    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Electrohome Marquee Series
      >> Introduction
      >> Layout and Setup Tips
      >> Tim Martin Modified LVPS Installation
      >> Manuals / Downloads
 (Page 13)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
LVPS
The low voltage power supply is a fairly reliable module within the Marquee projectors. It supplies all of the voltages to the various areas of the set. There are a series of red LEDs on the front of the power supply. Under normal operating conditions, these LEDs are always off. It’s normal for them to blink at power-up or down.
The fans on the LVPS will stay spinning at a low speed when the set is plugged in but turned off. This again is normal. My fellow tech at www.etechvideo.com offers a fan modification to quiet these power supplies down if you find them noisy.
Filament voltage check. A number of Marquee 8110 and 8500/9500s were produced with a poor quality part installed in the LVPS that will cause the CRT filament voltage to slowly increase over time, from a nominal 6.3 volts to as high as 7.0 volts or more. This greatly reduces the life of the CRTs, and of course is expensive to repair when tubes need to be replaced. While this problem only affected the productions runs of sometime in late 1995 to sometime in 1998, there’s no saying that an older Marquee 8000 didn’t have a power supply failure in the past, and that a newer defective supply was installed at a later date, so it’s a good idea to check the filament voltage in the sets. Tim’s website shows how to do that here: http://www.etechvideo.com/techtip1.htm
While it might be tempting to simply tweak the filament voltage trimpot (I’m not showing you how to do that for that reason), a bad filament circuit will continue to drift, potentially causing damage down the road. If the filament voltage is too high, pull the LVPS out for modification, it’s a simple and permanent repair. A properly built LVPS will not need the filament voltage adjusted during the life of the projector.
... Previous Page
Next Page ...
