    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Projector Focus & Mechanical Aim
 (Page 4)
Page: 1 2 3 4 5 6 7
Rough Optical Focus
Now that mechanical aim of the guns has been done, it is time to do an initial, rough optical focus.
Display a crosshatch pattern. Adjust optical focus using the two knobs. The front most knob on the lens controls edge optical focus. The rear most knob adjusts center optical focus. Dial in center focus first. Then adjust the outer (front knob) focus to while watching the corner lines of the crosshatch flare inward and outward. Try to minimize flaring using the outer focus knob. Go back and forth between the two optical focus knobs to get both center in focus and outer edge minimally flared. Use of binoculars aids this process tremendously.
Rough Scheimpflug (Lens Flapping)
Once rough optical focus is completed, you can perform lens flapping. The following is primarily for projectors which have continuously variable lens flapping. For projectors with lens flapping rings, simply set the lens rings per the installation manual specified settings for your projection distance.
Display a focus pattern. Look ONLY at the center of the top edge. Adjust center optical focus to make that edge sharpest. Note the position of the focus knob. Pay attention to the center of the bottom edge. Adjust lens center focus to make the bottom edge sharpest. Is the lens center focus control in the same position as when the top was sharpest? If so, vertical flapping is correct. If not, adjust vertical flapping using a wrench. Note the wrench position when the bottom edge is focused vs top edge. Set the vertical flapping to put the wrench in exactly halfway between the two positions. Horizontal flapping is performed in an analogous fashion paying attention to only the left and right edges.
Now go back and refine center and edge lens focus. Once that is done you should have the lenses in fair optical focus and flapping. Advanced owners may consider the 3 x 5 card technique fine focusing technique presented later in this document for even better optical focus and Scheimpflug.
Phosphor Grain Optical Focus Technique for when the Electron Beam Has not been Focused Yet
Most people have difficulty deciding whether optical, beam or both kinds of focus problems are present, particularly if they have not already achieved good beam focus. Here is a trick for setting good optical focus without being confused by beam focus. You must have a good pair of binoculars which focus at a short distance to use this technique.
The phosphor surface of a CRT has an inherent grain pattern. Because this grain is visible and is exactly at the plane of light generation, one can use the grain to set optical focus independent of beam focus. A small piece of 3M easy release blue masking tape aids in keeping your eyes correctly focused on screen. Display a bright window pattern and intentionally defocus the electron beam to make the scan lines disappear. Adjust center optical focus while viewing the screen through binoculars. When optical focus is correct, the inherent grain pattern of the phosphor surface suddenly snaps into view. This is nearly impossible to see with naked eye, but binoculars make it readily evident.
... Previous Page
Next Page ...
