    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Ampro 2300/2600
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
Some quick tips provided by 'phooka' of the AVS forum:
1) The helps menus are 3600/4600 style, that is help setup is [help] 5, not [help] 7 a la 2000.
2) 77 [code] and 79 [code] leave you with the color temp at "user settings" and basically no real drive on the CRTs. The fool proof way on my 2600HD to get help visible is to do the 77 [code] and 79 [code] then [help] 5 followed by 96 [code] and reset to a color temp of 6500K. Then turn up the brightness and contrast till you can make out the help text.
3) An easy way to tell that the help screens are active is watch/listen for the red CRT to turn off.
4) If following the 3600/4600 setup manual there is no static horizontal shift, and no EM focus, focus is via a HV breakout block just like in a late model 2000D/G
5) The internal test patterns, are way off, use external or you have no hope of getting good edge convergence.   However, if you press "4" then "test" and the test patterns will be gen-locked to the video source. That makes the convergence (or registration as Ampro called it) much better.
6) The neck boards are late 200 series so look in the 2000 manual for G2 setup procedure and test points for sub-contrast and sub-brightness settings.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and DVD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
