    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee Maintenance & Improvements
(by Mike Parker)
  (Page 8)
Page: 1 2 3 4 5 6 7 8 9 10 11
5. Horizontal Deflection Module
This board is located between the green and blue tubes.
For this you'll need a good soldering tool, solder and a 220 mfd @ 160vdc cap (C50). And remember that we clean each board as we go with denatured alcohol.
Replace "C50" it's in the modulator circuit on that board, The modulator circuit supplies the operating voltages for the deflection power stage (power MOSFETs), this circuit varies the voltage for the FETs based on the scan rate that the project receives. If this cap leaks, it'll cause erratic width performance, or inability to achieve max horizontal width.
Then we'll move on to soldering various contacts on the board. If you remove this board and closely examine the contacts you'll immediately notice the need for soldering. The contacts that will need this soldering are the three power MOSFETs and two transistors that are mounted to the heatsink:
The next items for soldering are the five relays and six coils that are mounted next to the three large relays:
Next, inspect the three yoke connectors that are attached to the board, look through the plastic connector and look for burns or dark marks in the area where the contacts meet. If you see burn or darkness on that connector, it'll need replacement.
This simple procedure greatly stabilizes this board, and it'll protect the board from failure, because it's very important that these contacts are tightly soldered, if not, as the board heats up, you could experience drifting or even board failure.
... Previous Page
Next Page ...
