    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Electrohome ECP Series
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 12)
Page: 1 2 3 4 5 6 7 8 9 10 11 12 13
Power Supply Cage
Some of the most common failures on the ECP are caused by bad HV or LV power supplies. There was no service information released for these supplies, so they should be considered a replacement device only. Most of the HV supply is sealed in silicone, and cannot be serviced. To access the power supplies, do the following:
Flip the projector on it’s side and remove the side panels that the fans are mounted to. The side panels then slide down and out of position. You can disconnect the fan leads on the fans themselves, or leave the wiring in place.  Then remove the front panel, also held on at the bottom of the set with either Philips or ¼” hex bolts
You’ll then see this:
The bottom exposed boards are the low voltage power supply. There are two versions of this board, and all LV supplies will interchange with each other. Above it is the HV supply. There were two makes of HV supplies. The early 3000 and 4000 used the Keltron brand, the later models used the Spellman supply that were supposed to be more reliable. I’ve had failures of both. The AC input board has the standby supply located on it that keeps the CPU and the remote sensors powered up. There is an AC fuse at the AC input under the black plastic cover, and there are one or two fuses on the AC input board depending on the version of ECP. Sometimes these fuses blow for no reason, and a dead set will come back to life once a fuse is replaced.
Look around the frame that hold the power supply in place. There are two hex screws near the top that hold it in place, and two screws shown above that hold the ground screws in place. Take all four screws out, and the entire power supply frame slides out as below.
This now gives you access to the LC and HV supplies which remove relatively easily (more or less).
... Previous Page
Next Page ...
