Sign up and receive the latest newsletters by email     Join the Forum discussions!
    Site Map
Home FAQs, Tips,
Manuals
Referral
List
Gallery
Links Contact
Us
Which Meter is Right for Me?
Updated: May 18, 2026 - Minor edits for clarity
I don't have time to read all this. What's the best meter?
By far the meter package we recommend the most is the Display 3 PRO or Calibrite Display Pro meter (or any of the variants) with ChromaPure. They are, by a wide margin, the best bang for the buck meter for home users, enthusiasts or even the professional just starting out. Very accurate and fast, with easy to use and intuitive ChromaPure software to walk you through the steps. Perfect for any display technology. If you do not have the need to calibrate projectors and want to save a few bucks, the SpyderX meter with ChromaPure is recommended. Seasoned professionals serious about calibration should consider the Colorimetry Research CR-100 or JETI 15xx/25xx.
I don't want to learn how to calibrate - I want it to all be done automatically for me
No problem! Automatic calibration is possible with an external video processor. It allows anyone with little or no training to fully calibrate their display with almost no user input. It adjusts the display's grayscale, gamma, and colors to levels of accuracy that are simply not achievable by manual methods (i.e. colours are calibrated up to 4913 points instead of only 6). Just setup a few simple options in ChromaPure software, click "Auto-Calibrate", and then go have a cup of coffee while the process completes, usually in a few minutes. A Radiance video processor is used for this. For complete details, see: https://www.curtpalme.com/Radiance.shtm
Still want to do manual calibration yourself? Read on...
Introduction
Many meters are available for greyscale and colour calibration. What follows below is a short list of popular meters recommended by CurtPalme.com.
Colorimeters, Spectroradiometers, Spectrophotometers: What's the difference and why do I care?
A tristimulus colorimeter measures the colour of a display by using three separate sensors to measure red, green, and blue. Each of the sensors sits behind a filter that isolates a particular colour. Using a tristimulus colorimeter is conceptually equivalent to using a normal white light meter and putting different filters on it for measuring different colours.
In an attempt to accurately model human colour vision using three filters, in the year 1931 the CIE (Commission Internationale de l'Eclairage, or International Commission on Illumination) defined the Standard Observer characterized by three colour matching functions:
The filters in a tristimulus colorimeter are modeled after this colour matching function to mimic the human eye's response to red, blue and green. How well a colorimeter works is based on how well the manufacturer is able to match these curves to mimic this response to various display types. A filter-based colorimeter doesn't always get it exactly right however. Why? Accurately matching these complex curves and remaining affordable is always trade-off.
A spectroradiometer (also called a spectrophotometer) on the other hand reads light completely differently. It does not rely on filters as a way of mimicking human colour vision, but rather measures the spectra of a display directly in small bands and uses an industry standard formula to calculate the red, blue and green response. What you see is what you get! Its accuracy depends only on the bandwidth, sensitivity, and resolution of the device. This is why (generally speaking) spectroradiometers don't care what sort of display you're measuring.
The Spyder 1/2/3/4/5, SpyderX, EyeOne Display 2/LT, DTP-94, Chroma 5, X-Rite EyeOne Display 3/Display 3 Pro/Calibrite Display Pro (and all variants), Hubble, and CR-100 are colorimeters.
The EyeOne Pro, JETI Specbos 1201/1211, JETI Spectraval 15xx/25xx, and CR-250 are spectroradiometers.
Most of the very bad meters that clutter the world, delivering unreliable and wildly inaccurate results, are colorimeters. That is because colorimeters can be manufactured very cheaply. But just because bad meters are mostly colorimeters does not mean all colorimeters are bad meters. Designed and manufactured correctly, either technology can provide excellent results. The underlying technology employed is not the way to judge a meter. Each technology has its advantages, and each has its drawbacks.
We've also published a series of Colour Science articles that deal with calibration in general. The following articles are definite must-reads for anyone looking at purchasing a meter:
Colour Science: About Meter Accuracy
Colour Science: Video Calibration Myths
For the complete list of articles, see here. Note that some of these articles are quite technical so don't worry if they don't make much sense to you. You don't need to understand the intricacies of what goes on in a calibration meter to perform an actual calibration!
So what's the best meter?
