    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
High Voltage (HV) Lead Splicing
 (Page 1)
Page: 1 2
The following procedure was written by Curt Palme.
While I’ve been critiqued for this, there are times where you need to splice a high voltage (HV) lead due to an arc or to the fact that the HV lead end is different. Now, before we start, the best way to change an HV lead is to cut off the entire HV lead and rubber anode cap right at the bell of the tube and replace the whole lead, but if you’re short on time and don’t have a new lead handy, this is the way to get arc-free HV lead splices.
You need to get some heat shrink tubing, the stuff that shrinks about 40-50% when heated. You need a heat gun, although a lighter will work as well.
Start by stripping back the HV insulation, and form as small a connection as you can. Put a minimum of 5 layers of two or three different sizes of heat shrink over the HV leads, two or three pieces of heat shrink over each HV lead. Make sure that each layer of heat shrink is slightly longer than the next, and allow for at least 1” of overlap onto the original insulation area (see image below):
Solder the splice point so that stress can’t pull the lead apart (see image below):
Next Page ...
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
