    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Projector Focus & Mechanical Aim
 (Page 7)
Page: 1 2 3 4 5 6 7
CPC Magnet Adjustment of Beam Astigmation
Note: This adjustment procedure is similar in concept to the one outline here.  It is still included in this article for sake of completeness.
Warning: This adjustment is for advanced setup technicians only. Novices and non-technicians are warned to avoid performing astigmation CPC magnet adjustments. Adjustment of CPC magnets should ONLY done by advanced setup personnel. Improper technique will render focus impossible. High voltage shock and tube neck fragility are also significant hazards during CPC magnet adjustment.
Electron beam focusing lenses are not perfectly uniform. Also, the direction of the earth's magnetic field can cause the beam to enter the lens off center. Astigmation of the beam fine tunes the lens uniformity and centers the beam as it enters the lens. This allows the beam lens to create a small electron spot with minimal flaring. Poor astigmation can make good electron beam focus impossible.
Static electron beam astigmation is carried out using CPC magnets (called Color Purity Control for historical reasons) on the tube neck and/or electronic astigmation controls. If both CPC magnets and electronic "dynamic" astigmation controls are present, it is best to let the CPC magnets do most of the work and have the electronic astigmation system merely fine tune the effects. One must neutralize the electronic astigmation controls prior to adjusting CPC magnets.
CPC magnets are arranged as pairs of rings about the end of tube neck near the socketed drive board. They should not be confused by the much more forward raster centering magnets just behind the deflection yoke. Projectors don't always have the full set of 2, 4, and 6 pole CPC magnets. CPC magnet assemblies vary in appearance and mechanical design. Sometimes the ring pairs have a small knob allowing one to adjust the angle between the two rings of a pair. More often one merely sees tabs with which to manipulate the rings. The CPC have 2, 4, or 6 magnetic poles, but don't confuse that with the number tabs on the rings. One cannot actually see the poles. By varying the angle between the two rings of a pair (moving tabs in opposite directions or twisting a little knob) one varies the intensity of the effect. Rotating a pair about the axis of the tube neck (moving tabs in same direction or twisting little knob in opposite direction) changes the directionality of the effect. If all three sets of CPC magnets are present, the rearmost is the 2 pole (centering). The middle is the 4 pole (ovalness). And the most anterior (if present) is either non-functional or a 6 pole correction (triangularity).
I'll reiterate since this seems to confuse some people....
Intensity: The amount of effect that a magnet ring pair creates. For instance if you consider the two pole magnet pair, you can make the rings cancel each other out or augment each other by varying the rotation of the two rings relative to each other.
Directionality: The orientation of the net magnetic effect. If you spin a ring pair TOGETHER around the tube neck you spin the direction in which the poles affect the electron beam. Notice that this minimally changes how the poles cancel or reinforce each other. Spinning the pair together merely lets you vary the direction in which that magnet ring pair squeezes or expands the beam.
Spinning a pair together changes the direction of the effect, but making the two rings of a pair spin in opposite directions changes the amount of their effect.
Because the factory performs CPC magnet alignment, shipping can shift controls, and end users are not expected to make these adjustments, the CPC magnets are usually held in place with some silicone adhesive. This must be removed carefully. Very cautious picking at the adhesive with fingers will usually free the controls. Do not mechanically stress the tube necks!
Again, neutralize all electronic astigmation controls prior to working with CPC magnets. On projectors which lack separate electronic astigmation controls, perform CPC and electronic astigmation while the highest scan frequency to be used is displayed.
I assume you know how to change the electron beam focus and don't get that confused with optical focusing.
The 4 Pole (middle) CPC magnets affects ovalness of the electron beam lens. Adjust this while displaying a dot pattern with contrast set moderately high. Intentionally UNDER focus the electron beam making the dots into uniform blobs. Adjust the 4 pole magnets to make the center blob as perfectly circular as possible. Physically walk up to the screen to judge shape. Turning the small knob or moving adjustment tabs in opposite directions alters the amount of ovalness. Spinning the 4 pole rings around the axis of the tube neck changes the direction of the ovalness axis.
The 2 Pole (rear) CPC magnets centers the electron beam in the electron beam lens. Adjust this while displaying a dot pattern while contrast is moderately high. Intentionally OVER focus the electron beam making the dots into a flare with a bright central core. Turning the small knob or moving adjustment tabs in opposite directions alters the amount of deflection. Spinning the 2 pole rings around the axis of the tube neck changes the direction of deflection. Make the bright core centered in the flare.
Go back and forth between the 2 and 4 pole adjustments to get things right. As a final check, carefully watch the dots as you go from under to over focused. The dots should stay almost motionless as you vary the beam focus. If they move, redo the 2 pole adjustment.
You will have to redo raster centering after adjusting the CPC magnets. If working on the blue gun, you'll probably want to leave the electron gun underfocused enough to make its light output measure about 20% higher than its fully focused state to improve grayscale tracking at higher light output.
Guy Kuo
Director - Imaging Science Foundation Research Lab
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Back to Page 1
