    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Changing a C-Element (Marquee)
 (Page 1)
Page: 1 2 3 4 5 6 7
For definitions of c-element, liquid coupling (LC), or air coupling (AC),  see this page.
Many liquid coupled (LC) projectors were originally manufactured with clear red and green c-elements in order to increase the overall light output of the projector as the original use for many of these projectors was not for home theater. Light output was more important than colour accuracy. Home theater enthusiasts choose to replace clear c-elements with tinted ones in order to achieve more accurate colours (i.e. more accurate SMPTE-C primaries). This is referred to as colour filtering.
Without colour filtering it is not impossible to achieve correct primary colours on a CRT projector: Reds tend to look orange and greens tend to look yellow. As explained in our Greyscale & Colour Calibration for Dummies guide, ensuring that the raw or "primary" colours used to create all colours are correct is critical to both greyscale and colour calibration.
Think of painting with a brush: Greyscale calibration ensures that the proper amounts of paint are mixed together to get the colours we need, while colour calibration ensures that we have the right base colours to mix in the first place. Using tinted c-element ensures that we start with the right base colours. For example: If your bucket of red paint isn't perfectly "pure" red, no matter how you mix in the other primary colours you'll never you'll never be able to get that red any more correct.
Regardless of the projector in question, only the red and green are ever colour filtered.  Blue is never colour filtered.
Below is a screenshot with the red tube displaying an image.  The left half of the image is un-tinted and looks orange while the right side shows the effect of tinting and has a deeper red hue.
Red tube output: No colour filtering on the left, colour filtering on the right
(Thanks to cmjohnson [CJ] for the example photo)
Every manufacturer is different. In the case of the Marquee 9500LC the c-element on the green tube of is already tinted green.  Only the red needs replacing. In the case of the Barco 1209s, both the red and green c-elements are clear so both need replacing.
Some LC coupled projectors already have both c-elements tinted.  The Sony G70 and the Zenith 1200 are two examples.
Note: Colour filtering of LC projectors can only be achieved by replacing the clear red and green c-elements with tinted ones. Air-coupled (AC) projectors achieve colour filtering by using tinted glycol in the coolant chamber in front of the CRT face (ex: Sony 125x/127x, Barco 800) or by using a tinted element with the lenses themselves (ex: the HD-144 lenses on an NEC PG or XG).  Many AC projectors do not use colour filtering at all.
Sony 1272 air-coupled projector with tinted glycol
Barco 808 air-coupled projector with clear glycol
This article however, deals only with changing of c-elements for Marquee LC projectors.  Tinting of air-coupled projectors will be dealt with a future article.
Below is the procedure that you can use if you want to do the c-element change yourself.  This is considered a very advanced procedure as it requires you to completely remove the tube(s) from the projector.
While this procedure was originally written for the Electrohome Marquee 9500LC, it can be adopted for other projectors with clear c-elements if needed.
Tinted c-elements are available from both VDC and 3M.
The following procedure and pictures were graciously provided by forum member HK-Steve.  Thanks Steve!
Tools needed:
• Allen or Hex drivers Keys
• Flat Blade Screwdriver
• Towels or Paper Towel
• Container for the Glycol
• 60ml or larger Syringe
• Small diameter tubing or heatshrink tubing
• RTV Silicon
Steps:
1. Well you already know how to remove the tubes from your Marquee Chassis, so I won’t go through the procedure, so with your tube removed you are ready to go.
2. Remove the Hex Screw in the top of the LC assembly; be careful when you take the screw out, there could be some pressure and glycol with spurt out. Put some paper towel over the top to absorb any glycol.
A hint from forum member erikjohn:
In order to prevent glycol from squirting out remove the top and bottom pivot pieces and flapping adjustment screw. This allows you to release any pressure that was squeezing the bellows and ensures that you will not get a big squirt which can make a mess and get to the magnetics and raise hell.
3. Remove the 2nd Hex Screw; it will let air in as you take the glycol out.
Next Page ...
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
