    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Marquee Maintenance & Improvements
(by Mike Parker)
  (Page 10)
Page: 1 2 3 4 5 6 7 8 9 10 11
7. Convergence
Now for the convergence board. This board is very well designed, with only one exception, yep, they used the same little Mickey mouse resistors on this board. The early version boards had one each, while the later version boards had a double stack. There are twelve of them on the convergence board (24/stacked on the later version). R118, R117, R218, R217, R318, R317, R418, R417, R518, R517, R618 and R617. There are also 48 1.2 ohm (same Mickey-mouse resistors) right near the power transistors.
And while you have this board out, make sure you solder the many leads for the 30 power transistors that are heat-sinked. If you look very closely at the contacts on these transistors you should see the need for soldering, especially on a high use projector, take your time and solder all 90 contacts.
Next, you'll want to clean that heat sink surface insulator (denatured alcohol) and apply a very light film of petroleum jelly on that insulator. Before reinserting the board, use a ruler or other flat device and align each transistor so that each one would be perfectly inline with the heatsink surface. Now take each heat sink clamp and bend back for better tension.
Do the same for the vertical and stigmator boards (if it has stigmator board).
8. Contrast Correction Module
Remove the contrast modulation board (color correction module), right next to the ACON board (above the control module). This module is not in all Marquee's, look for it on the 8500, 8500LC. 9000, 9500LC.
This board will allow color correction in nine different zones. Much needed for multi-display commercial systems for edge matching and such, but not needed in video applications, and could effect the overall purity of the image – REMOVE IT!
... Previous Page
Next Page ...
