    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Barco 808/Cine8
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 6)
Page: 1 2 3 4 5 6 7 8 9 10
SMPS sub board:
Looking at the SMPS, the sub board on the top of the main board houses the standby supply that drives the back red/green LED, the CPU/processor board and the IR sensors. The sub board also contains the master width circuits for the H deflection board, and the temperature control thermistor that determines the fan speed, depending on the internal temperature of the set.
The 125mA fuse protects the standby supply. Should a fault occur on the standby board, this fuse will blow. Note that the stock Barco fuses are sand filled, and must be measured with an ohmmeter to determine if they are blown. 125mA fuses are hard to find, do not install anything over a ½ amp fuse in this slot, or serious damage can occur if there’s a short on the board. Note also that these fuses are European ‘F’ fuses, a good electronics supply shop will carry them, Radio Shack may not.
Staying on the sub board for a moment, the only user adjustment on this board is the master width control. Under normal operation , this pot will not need adjustments, however if the power supply has been repaired or replaced, the pot might need adjusting. The Barco service manual outlines one method of setting this pot, here’s how I do it:
Go into the geometry menu and set the H width to 50%. Put up the test grid (genlocked test pattern) and set this trimpot so that the test pattern _just_ overshoots the sides of the tubes. The regular video image should then fall within the phosphor area of the tubes, and have good width. Note that setting this pot too high or too low may trigger a ‘scan fail’ condition on the G2 board, and cause the set to shut down the HV section.
SMPS Back View:
One of the common causes of failure of the Barco SMPS’s are bad solder connections, the most common ones are pointed out in the picture. Check all solder connections with a magnifying glass, and resolder all suspect connections, using resin core solder of course. If you don’t know how to solder, please leave even this step to an expert.
... Previous Page
Next Page ...