People want lists so here's one! Generally speaking, from worst to best we have:
1. Datacolor Spyder 1/2/3/4/5 (discontinued, not recommended)
2. EyeOne Display 2/LT (discontinued)
3. EyeOne Display 2/LT PRO (discontinued)
4. X-Rite DTP-94 (discontinued)
5. X-Rite DTP-94 PRO (discontinued)
6. X-Rite Chroma 5 (discontinued, superseded by the Display 3)
7. X-Rite Chroma 5 PRO (discontinued, superseded by the Display 3 PRO)
8. Datacolor SpyderX
9. Datacolor SpyderX PRO
10. X-Rite Display 3/Calibrite Display Pro (and variants)
11. X-Rite Display 3 PRO
12. X-Rite EyeOne Pro (Not suitable as your one and only meter in most cases)
13. X-Rite Hubble (discontinued)
14. Colorimetry Research CR-100 Professional Colorimeter
15. JETI Specbos 1201 (Not suitable as your one and only meter in most cases)
16. JETI Specbos 1211
17. JETI Spectraval 15xx/25xx
This list assumes new colorimeters that are reasonable accurate to begin with and/or have not drifted. Colorimeters can (and should) be periodically recalibrated to ensure they retain their initial accuracy. This eliminates the problems associated with exposure to the elements over time that affect all colorimeters. We recommend doing this yearly. All of the colorimeters listed above may be recalibrated (more information below).
For the reasons stated above, be careful buying old/used colorimeters. We often see old units (some more than 20+ years old!) being sold for cheap on eBay. Unless you have a way to recalibrate these, stay away. It's also possible that a unit may have drifted to such a large degree that it is no longer usable. Until you have it in your hands and are able to compare against a reference device, you have no idea how far it's drifted. How much the meter's been used has no relation to how much it may have drifted (usage does not make a meter drift).
Other budget/homemade meters exist but they're fairly rare and some present questionable results. They're not worth mentioning here given the low price that even reasonable meters can be purchased for.
Others, such as the JETI Specbos 1201/1211 and JETI Spectraval 15xx/25xx are true reference quality meters that meet strict SMPTE (Society of Motion Picture and Television Engineers) standards. These true reference meters are used to calibrate other meters. It's not possible to buy more accurate meters than these reference meters.
An important thing to keep in mind is that using any meter is better than trying to calibrate by eye or by using only test DVDs or Blu-ray discs. Our eyes are horrible at differentiating colours. The idea of being able to calibrate a display with only a $20 test disc and our eyes just doesn't make any sense. It simply cannot be done with any degree of accuracy in a repeatable manner.
It's also important to note that just because you can't afford the best meter doesn't mean you won't reap great rewards by calibrating your display with even a less expensive meter. There is a serious steep 'law of diminishing returns' price/performance curve with meters. It's possible to pay 10-20 times more for a meter that is only slightly better than another model but only achieve 1-2% greater accuracy. Professional calibrators use professional quality meters not only because they're more accurate, but also because they read incredibly fast (time is money when you're paid to calibrate) and are built to withstand the abuse of daily use on the road.
If you're at all serious about Home Theater please calibrate your display. Proper greyscale and colour calibration is regarded as one of (if not the) most important actions that should be performed on all TVs or projectors for optimal picture quality. You will be astounded by the resulting difference in picture quality. To get started with calibration please see our Greyscale & Colour Calibration for Dummies.
So which is most accurate?
This is a nearly impossible question to answer. "It depends". An i1Pro, Chroma 5, SpyderX, or Display 3 will have lower errors than the Display 2/LT. That much is true. Of course, they have (or had) higher asking prices. So the question is not so much one of accuracy, but rather "What you are willing to pay for?" Are you satisfied paying $200 for a meter that removes 80% of the errors or would your rather pay 2-3 times more to remove 90-95% of the errors? Of course, if you invest in a professional quality tool you can remove 95%-99% of the visible errors. Again, notice that the price/performance curve is not particularly consumer friendly. You have to pay a significantly greater amount for what is really just an incremental improvement in accuracy. For casual amateurs, something like the Display 2/LT is fine but is now discontinued unfortunately. Most people starting out therefore ( including home users, enthusiasts, or even the professional just starting out) opt for the Display 3 PRO or SpyderX PRO. Either of these is probably the best choice.
