    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee Maintenance & Improvements
(by Mike Parker)
  (Page 9)
Page: 1 2 3 4 5 6 7 8 9 10 11
6. Vertical Deflection Module
Now we'll start on the vertical. This board has three separate vertical amps that drive the yokes, and they are directly controlled by the DAC's (digital to analog converters) on the board. There are 8 resistors I'll recommend for change on this board. Changing the caps on this board did not make any measurable (scope/meter) change or difference on this board. But replacing certain resistors did.
http://www.micro-ohm.com/ You'll want Part# FRN1/4 - 1 ohm 5% tolerance
On the early version boards, you'll see that resistors R720, R721, R820, R821, R920 and R921 are mini one (1) ohm resistors. On the later version boards, there are two of these one ohm resistors in parallel, they are the plus and minus 15 volt supply rails for the vertical output IC's. So that would mean that the early version boards had a one ohm resistor on each of the IC's supply, and the later version boards have one half ohm (1/2 ohm) on each supply rail. In other words the upgrade was a doubling up of these resistors. I only had three problems with the design of these projectors, and the use of these Mickey-mouse resistors is one of them. They're supposed to be fusible metal film resistors at 1/2 watt.
Your choice would be to upgrade by adding the other resistor in parallel to the one in place, that's if you have the early version board, or do as I do on both the early and later version boards - remove all of them and put in real fusible resistors. You'll also want to replace R5 and R6 with the same resistors also.
Solder each lead on the three vertical output IC's, and remember to remove all solder flux (denatured alcohol), flux is good for soldering, but bad for the circuits.
The above greatly improves the vertical boards stability.
While you have this board out, it’s a good time to perform the "Vertical Squeeze Mod". This decreases the vertical size for 16:9 operation. the circuit was probably designed more for computer presentation.
The mod requires the replacement of 3 resistors on the vertical board (R704, R804 and R904). These resistors are 30K ohm, they should be replaced with 56K ohm resistors, and it's best to use metal film resistors @ 1 to 5% tolerance. I use 1% 1/4 watt from Digikey.com, Part# 56.2KXB.
... Previous Page
Next Page ...
