    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Electrohome Marquee Series
      >> Introduction
      >> Layout and Setup Tips
      >> Tim Martin Modified LVPS Installation
      >> Manuals / Downloads
 (Page 10)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
CLM/Microprocessor board
Below is a picture of the CLM or microprocessor board. This is where all of the control functions of the projector take place. The pix below is of a Marquee 8110. There are slight differences between the 8000, 8110 and 8500 control boards, but the functions are the same. The main difference between the 8500/9500/9000 control boards and the other models is that the higher end units have a second daughter board installed for the astigmatism (or ‘Stigmator’ as Electrohome calls it) as outlined in the red rectangle below. Without this board, the astigmatism controls in the service menu become disabled, however the set will still function.
As with the HDM board, the daughter boards can develop bad contacts and cause intermittent operation of some functions or projector power-up. Socketed chips on this board can also get bad contacts. To reseat the chips, simply push down HARD on each chip so that it sits firmly in its socket.
The memory battery on the board can go bad. This is a lithium battery that measures 3 volts. If the battery voltage drops below 2.8 volts, you stand a chance of losing the convergence memory without warning, or the set may have erratic operation.
The rear panel of the CLM shows error LEDs that give a hint as to where the problem in the set lies. Most of these error codes are straightforward, H fail for a bad horizontal board, V fail for a bad vertical board, etc. AS with any other set however, the LEDs are not perfect indicators of all fault conditions in the set, so here’s some other errors that I’ve found with the Marquee sets:
Error lights sequentially flashing back and forth- bad connection on a chip on the CLM board
Multiple LEDs on, indicating possible multiple board failure- caused by a bad VIM (RGB input) board.
No picture, but no error lights on- This can be due to any board being bad in the set. There are a number of circuits that will shut down the HV power supply which will cause no picture, but you may not see an error light on the back of the set. Failure of the HV section in the set will also not be indicated on the CLM board error LEDs.
... Previous Page
Next Page ...
