    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Projector Focus & Mechanical Aim
 (Page 6)
Page: 1 2 3 4 5 6 7
3 X 5 Card Optical Focus Technique
At this point in the process, both beam and optical focus should be excellent, but further refinement is sometimes possible.
Use a plain white 3 x 5 card for finding the exact focal distance of the projector. Do this by moving the card fore and aft in front of your screen to see at where a fine focus pattern is best in focus. If it is already exactly at the screen surface plane throughout the screen, then you are done. If it is more than 1 cm in front of or behind the screen do the following. And yes, this will temporarily undo the hard work done getting the phosphor grain sharp.
Display a fine detail focus pattern (internal focus pattern or S&V Home Theater Tune-Up) and intentionally overfocus the optics (rear lens control) so that the center is best optically focused about 2 cm short of the screen. This is in the direction that extends the lens barrel forward. Bringing the focal plane slightly short of the screen lets you more easily examine the focal distances throughout the image area. Check the focal distance for each screen edge by moving the 3 x 5 card back and forth in front of the screen. You'll be able to see very accurately the distance at which things are best focused on the 3 x 5 card. Check if the distances are uneven between left/right (indicating a horizontal lens flapping error) and top/bottom (indicating a vertical lens flapping problem). Fine tune lens flapping to make the focal distances for top = bottom, and left = right. This is the time to fine tune lens flapping rings. The 3 x 5 card check is so precise that you'll notice the flapping changes caused by uneven tension on the lens mounting screws.
Next, pay attention to how the left and right edge distances compare to the distance at screen center. They should be about equal between center and edges. If not, slightly adjust the inner and outer optical focus to bring both the edges and center to focus about 2 cm in front of the screen. Notice that I don't have you check the screen corners. That is because there will almost always be a difference in the extreme corners and center and using the left/right edges gives a good compromise which preserves the central focus where the video image is going to be sharpest portion of a movie frame anyway.
At this point the optics are perfectly balanced in terms of Scheimpflug and inner vs outer lens focus. The next step is to shift the entire optical plane back onto the screen surface. Make tiny movements of the rear lens focus knob while repeatedly checking the optical focus position with the 3 x 5 card. One thing to consider is that you probably did all this with the projectors lens hood off and the lenses are a little cooler than normal. As the lenses warm up, their index of refraction decreases, the lens mounts expand, and the focal plane can move slightly inward or outward. You should recheck the focal plane when the optics reach normal operating temperature an hour or so after the lens hood and hushbox are closed. Also, recheck 24 hours later and compensate for mechanical settling.
If you use the 3 x 5 card for final optical focus, you'll note that it is so sensitive an indicator that even the slight shift of the lens while tightening the focus knobs will be detectable. Focusing a projector is an iterative process in which improvement in either optical or beam focus enable finer observation and adjustment of the other focus system. Patient and diligent technique is needed to achieve maximal sharpness of both optical and beam focus systems. Expect a great deal of exercise moving between screen and projector using this technique.
Perfected optical focus means that even better beam focus may be possible. Revisit beam focus and fine tune as appropriate.
Only AFTER both optical and beam focus are perfected should you do final work on geometry and convergence can proceed. Otherwise, geometry and convergences changes wrought by focus adjustments will upset a hard gained geometry and convergence setup.
Speaking of which, the next steps in projector setup would be:
Rough geometry and convergence
Grayscale calibration (with possible blue gun defocusing)
Final geometry and convergence
(These steps are not discussed in this article).
... Previous Page
Next Page ...
