    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Sony G90 Tube Replacement
 (Page 4)
Page:
1 2 3 4 5 6
23- Now it's time to retrieve the new P19 bare tube close to the bench:
If the new bare tube is missing the Lead X-ray thick belt tape around it, recover it from the older tube.
Before starting the next operation, take care to place it in the correct orientation versus the cleaned aluminium belt/holder so the HV cup entry will be located on the right border of the LC assembly :
24- Now prepare the Silicon Cartridge (from GE for example) with the proper tool:
25- Place the four steel pits pieces back in place inside the relevant four holes :
26- slowly put a CONTINUOUS fresh silicon paste all around the aluminium tube belt/holder piece (better more than less enough!) :
Especially in the corners :
Beware to NOT remove the four steel pits from their location during this Silicon deposit !
27- After checking that silicon deposit is OK all around the tube, place the bare tube within the aluminium tube belt/holder piece and press it so the tube face will be stopped by the four steel pits :
IMPORTANT : Check that the tube is well centered within the aluminium piece and is not rotated versus its borders.
Do not move the assembly and leave it that way in dry place for one day first.
... Previous Page
Next Page ...
