    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Sony G90 Fan Mod
      (Page 4)
Page: 1 2
3 4 5 6 7
Replacing the front fan:
The front fan replacement is not as easy as the four rear ones and needs some step-by-step instructions as follows:
The idea was to use a larger fan than the tiny 60x60mm (18CFM) located behind the PA board.  Since larger fans do not have to spin as fast as smaller ones to move the same amount of air, they are quieter. I found SilenX IXP-52-14 (24CFM) fan that is considerably better and very silent:
http://www.silenx.com/ixtremaprofans.asp?sku=ixp-52-14
SKU: IXP-52-14
Rated dBA: 14 dbA
Dimensions:80x80x15mm
RPM: 1800 rpm
Airflow: 24 CFM
nominal Voltage: 12V
Current Draw: 0,09A
Power Consumption: 1.08W
Bearings: Hybrid Immersion
However because this fan is larger than the one it replaces, it cannot been place in the Sony original 60x60mm fan position behind the PA board:
Instead, we will install it in the front like this:
Previous Page ...
Next Page ...
