    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Barco 808/Cine8
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 7)
Page: 1 2 3 4 5 6 7 8 9 10
8) G2/diagnostic board:
This board has a row of lights on the edge of the board, telling you the status of most of the power supplies in the set. This board also generates the convergence voltages to power the convergence board, and the gray block on the top of the board takes 12,000 volts from the quadrupler and drops it down to about 1000 volts for the G2 (master brightness) voltage to power each CRT.  The master brightness (G2 adjustments) are on this board behind the gray G2 block. In BG 808s sets that use Sony tubes, this block also feeds the 5Kv focus voltage to the tubes (not used in the other 808 models.)
As per the pictures, the G2/diagnostic board has a row of green LEDs on it along with one red LED, and an additional separate green LED. The green LEDs all grouped together monitor the main SMPS, and each LED represents one voltage. All of the green LEDs should be on when the set is turned on. One of those LEDs does not come on until the set goes through a full diagnostic check, about 5 seconds after power is turned on.
The single green LED away from the rest is to indicate a working convergence power supply, which is located on the G2/diagnostic board. If this green LED is not lit, the set should fire up and show a picture, but the convergence and geometry controls will have no effect.
There are 4 fuses on this board. Three are soldered in place, the 4th is in the black plastic cylinder. Replace with the same value fuse, if they continue to blow, the board or something in the set has failed.
The G2 adjustments are the individual master brightness controls for each tube. Mis-adjustment here will cause a dim or washed out image. Please refer to the service manual for the proper settings of these controls.
... Previous Page
Next Page ...
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
