    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Projector Focus & Mechanical Aim
 (Page 1)
Page: 1 2 3 4 5 6 7
Updated: 12/25/2004
Written by Guy Kuo, Ovation Multimedia, Inc. - Home of:
Avia PRO
AVIA Guide to Home Theater DVD
Sound & Vision's Home Theater Tune-up DVD
Focusing and aiming a CRT projector is a daunting task. It involves two projection systems which operate in series: Optical and beam focus. Problems in one system make it difficult to see problems in the other. As a result, first time owners are sometimes at a loss as to which system is the problem. Add to that the need to astigmate the electron beam and adjust lens flapping (Scheimpflug) and the novice CRT setup can fall far short of the projector's optimum.
Read through this document in its entirety before proceeding. At first, it will seem as though some steps are discussed in jumbled order. I have attempted to present this in sequence but one must perform tasks iteratively to achieve the final result. One revisits earlier steps because later steps make earlier ones easier to do more accurately.
Equipment Recommended:
An external test pattern DVD such as AVIA or S&V HTT or a test signal generator provide the signals needed for alignment.
A good pair of binoculars which can focus at SHORT distances is very helpful for critically observing the effect of adjustments.
One roll of 3M brand blue easy release masking tape for marking the center of screen surface and edges. Do NOT substitute another brand of tape.
Tape measure to find center of each screen edge.
Laser Pointer or CLEAN straight edge for finding screen center.
Next Page ...
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
