    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Panasonic 1083/1085
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 2)
Page: 1 2 3 4
It's important to do the settings in right order, starting with the green tube. You should set green geometry as good as possible.
The correct setup order is:
  1. Centering
  2. Skew
  3. Bow
  4. Linearity
  5. Size
  6. Pin(cushion)
  7. Pin balance
  8. Keystone
  9. Keystone balance (only for green)
  10. Zone (only for red and blue)
You can try and see what each of these adjustments does or look at the Sony manual. After you've set green geometry, it's time to set blue and red, one at the time. Use the same order as listed above. You should be able to get pretty good convergence without zone adjustment which is used only for little tweaks. When adjusting zone use + and - buttons to select next/previous zone. Again, this all is pretty similar to Sony setup. Anyone familiar with setting up a Sony projector should have no trouble setting up a Panasonic 1083/1085.
... Previous Page Next Page ...