For more information, read this article: Colour Science: About Meter Accuracy
Why buy two meters?
Sometimes kits are listed that feature two meters. Why? As is usually the case, there's usually a trade-off so you'll often see kits with two different meters. Typically one will be a colorimeter and the other will be a spectroradiometer. For example: The Display 3 colorimeter and the EyeOne Pro spectroradiometer.
Even an inexpensive colorimeter like the SpyderX or Display 3 reads extremely fast but drifts over time as it uses a filter that slowly degrades. A spectroradiometer like the EyeOne Pro on the other hand reads very slowly but remains more accurate over time since there's no filter to degrade. The EyeOne Pro also does not read low light levels very well so it's not the perfect choice for gamma and contrast measurements that will generally require readings below the EyeOne Pro's effective operating range.
So what to do? Simple! Pro's and enthusiasts use software such as ChromaPure to create a meter offset make the SpyderX or Display 3 read like the more accurate EyeOne Pro or even more accurate JETI Spectraval 15xx/25xx. This gives the SpyderX/Display 3 the accuracy of the better meter and also gives you the low light sensitivity required to read down to near black. The best of both worlds. You do your readings with the colorimeter (called your "field" meter) and your spectroradiometer remains your "reference" meter used to keep the SpyderX/Display 3 accurate as it drifts over time. (Note that some of the better reference meters like the JETI Spectraval 15xx/25xx will actual perform very well to low light levels so you can use it as your 'only' meter if required. Though if you can afford a Spectraval 15xx/25xx you likely will also own a fast colorimeter as the extra price is somewhat insignificant in the grand scheme of things).
Budget Meters:
Budget meters are typically what users on a budget will consider for calibration use. Some of the cheaper ones are not even individually calibrated to begin with at the factory (more on this below). They are filter based meters so they will drift over time and should be replaced or recalibrated about once a year to ensure accuracy. Keep them in a cool/dark/dry place to minimize drifting. Many users use a sealed ziplock plastic bag or case of some sort with silica gel packets (dessicant) to absorb moisture from the air.
Spyder 1/2/3/4/5 meters (discontinued)
(Not to be confused with the newest SpyderX meter described further below)
Our experience has been that previously available Spyder 1/2/3/4/5 meters typically delivered results that were unpredictable. In tests and discussions with pro calibrators we've found that approximately one third of Spyder units seem to be very accurate, the next third are slightly off, and the last third are considerably more inaccurate. Unfortunately there's no way to know how your Spyder unit rates unless you have a known accurate meter to compare it against. The reason for this disparity in accuracy is that Spyder units are not calibrated at the factory as they come off the assembly line and since they're fairly inexpensive units, manufacturing tolerances are probably much looser than with higher end units. The end result is a variance in accuracy between units. Therefore most calibration experts do not recommend that Spyder 1/2/3/4/5 meters be used as you simply don't know what sort of results to expect.
The obvious advantage of previously available Spyder is cost: A low end Spyder can be had for under $100. In our humble opinion you're better off spending just a little more at a minimum to get something that has some sort of guaranteed level of accuracy. While we're all interested in saving money, buying a meter only to question the results and *then* having to purchase a second (better) meter isn't much of a savings!
Spyder 1/2/3/4/5 meters are not temperature compensated. This means that readings will change as temperature changes. If you wish to use a Spyder 1/2/3/4/5 on displays such as plasmas (which tend to run hot), leave the meter on the display for at least 30 minutes (with the display on) before starting a calibration. This will help to offset the errors a bit.
If you do have a known good reference meter and Spyder 1/2/3/4/5, you can use the offset feature of ChromaPure to measure exactly how far off the Spyder is and create an offset table. ChromaPure can will return reasonably accurate results from the Spyder using this offset tables.
We've used and owned both a Spyder2 vs Display 2/LT Sensor and performed a really simple comparison that showed that our Spyder2 off compared to your Display 2/LT, especially below 40 IRE. While this sample size obviously isn't a good judge of what to expect in all situations it still is truthful information about what sort of variances you may be getting when buying a new Spyder and new Display 2/LT. Spend more money on a meter and you're likely to see less variances from one unit to the next.
