    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee Maintenance & Improvements
(by Mike Parker)
  (Page 5)
Page: 1 2 3 4 5 6 7 8 9 10 11
3. Neck Boards
OK, let's get started on the neck boards.
Here are some board numbers:
50-2000-02p
50-2013-04p
50-2013-05p
We're not going to use the boards’ part numbers for this. So you'll have to visually inspect your boards for the following:
  1. Look for the numbers on IC 'U2' (near the mini RCA jack). On that IC you should see one of the following numbers: 'CLC409, CLC449, H1100.
  2. Check transistors Q12 and Q19, see if they are round metal (TO-5) devices, or small square (SOIC) devices.
  3. Check the opposite end of the card for four soldered on 'blue' capacitors.
  4. Inspect the solder contacts of resistors R13 and R28, for burn at the point of soldering on the PC boards surface.
  5. Inspect coils L8 and L9 for any indication of heat damage.
(1) If IC 'U2' is a CLC409 it should be replaced with IC CLC449. Also if there's a H1100, it could also have a softening effect on the image, because it was later replaced with CLC449 (and some H1100's were also on the later boards 8500, 9500's).
(2) If transistors Q12 and Q19 are metal (TO-5) you have an early version card, and this board would more likely have the CLC409 or H1100 chip.
(3) The 'blue' caps are on the early version boards only, as they were a part of the upgrade for the brightness blanking problem that was also on the early version boards. Don't try this fix yourself, this is the protect circuit, and much care should be taking to prevent tube damage if the procedure is not done properly (that I won't provide). Also, much care must be taking when servicing this area of the board. This board SHOULD NOT be used for random modding, it has special interference tweaks that were necessary for FCC compliance.
(4) If resistors R13 and R28 show burn marks at the solder contacts, replace capacitors C1 and C26. That burn is an indication of high hour use, and C1 and C26 would most likely test leaking. The value is 22mfd @ 100 vdc. You can replace with the same value, but use 105c (high temp) 160 Vdc caps.
(5) Coils L8 and L9 are 100 uh, and would more likely show indication of heat damage if the same is seen on resistors R13 and R28.
... Previous Page
Next Page ...
