    Site Map
Home FAQs, Tips,
Manuals
Referral
List
Gallery
Links Contact
Us
X-Rite EyeOne Pro 2 Spectroradiometer with ChromaPure
All orders now include the new X-Rite i1Basic Pro 2 (EO2BAS) retail package at no additional cost.
ChromaPure now available with autocalibrate!
EyeOne Pro 2
(without ChromaPure)
   Already own ChromaPure?
Contact us for meter only pricing!
EyeOne Pro 2 with ChromaPure Standard
(Includes the X-Rite i1Basic Pro 2 (EO2BAS) retail package)
ChromaPure info
Regular price: $1249 USD
Our price: $1199 USD
EyeOne Pro 2 & EyeOne Display 3  with ChromaPure Standard
ChromaPure info
Our price: $1558 USD
EyeOne Pro 2 & EyeOne Display 3 PRO  with ChromaPure Standard
ChromaPure info
Our price: $1708 USD
EyeOne Pro 2 with ChromaPure Professional
ChromaPure info
Our price: $1799 USD
EyeOne Pro 2 & EyeOne Display 3 PRO with ChromaPure Professional
ChromaPure info
Our price: $2499 USD
ACCESSORIES & SERVICES
Optional EyeOne Pro 2 Front Projector Kit
Complete details
(Not available separately - must be purchased together with an EyeOne Pro meter)
Regular price: $50 USD
Our price: $30 USD
YOU SAVE $30!
Sign up today to receive the latest EyeOne Pro 2 and ChromaPure news.
Most US orders ship USPS Priority Mail and international orders ship USPS Express Mail. International orders may include extra import duties and/or taxes according to the laws of the target country. Contact us for custom shipping.
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor will automatically convert the amount
to your local currency.
Orders ship directly from our ChromaPure partner in Missouri, USA.
We've worked out an exclusive deal for our members to bring you this product at a price lower than what everyone else pays anywhere on the internet! Buy direct from our ChromaPure partner at prices lower than buying off their own website! Same product, same support, just more money in your pocket at the end of the day.
Confused about meters?  See our FAQ: Which meter is right for me?
The EyeOne Pro and EyeOne Pro 2 (often simply called i1Pro or i1 Pro 2) are true spectroradiometers (spectrophotometers), and thus offers the most accurate readings for the widest range of displays at an affordable price.
The meter's only drawback is relatively limited low-light sensitivity. The EyeOne Pro / EyeOne Pro 2 alone is therefore not the perfect choice for gamma and contrast measurements that will generally require readings below the meter's effective operating range.
Thus, it is a nearly ideal choice for use together with the Display 2/LT, Chroma 5, or Display 3 colorimeter, all of which can work well in very low light settings. Simply create an offset in ChromaPure using the EyeOne Pro / EyeOne Pro 2 as a reference and then use that offset to correct the response of the other meter.
Although the color performance of inexpensive meters (such as the Display 2/LT) is not as good as the EyeOne Pro / EyeOne Pro 2, their luminance performance is remarkably accurate down to surprisingly low levels. Furthermore, once color corrected by a known reference, they maintain their accuracy down to very low levels as well.
The combination of the EyeOne Pro / EyeOne Pro 2 together with either of these colorimeters offers excellent accuracy, speed, and low-light sensitivity and is suitable for professional calibrations.
We offer a special package which includes both the EyeOne Pro 2 and Display 3 (see the BUY NOW button above). You may also use the EyeOne Pro 2 by itself when low-light capabilities are not critical.
The EyeOne Pro 2 is also suited for use with our Greyscale Calibration for Dummies guide as it is also supported by the ColorHCFR software.
Why use a spectroradiometer instead of a less expensive pod colorimeter?
A pod device such as the Spyder2, Spyder3, Eye-One Display 2/LT, DTP-94 or Chroma 5 measures light through filters and estimates the color based on a relatively small number of sensors, usually three and sometimes a few more. The EyeOne Pro / EyeOne Pro 2 uses a holographic diffraction grating with a diode array (no filters to degrade) similar to what is found in laboratory grade instruments. The meter samples with 100 sensors instead of three and uses the internationally recognized scientific standard method from CIE to calculate the x and y coordinates from those samples. The end result is increased accuracy that remains accurate over time.
As mentioned previously however, once color corrected by a known reference such as the EyeOne Pro / EyeOne Pro 2, a less expensive pod colorimeter can remain accurate.