The Spyder 1/2/3/4/5 meters can be recalibrated for use in ChromaPure by testing them against a reference spectroradiometer. Offset tables are then created for use in ChromaPure to ensure that you get as accurate results as possible. This also compensates for any drift that may have occurred over time, essentially recalibrating your meter. We always recommend recalibration instead of buying a new meter of possible, not only because it costs less, but because it also keeps more stuff out of landfills.
X-Rite EyeOne Display 2/LT, Display 2/LT PRO (discontinued)
Note: While the Display 2/LT has been discontinued for some years now, it still comes up for sale at some locations. Given how old these units are, we cannot recommend their purchase as the accuracy would be questionable. The text below is kept for historical reasons.
The EyeOne Display meter actually comes in two retail box versions: The EyeOne Display 2 and the EyeOne Display LT. These are in fact the same meter, what differs is the retail software packaging. Both versions come with software to automatically calibrate PC/Mac displays by creating a custom display response curve used by your video card (typically of no use to home theater users). The Display 2 version comes with slightly fancier PC/Mac monitor calibration software. The two meters are identical in terms of hardware.
The Display 2/LT is a nearly ideal meter for the person who is new to video calibration. It is inexpensive, fast, has excellent low-light capabilities, and is the most accurate of the budget meters.
If you're the type of person that only will only be calibrating your own TV or projector rarely, is on a budget, and doesn't need absolute perfection, this is the meter for you. The results will be better than anything you could achieve using only your eyes and a calibration DVD/Blu-ray.
Unlike the (only slightly) lower priced Spyder 1/2/3/4/5 meters, the X-Rite Eye One Display 2/LT is calibrated at the factory as they come off the assembly line. As such, our experience has been that they are all reasonably accurate consistent from unit to unit. This factory calibration most certainly has a lot to do with it.
Colorimeters like the Display 2/LT do drift faster than spectroradiometers so it's best to always get one that's as fresh as possible. Always purchase one from a place that has high turn around, or get the unit calibrated at the time of purchase. You do not want a unit that's been sitting around at hot/humid warehouse for quite some time before being sold to you.
The Display 2/LT is temperature compensated but this compensation is not as accurate as (say) a Chroma 5 however. If you wish to use a Display 2/LT on plasmas (which tend to run hot), leave the meter on the display for at least 30 minutes (with the display on) before starting a calibration. This will help with errors.
Care must also be taken to avoid having stray light hit the Display 2/LT meter from the side. For this reason this meter will be more reliable in some situations as a contact meter (where the meter is placed against the display) instead of as a non-contact meter (for calibrating projectors). If you wish to use the Display 2/LT to calibrate a front projector, care must be taken to avoid any stray light hitting the meter. This means closing all blinds or curtains, turning off all lights, and even making sure to keep the laptop running the calibration software closed while readings are being taken. It's also not uncommon for the bright blue lights of home theater equipment to completely throw readings off at the lower end of the spectrum!
The Display 2/LT meter reads reasonably fast (much faster than the Spyder 1/2/3/4/5) and also reads fairly low (ie: darker) such that you're likely to get reasonable accurate readings all the way down to 20 IRE on most displays as long as you're careful with stray light. If you require very accurate readings right down to very close to essentially black (0 IRE), consider the Hubble or the EyeOne Display 3 (see below).
Note that some LCD displays can pose challenges for the Display 2/LT and colorimeters in general. Colorimeters can give erroneous results when calculating these displays. The errors aren't huge, but they're there, and most people don't go to the trouble of calibrating their displays for the purpose of making them "not too wrong". The problem is with LCDs in general and is not directly related to the difference between CCFL backlit and LED backlit displays.
A special version of the Display 2/LT called the Display 2/LT PRO is available that increases accuracy for use with not only LCD displays, but other displays as well. It uses special offset tables for various display types when used with ChromaPure. The EyeOne Pro and JETI Specbos 1201/1211 or JETI Spectraval 15xx/25xx are also good choice if you wish to remain somewhat future proof and ensure accuracy when calibrating just about any display. The EyeOne Pro and JETI Specbos/Spectraval units do not need to compensated as they read light completely differently as they are spectroradiometers.
