    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Barco 70x/Cine7
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 9)
Page: 1 2 3 4 5 6 7 8 9 10
Video input board
The above board under the CRT’s is the video input board, with the deflection processor located to the left, and the shielded board to the right under the blue tube is the quad decoder. These boards are hard to service by the end user. There are many revisions of these boards, and most will not interchange with another. The input LED’s indicate which input is selected via the keypad. With the late model 708 board pictured above, most components are of the surface mount type and cannot be removed without special tools. Failure of the deflection processor can cause a ‘no picture’ condition with no fault LED’s being lit. Ditto for a bad video board or quad decoder.
The CRT sockets shown above house the video output section for each CRT. All three are identical and can be swapped to determine whether a video output card is bad. Note that the multi-pin plug in connectors onto the video board bend pins very easily, and more than one ‘dead’ video output board has been due to a bent connector pin on the motherboard.
... Previous Page
Next Page ...