Technical Specifications
Optical Resolution: 10 nm
Sampling Interval: 3.5 nm
Spectral Range: 380 nm-730nm in 10nm increments
Short-term repeatability:* Chromaticity: x,y <+/-0.002
* CRT 5,000k, 80 cd/m2
How does the new EyeOne Pro 2 compare to the original?
In 2012 X-Rite released an updated version of the EyeOne Pro called the EyeOne Pro 2 (i1Pro 2). This version replaces the extremely stable revision D version that people have known and used for years. The accuracy of the EyeOne Pro 2 is the same for the original EyeOne Pro. It looks and feels like it is better built, and is heavier. It is better isolated from temperature (partially due to the aluminum outer shell) and it reads higher levels of luminance, but the vast majority of the improvements made are for reflectance readings for those who use it for photography and print work, not for the emissive mode that we use for calibrating displays.
The EyeOne Pro 2 looks and behaves identically as the EyeOne Pro as far as supporting software is concerned. If software supports the EyeOne Pro, then it will also work with the EyeOne Pro 2. No ChromaPure software or driver changes are required.
New EyeOne Pro 2 on left, original EyeOne Pro on the right:
Calibrating Front Projectors
For best accuracy, we recommend calibrating front projectors by taking readings directly off the screen. For a modest fee a universal front projection kit is also available that includes a tripod mount and an opal glass diffuser for those who prefer the higher light levels available from direct lens readings. However, when taking readings in this mode, you should always color correct the results from an offset created by taking readings from the screen without the diffuser.
What's included
The EyeOne Pro 2 / ChromaPure kit as shipped contains:
  • EyeOne Pro 2 spectroradiometer
  • Flat Panel Holder & Counter Weight
  • Ambient Head (Diffuser or Cosine Corrector) & Cap
  • Small plastic calibration base plate
  • USB cable
  • CD containing documentation, etc.
  • Canvas carrying case
  • ChromaPure video calibration software on CD
We offer a kit that allows customers to use the EyeOne Pro / EyeOne Pro 2 to calibrate front projectors. The kit includes a tripod mount.
We recommend taking readings directly off of the screen without the diffuser. Place the tripod a couple of feet away from the screen at enough of an angle to prevent the probe from reading its own shadow.
If you wish to take readings from the lens to get higher light output, then you must use the diffuser. The diffuser will filter out some light in the higher wavelengths, so you should use ChromaPure's Meter Offset feature (for example) to correct the response by using off-screen measurements without the diffuser as a reference.
Be sure to attach the probe snugly to the tripod clamp, but do not over-tighten. Also, do not allow the clamp to block the central area of the probe where the light is received.
Calibration DVD
For your convenience our ChromaPure partner offers a simple calibration DVD that includes all of the test patterns that you'll need to perform a complete calibration of your display. This DVD is offered free as a complementary download.
Click here to download the DVD
Instructions:
  1. Download the .zip file to your PC.
  2. Unzip the contents, which is an .iso DVD image file, to your hard drive.
  3. Double-click the .iso file.
  4. If you have DVD burning software (e.g., Nero Burning ROM), the file will open.
    Set the image type to DVD (not CD) if necessary.
  5. Insert a blank, writable DVD into your DVD burner, and then burn the image.
Reviews/Testimonials
For reviews/testimonials of ChromaPure calibration software & packages, see our ChromaPure order page.
Why buy from CurtPalme.com?
CurtPalme.com are calibration experts and authors of the world's more popular free calibration guide: Greyscale Calibration for Dummies. We live and breath calibration. No matter what your needs we can assist in choosing what's right for you. We offer products for the budget DIY'er all the way up to the seasoned professional, all at CurtPalme.com discounted prices.
Warranty
All X-Rite meters are backed by a strong one-year warranty. Click here for full X-Rite warranty details.
Links
ChromaPure software
Official EyeOne Pro 2 & with ChromaPure forum thread
ChromaPure Discussion/Support Forum
Colour Science: About Meter Accuracy
Colour Science: Video Calibration Myths
Questions, comments or feedback should be directed to :
chromapure@curtpalme.com
When purchasing you will be paying and dealing directly with the third party seller 'Display Calibrations LLC'.
While this item is not sold or supported directly by CurtPalme.com, we are in the service business and our only goal is your complete satisfaction. We work with our vendors to ensure you are completely satisfied.
Back to the Products Index ....
  © Copyright 2004-2012 Curt Palme. All Rights Reserved.