The Display 2/LT PRO units are all individually tested against a Colorimetry Research 2nm CR-300 reference spectroradiometer on multiple display types. Offset tables are then created for use in ChromaPure to ensure that you get as accurate results as possible. This also compensates for any drift that may have occurred over time, essentially recalibrating your meter. We always recommend recalibration instead of buying a new meter, not only because it costs less, but because it also keeps more stuff out of landfills!
More information on the Display 2/LT, Display 2/LT PRO »
X-Rite DTP-94 / DTP-94 PRO (discontinued)
Note: While the DTP-94 has been discontinued for some years now, it still comes up for sale at some locations. Given how old these units are, we cannot recommend their purchase as the accuracy would be questionable. The text below is kept for historical reasons.
Those of you that have been doing calibrations for some time will recognize the DTP-94. It's the pre-cursor to the Chroma 5 and was unfortunately pulled off the market in the mid 2000s.
Performance wise the DTP-94 sits squarely between the Display 2/LT and the Chroma 5. It is a fast reading meter that reads well down to fairly low light levels. It reads lower, more accurately, and more consistently than the Display 2/LT but not quite as well as the Chroma 5.
The DTP-94 is more similar to the Chroma 5 as the Chroma 5 was actually designed from the DTP-94 (the specifications are very similar). Think of the DTP-94 as a budget version of the Chroma 5. It reads nearly as fast but isn't quite as accurate. Think of the Chroma 5 as a low priced professional meter while the DTP-94 is the best performing consumer class colorimeter you can get.
The DTP-94 is temperature compensated.
The DTP-94 was primarily designed for flat panel and CRT displays but it works well with projectors. Heed the same warnings mentioned above in the Display 2/LT section however about eliminating stray or ambient light.
Note that some LCD displays can pose challenges for the DTP-94 and colorimeters in general. Colorimeters can give erroneous results when calculating these displays. The errors aren't huge, but they're there, and most people don't go to the trouble of calibrating their displays for the purpose of making them "not too wrong". The problem is with LCDs in general and is not directly related to the difference between CCFL backlit and LED backlit displays.
A special version of the DTP-94 called the DTP-94 PRO is available that increases accuracy for use with not only LCD displays, but other display types as well. It uses special offset tables for various displays when used with ChromaPure. The EyeOne Pro and JETI Specbos 1201/1211 or JETI Spectraval 15xx/25xx are also good choice if you wish to remain somewhat future proof and ensure accuracy when calibrating just about any display. The EyeOne Pro and JETI Specbos/Spectraval units do not need to compensated as they read light completely differently as they are spectroradiometers.
The DTP-94 PRO units are all individually tested against a Colorimetry Research 2nm CR-300 reference spectroradiometer on multiple display types. Offset tables are then created for use in ChromaPure to ensure that you get as accurate results as possible. This also compensates for any drift that may have occurred over time, essentially recalibrating your meter. We always recommend recalibration instead of buying a new meter, not only because it costs less, but because it also keeps more stuff out of landfills.
More information on the DTP-94 /DTP-94 PRO »
High End (Pro) Meters:
These are some of the higher-end meters that are typically used for video display calibration by enthusiasts and professionals looking for quality pro-grade or reference equipment: The Chroma 5, the SpyderX, the EyeOne Display 3/Calibrite Display Pro (and variants), the EyeOne Pro, the Hubble, and the Colorimetry Research CR-100. All are excellent meters and provide great accuracy and are manufactured to high standards, so any of them will be robust and reliable. The JETI Specbos 1201/1211, JETI Spectraval 15xx/25xx, and Colorimetry Research CR-250 reference spectroradiometers are also included in this list. They are true reference device and is accurate enough to be used to calibrate other meters. All pair extremely well with ChromaPure calibration software.
X-Rite Chroma 5 / Chroma 5 PRO (discontinued)
Note: With the introduction of the Display 3 (see below) most people would be better off purchasing the Display 3 over the Chroma 5 as it is a better meter in all ways and less expensive.
The Chroma 5 (also sold as the Progressive Labs C-5 and the Sencore CP6000 ColorPro) is the big brother to the DTP-94 and Display 2/LT. The main advantage of the Chroma 5 is that it reads more accurately, consistently, and lower (closer to black) than the lower end meters. It also employs better temperature compensation so the Chroma 5 stays more accurate with changing ambient temperatures (such as found on plasma displays which tend to run hot). It can also can be calibrated to tighter standards.
