    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Projector Specifications > Seleco
Select a manufacturer:
      >> Ampro
      >> Barco
      >> Electrohome
      >> Mitsubishi
      >> NEC
      >> Panasonic
      >> Runco
      >> Seleco
      >> Sony
      >> Vidikron
      >> Zenith
Model
CRT Size/
LC
CRT
Type
Chassis Controls Peak
Lumens
HScan (kHz)
VScan
(Hz)
Bandwidth
(Mhz)
Screen
Width
(feet)
Max Resolution HDTV Inputs IR
Remote
Zone
Convergence
EM
Focus
New
Price
(USD)
SVT 110 7" Toshiba Analog 680 15-16 50-60 - 5-21 480i N V/S/R - - - -
SVT 130 - Toshiba - - - - - - - - - - - - -
SVT 150 7" Toshiba Analog 680 15-16 50-60 - 5-21 480i N V/R - - - -
SVT 180 7" SD-187 Analog 900 15-16 50-60 - 5-21 480i N V/R - - - -
SVT 190 7" SD-187 ? Digital 900 15-16 50-60 - 5-21 480i N V/S/R - - - -
SVT 195 7" SD-187 ? Digital 900 15-16 50-60 - 5-21 480i N V/R - - - -
SVT 220 - - - - - - - - - - - - - - -
SVP 310 7" Toshiba Analog - 15-16 - 12 5-21 480i N V/S/R - - - -
SVP 320 7" Toshiba Analog - 15-16 50-60 12 5-21 480i N - - - - -
SVP 350 7" Toshiba Analog - 15-16 50-60 12 5-21 480i N V/S/R - - - -
SVP 350+ 7" Toshiba/Sony Analog - 15-16 50-60 12 5-21 480i N V/S/R - - - -
SVP 390 7" Sony 07MS Digital 900 15-16 50-60 12 5-21 480i N V/S/R - - - -
SVP 400 HT 7" Sony 07MS Digital 900 15-32 - 20 - 480p N V/S/R/C - - - -
SVP 400 Plus 7" Sony 07MS Digital 900 15-32 45-130 20 - 480p N V/S/R/C - - - -
SVP 420 HB 7" Sony 07MS Digital - 15-38 - 20 - 480p Y V/S/R/C - - - -
SVP 450 7" Sony 07MS Digital - 15-38 - 20 - 480p Y V/S/R/C - - - -
SVP 450 Plus 7" Sony 07MS Digital 950 15-16 / 30-38 45-130 20 5-21 540p Y V/S/R/C - - - -
SDP 500 Plus 7" Sony 07MS Digital - 15-38 - 20 - 576p Y - - - - -
SDP 500 Plus HD 7" Sony 07MS Digital - 15-38 - 20 - 576p Y - - - - -
SVD 500 HT - Sony 07MS - - 15-38 40-130 20 - 576p Y V/S/R/C - - - -
SVD 700 7" - Digital - - - - - - Y - - - - -
SVD 800 HD 7" - Digital 1050 15-72 45-140 75 - 1280x1024p Y V/S/R/C - - - -
SDG 700 - - - - 15-72 - - - 1500x1200p Y - - - - -
SDG 790 7" - - - 15-90 - - - 1500x1200p Y - - - - -
SDG 900 8" - Digital - 15-105 38-150 75 5-25 1600x1400p Y V/S/R/C - - - -
Model
  Weight in Kg
 Dimensions L x W x H (mm)
SVT 110/130/150/220
30
SVT 180/190/195
35
SVP/SDP Series, SVD 500 HT
35
700 x 620 x 290
SVD 800 HD
58.5
SDG 900
55
Glossary of Terms (click on term for in-depth information)
CRT Size/LC: Although manufacturers measurements will vary, these measurements are the agreed upon measurements by most enthusiasts. Actual raster corner to corner measurements will vary based on the installation. LC is noted for tubes that are liquid-coupled (as opposed to air-coupled). LC'ed tubes offer greater contrast and less halo'ing.
Chassis Controls: Analog chassis projectors use manual "pots" for convergence, image sizing, shift, etc.  With the newer digital convergence feature, convergence is done from the control panel or infrared remote control.  This gives you the ability to stand at the screen and more accurately set up the focus and alignment of the CRT's. Digital convergence units also may have memories for different inputs and aspect ratios.  These can then be changed with the push of a button on the remote.
Peak Lumens: Lumens relate to the amount of energy (light) that's coming from the CRT.  It describes the potential of the projector, but little of the actual brightness you will get on screen.  The brightness depends on many factors.  The most important being the screen size and material as well as ambient light conditions.
Scan Rates and HDTV:  The ability of a projector to display HDTV depends on its scanning capability. For example for a projector to line double standard NTSC signals (480i at 15.75khz horizontal) from DVD, VCR or cable/Satellite to 480p, requires 31.5 Khz of horizontal scan rate and enough bandwidth to handle twice the picture information. HDTV at 1080i requires a horizontal rate of 33.75 Khz and 50 Mhz bandwidth.  720p requires a horizontal rate of 45 Khz with 50 Mhz bandwidth.
Max resolution: This is the maximum resolution that the projector can accept (and sync to) as an input signal. Important: While the projector may be able accept the signal, it may not be able to fully resolve the information on screen without overlapping of scan lines resulting in a softening of the picture. That is, the manufacturer resolution specifications do not necessarily reflect real world resolving capability.
Inputs: As listed above V = standard composite video, usually a BNC connector on projectors (takes a $2 Radio shack connector to convert back to RCA). S = S-video in its usual form. R = RGB in either a DB type plug or 5 separate RGBHV BNC type connectors. C = Component video.  Any values in ( ) are available with an optional input board.
Zone/Point Convergence: A feature of a digital chassis where after doing a rough convergence you can fine tune various areas of the image for a tighter alignment
Electromagnetic Focus: A feature on newer projectors where you not only have the ability to focus corners and center, but additional electronic controls for fine focus of the beam spot throughout various areas of the image producing a sharper image.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and DVD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
  © Copyright 2004-2010 Curt Palme. All Rights Reserved.
