    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Tinting Glycol
 (Page 1)
Page: 1 2 3 4 5
For definitions of air coupling (AC),  liquid coupling (LC), or c-element, see this page.
Many air coupled (AC) projectors were originally manufactured with clear glycol in the red and green tubes in order to increase the overall light output of the projector.  Some home theater enthusiasts choose to replace the clear glycol with tinted glycol in order to achieve more accurate colours (i.e. more accurate SMPTE-C primaries). This is referred to as colour filtering.
How much of a difference this actually makes to the projected image is hotly disputed on many online forums with some saying the difference is huge and others indicating that it's not worth the hassle. Proponents of colour filtering will tell you that without colour filtering reds tend to look orange and greens tend to look yellow.  Regardless of the projector in question, only the red and green are ever colour filtered.  Blue is never colour filtered.
Below is a screenshot with the red tube displaying an image.  The left half of the image is un-tinted while the right side shows the effect of tinting.
Red tube output: No colour filtering on the left, colour filtering on the right
(Thanks to cmjohnson [CJ] for the example photo)
Air-coupled (AC) projectors achieve colour filtering by using tinted glycol in the coolant chamber in front of the CRT face (ex: Sony 125x/127x, Barco 800) or by using a tinted element with the lenses themselves (ex: the HD-144 lenses on a NEC PG or XG).  Many AC projectors do not use colour filtering at all. Every manufacturer is different. Some, such as Barco, tinted their earlier models such as the 800 and 801, but then stopped tinting in later models such as the 808 and 1208 in order to increase light output.
Colour filtering of liquid coupled (LC) projectors can only be achieved by replacing the clear red and green c-elements with tinted ones.
Sony 1272 air-coupled projector with tinted glycol
Barco 808 air-coupled projector with clear glycol
This article deals only with the changing of clear glycol for tinted glycol in the red and blue tubes. Changing of clear c-elements to tinted c-elements is dealt with in other articles on this website.
Below is the procedure that you can use if you want to tint your own glycol.  This is considered a very advanced procedure as it requires you to completely remove the tube(s) from the projector.
While this procedure was originally written for using a Barco 808 as an example, it can be easily adopted for other projectors with clear glycol if needed.
The following procedure and pictures were graciously provided by Bjørn Hegelstad of Norway.  His web site can be found at: http://www.crtht.com. Bjørn offers home theater installations, CRT sales, CRT modifications, and gray scale calibrations.
Warning!
I can’t guarantee any of this, this is only for other HT-enthusiasts that like to test and try new things.
I have only tried this on the BarcoGraphics 808s tubes, and other tubes can be different in construction so this procedure may not work on them.
You do this entirely at your own risk.
Background information and testing:
This whole project got started because of Rosco color filters (essentially coloured see-through plastic sheets) and what they did for the colors on CRT projectors without color filtered lenses/glycol.  Rosco filters got the colours right but at a cost: The colors were beautiful but the filters produced reflections and ruined the black level.
That was when I started on tinting glycol. Because I have a BG808s that is color filtered with the glycol from a BG801s, I thought there had to be a way to get coloured glycol.
But after a lot of mailing around, I still had not found out where to get hold of the red and green glycol.
I then got some interesting suggestions from other enthusiasts: First I tried with ink and it looked great but it was entirely water based so I didn't think that would be clean enough for the glycol in a CRT projector.
Then candy dye was suggested and I found out that it was glycol based, so I thought that would be better than the water based ink. So I started testing and finding out how to mix it and get the right color density. After a lot of testing I found out that the candy dye color density didn't last very long.
Then I got back to inks and I found out that it was more correct; with magenta for the red tube and cyan for the green tube. That's where I am now and the only thing left is to test if the ink/glycol combination lasts as long as the original coloured glycol.
Fast forward a few days...
The colors are holding their density so far. This is a much better way to do the color filtering than the Rosco filters, because there are no reflections and there is less light loss.
I am going to take a measuring every 50 hours of the color density of the coloured glycol to see if it is keeping the right color for long term use. I have supplied this to a few BG808s users for testing as well.
The coloured glycol I have mixed gives the same coloring as the BG801s original coloured glycol. I can't give any guaranties how long it will last, but it gives the most beautiful colors I have ever seen on the BG808s.
Fast forward a few months...
I measured the BG808s projectors with ink coloured glycol and they are all stable. They have been used from 100 to 220 hours since they where color filtered with ink in the glycol. That means that the project has been a success this far, and this is the cheapest way to get beautiful colors on air coupled Barco projectors.
I am also warning people about the early tests with the candy dye, as it did not work at all as the green candy dye changed color after a short while and the measurements where much worse than with out the dye.
If anyone has used candy dye you should change it to ink based or clear glycol.
For results of the tests, see the CIE chart and measuring on the very last page of this procedure.
Update: One user of this tinted ink (Nicholas) has indicated that for him the ink-tinted glycol had faded over a period of a couple of months just sitting in a container in his closet (unused).  Caveat Emptor.  Others have had absolutely no problems over 7+ months (forum member 'secstate').
Another option that some users are adopting: Instead of tinting clear glycol, some users are using the tinted glycol from worn tubes in older projectors that had tinted such as the Barco 800 or the Sony 125x/127x. Older projectors such as these with worn tubes can be had for next to nothing, so it's a viable option assuming that the glycol's still usable (not cloudy).
Next Page ...
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