The Chroma 5 is also one of the easiest devices to use because it requires no dark reading calibration. Some meters require that they be covered up and a reading taken either when they're first connected or every 10-20 minutes as you calibrate. It only takes a second but it annoys a lot of people! For comparison sake, the Display 2/LT, EyeOne Pro, and Hubble requires a dark reading when the meter is initially connected. The EyeOne Pro and the Hubble then also require periodic dark readings throughout the calibration session.
The Chroma 5 was primarily designed for flat panel and CRT displays but it works well with projectors. Heed the same warnings mentioned above in the Display 2/LT section however about eliminating stray or ambient light.
The Chroma 5 is one of the few meters that can be locked or modified to only work with one software product. If you think you may want to use your Chroma 5 with other software in the future, make sure to ask the seller if their unit is locked or modified in any way. Already own a Chroma 5? Contact us at kal@curtpalme.com and we'll send you a tester application to see if yours is locked or modified in any way that may render your meter unusable with other software. If the tester application works then you're free to use your Chroma 5 with any software that works with unlocked/unmodified Chroma5 meters. If it does not work then you're likely limited to only using the software it was sold with.
Note that some LCD displays can pose challenges for the Chroma 5 and colorimeters in general. Colorimeters can give erroneous results when calculating these displays. The errors aren't huge, but they're there, and most people don't go to the trouble of calibrating their displays for the purpose of making them "not too wrong". The problem is with LCDs in general and is not directly related to the difference between CCFL backlit and LED backlit displays.
A special version of the Chroma 5 called the Chroma 5 PRO is available that increases accuracy for use with not only LCD displays, but other display types as well. It uses special offset tables for various displays when used with ChromaPure. The EyeOne Pro or JETI Specbos/Spectraval units are also good choices if you wish to remain somewhat future proof and ensure accuracy when calibrating just about any display. They does not need to compensated as they read light completely differently as they are spectroradiometers.
The PRO units are all individually tested against a Colorimetry Research 2nm CR-300 reference spectroradiometer on multiple display types. Offset tables are then created for use in ChromaPure to ensure that you get as accurate results as possible. This also compensates for any drift that may have occurred over time, essentially recalibrating your meter. We always recommend recalibration instead of buying a new meter, not that anyone would likely buy a new Chroma 5 every time it drifts a bit.
More information on the Chroma 5 / Chroma 5 PRO »
Datacolor SpyderX / SpyderX PRO
The Datacolor SpyderX is the newest meter from Datacolor, first introduced in 2019. It is by far the best Spyder colorimeter that Datacolor has ever offered. It provides massive improvements in speed and low-light sensitivity over previous Spyders. The SpyderX reads about twice as fast and has low-light sensitivity more than 10 times better than the previous Spyder5. The X-Rite i1Display Pro (Display 3) finally has some competition!
The SpyderX does not require temperature compensation as it is a non-contact meter so the temperature of the display does not come into play. It does however come with a counterweight so that it can indeed be used in contact mode if desired or when ambient light cannot be controlled easily.
The non-contact design means that the readings will not be affected by the heat a display might emit (older plasmas are especially prone to this), nor is there any danger of damaging the delicate surface of a flat panel.
The Spyder3 is also one of the easiest devices to use because, like the Chroma 5 and i1Display Pro, it requires no dark reading calibration. Some meters require that they be covered up and a reading taken either when they're first connected or every 10-20 minutes as you calibrate. It only takes a second but it annoys a lot of people! For comparison sake, the Display 2/LT, EyeOne Pro, and Hubble requires a dark reading when the meter is initially connected. The EyeOne Pro and the Hubble then also require periodic dark readings throughout the calibration session.
A tripod mount is not required with the SpyderX as one is built in, which helps reduce upfront costs.
Note that some LCD displays can pose challenges for the SpyderX and colorimeters in general. Colorimeters can give erroneous results when calculating these displays. The errors aren't huge, but they're there, and most people don't go to the trouble of calibrating their displays for the purpose of making them "not too wrong". The problem is with LCDs in general and is not directly related to the difference between CCFL backlit and LED backlit displays.
