    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Installing Colour Filtered HD144/145
Lenses on a Marquee
      (Page 2)
Page: 1 2
Now let’s look at the differences between the stock HD8 and the HD144 lenses.
The problem with the swap is the HD144 lenses are quite a bit smaller than the HD8 lenses. The barrel has a smaller radius but the main issue with the swap is that the barrel juts deeper toward the tubes on the HD8s. Some mods simply mount the HD144 and cut the springs allowing the plate to be adjusted closer to the tube face. The problem with this is that the HD8s can no longer be used without sourcing new springs.
OK, so. Here is what we are going to do. We will mount a plate at the rear of the stock plate. The new plate will be the mounting point of the HD144 lenses. It will be closer to the tube face by the thickness of the stock plate. The new plate will have a opening to fit the HD144 and have the proper mounting holes. The stock plate will have some notches cut out to accommodate the screw point strengthening webs on the HD144 body. Thus the lens will not require modification at all. The plate used to mount the HD144 lens must allow for the clearance of the stock plate mounting bolts so we will make it an octagon shape. The holes used for mounting the HD8 lenses can be used to attach the new plate.
This is the design of the HD144 mounting plate:
This plate must be fabricated and should be painted flat black. The example shown here was made from two pieces of 1/4" Plexiglass glued together to double its thickness. Non-magnetic stainless steel (aka 300 series), aluminum or even MDF could be used. I would seal MDF if you use that.
This the modification required for the stock plate:
The above slots were made by using a Drill, Jigsaw and a File.
Below are some pictures of the finished product:
What is missing here is a way to encapsulate the nut so they stay put when the lens is removed. One option is to use epoxy to secure the nuts that accept the lens mounting bolts on the adapter plate. Having these secured makes installing the lenses much easier.
If you have any comments please contact me.
barrybeadman@gmail.com
aka: Joust (on the forum)
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and HD DVD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Back to Page 1
