between the blue and green CRTs. It contains the circuitry for the horizontal deflection, and controls the center square raster shift in a horizontal direction. The thick group of wires connect to each deflection yoke for each CRT. The white connectors pull apart to flip the image in an H direction. Make sure you only disconnect the yoke wires after the set has been turned off and unplugged for at least a minute to discharge all high voltages in this area.
There is a small daughter board that fits onto the main HDM. There is a small plastic screw that holds the daughter board in place. Undo the screw, and the daughter board pulls straight out of the multi-pin connectors holding it in place.
It is common for the HDM to develop bad module connections either on the main board or between the daughter board and the main board. This will cause an H fail LED to come on on the back of the unit and usually causes a ‘no picture’ condition. It is also possible for a no picture condition to occur due to a bad connection, but the H fail LED on the back of the set will not come on.
Simply pull out the main HDM and take the daughter board off and reseat it. Slide the HDM back into it’s slot a few times to clean the module contacts.
Other failures on the HDM are usually caused by a high voltage arc somewhere in the set, usually caused by pinhole leaks in the HV leads going to the tubes. There are any number of components that can fail on the HDM, if you get an H fail LED and reseating the modules does not cure the problem, contact us for servicing of this board.
... Previous Page
Next Page ...