A special version of the SpyderX called the SpyderX PRO is available that increases accuracy for use with not only LCD displays, but other display types as well. It uses special offset tables for various displays when used with ChromaPure. The SpyderX PRO increases the stock SpyderX colour and white point accuracy such that in the majority of cases it exceeds that of the EyeOne Pro spectroradiometer. The JETI Specbos/Spectraval units are also good choices (though more expensive) if you wish to remain somewhat future proof and ensure accuracy when calibrating just about any display. They do not need to compensated as they read light completely differently as they are spectroradiometers.
Note: Datacolor (the meter manufacturer) offers different retail PC/Mac monitor calibration packages that include the SpyderX meter, one of which they call the 'SpyderX Pro'. This is unrelated to the SpyderX PRO enhanced accuracy meter we mention here. The various Datacolor packages differ only in software and accessories. The meter is exactly the same in all of their retail packages and is not enhanced for 10+ display types like ours.
The PRO units are all individually tested against a Colorimetry Research 2nm CR-300 reference spectroradiometer on multiple display types. Offset tables are then created for use in ChromaPure to ensure that you get as accurate results as possible. This also compensates for any drift that may have occurred over time, essentially recalibrating your meter. We always recommend recalibration instead of buying a new meter.
When someone needs to choose one single sub-$1000 meter for video calibrations and doesn't need to calibrate projectors, the SpyderX PRO is the meter that we HIGHLY suggest as it is fast reading, accurate, and suitable for all direct vew display types. The SpyderX PRO is a colorimeter that offers professional grade performance at a price affordable to the amateur hobbyist or enthusiast. Only the Display 3 PRO comes close (and has a diffuser so that direct readings from projector lenses may be taken).
How does the SpyderX compare to the i1Display Pro (Display 3)?
This is most often asked question as the two are both reasonably inexpensive meters. While the speed and the accuracy of the SpyderX is similar to the i1Display Pro, there are a few differences that users should be aware of:
  • Low-light performance: The SpyderX's low-light sensitivity at 0.028 nits is still considerably inferior to the X-Rite i1Display Pro, which can read as low as about 0.0025 nits in its optimum mode. In most cases this difference won't matter because 0.028 is more than adequate to measure 5% grayscale. Both meters are adequate for virtually all calibration tasks. The only instance in which this will matter is measuring the black level of a very high contrast flat panel. The SpyderX will measure the black level of any flat panel whose contrast is up to 5,300:1 (assuming a peak white of 150 nits). Contrast above that all the way up to about 50,000:1 the i1Display Pro will be a better choice. Contrast on OLEDs is unmeasurable by any instrument.
  • Use with projectors: The SpyderX is somewhat limited for those who have projectors because it has no illuminance mode, so all projector readings must be taken off the screen. Sometimes it is useful to take readings directly from the projector lens to get more light into the sensor. The i1 Display Pro includes a diffuser that is put into the light path whenever taking lens readings. The SpyderX does not. Users may be able to use the SpyderX meter in this way by employing an aftermarket diffuser, but we have not tested this.
Don't use a projector or ever plan on having one? The SpyderX is our recommended budget meter for those who do not need to calibrate projectors and want a slightly lower cost option to the i1Display Pro. Want to remain future proof? The i1Display Pro is the better choice.
Why would I buy a SpyderX or SpyderX PRO instead of an EyeOne Pro?
The stock SpyderX is less expensive than the EyeOne Pro and may meet your needs, particularly if you are not a professional calibrator and only want to purchase one meter. The SpyderX PRO on the other hand increases the accuracy of the stock SpyderX such that it is more accurate than the EyeOne Pro in the majority of cases and still less expensive.
Why would I buy a SpyderX in addition to a EyeOne Pro?
If you are a professional calibrator, or even a hobbyist who spends a lot of time calibrating, you will find that the EyeOne Pro (being a spectrophotometer) is quite slow. This is particularly true at low light levels. If you're a pro you don't want to spend most of your time waiting for your meter. The SpyderX provides almost instantaneous results so you can perform the same readings over and over while adjusting the display's settings.
The ChromaPure meter offset feature allows SpyderX users to achieve even higher accuracy by creating an offset of your SpyderX using a spectroradiometer (such as the EyeOne Pro or even more accurate JETI Specbos 1201/1211 or Spectraval 15xx/25xx). ChromaPure compares the differences in readings and then allows you to automatically adjust what the SpyderX records as if it was the other meter. The end result is fast calibration increased accuracy.
More information on the SpyderX / SpyderX PRO »
X-Rite EyeOne Display 3 / Display 3 PRO / Calibrite Display Pro (and variants)
The X-Rite Display 3 (the official name is 'i1 Display PRO III') is the newest meter from X-Rite, first introduced in 2011 where it surprised consumers and professional calibrators alike with its high performance at a low price. In 2021 X-Rite and Calibrite joined so you'll also see this meter sold under various Calibrite names including the Calibrite Display Pro, Pro Plis, Pro HL, and Pro HL. All are similar and mostly only vary in the maximum light output they can read. This meter reads about three times faster and to lower light levels than the Chroma 5 it replaced, and costs less. In fact, the read speed above 10 cd/m2 is similar to the approximately 10 times more expensive Hubble!
The main advantages of the Display 3 is that it reads much more accurately, consistently, and lower (closer to black) than the lower end meters. It even reads better than some of the other higher end, more expensive meters. For example, the more expensive Chroma 5 is rated to read down to 0.01 cd/m2 light output while the Display 3 is able to read down to 0.003 cd/m2 (0.001 fL), or about one-third as bright. This is due to the Display 3 lens system which is able to capture and focus more light onto the filter diodes, providing much better low-light sensitivity and much faster readings (similar to the Hubble).
Colour accuracy is also excellent: The stock Display 3 shows errors no higher than xy0.006 for both color and white relative to a $10,000 reference spectroradiometer. This is performance comparable to a stock Chroma 5.
The Display 3 does not require temperature compensation as it is a non-contact meter (like the Hubble) so the temperature of the display does not come into play. It does however come with a counterweight so that it can indeed be used in contact mode if desired or when ambient light cannot be controlled easily.
The non-contact design means that the readings will not be affected by the heat a display might emit (older plasmas are especially prone to this), nor is there any danger of damaging the delicate surface of a flat panel. There is no laser aiming device built-in to the unit however such as with the Hubble. We're sure some intrepid DIY'ers will manage to somehow attach a small laser pointer of some sort. Wink
Because the filters on the Display 3 are installed in a sealed environment, they are not subject to the same type of degradation in performance over time that is typical of less expensive contact meters. This means that the Display 3 needs to be recalibrated less often than a typical colorimeter.
The Display 3 is also one of the easiest devices to use because, like the Chroma 5, it requires no dark reading calibration. Some meters require that they be covered up and a reading taken either when they're first connected or every 10-20 minutes as you calibrate. It only takes a second but it annoys a lot of people! For comparison sake, the Display 2/LT, EyeOne Pro, and Hubble requires a dark reading when the meter is initially connected. The EyeOne Pro and the Hubble then also require periodic dark readings throughout the calibration session.
A tripod mount is not required with the Display 3 as one is built in, which helps reduce upfront costs.
Note that some LCD displays can pose challenges for the Display 3 and colorimeters in general. Colorimeters can give erroneous results when calculating these displays. The errors aren't huge, but they're there, and most people don't go to the trouble of calibrating their displays for the purpose of making them "not too wrong". The problem is with LCDs in general and is not directly related to the difference between CCFL backlit and LED backlit displays.
A special version of the Display 3 called the Display 3 PRO is available that increases accuracy for use with not only LCD displays, but other display types as well. It uses special offset tables for various displays when used with ChromaPure. The Display 3 PRO increases the stock Display 3 colour and white point accuracy such that in the majority of cases it exceeds that of the EyeOne Pro spectroradiometer. The JETI Specbos/Spectraval units are also good choices (though more expensive) if you wish to remain somewhat future proof and ensure accuracy when calibrating just about any display. They do not need to compensated as they read light completely differently as they are spectroradiometers.
The PRO units are all individually tested against a Colorimetry Research 2nm CR-300 reference spectroradiometer on multiple display types. Offset tables are then created for use in ChromaPure to ensure that you get as accurate results as possible. This also compensates for any drift that may have occurred over time, essentially recalibrating your meter. We always recommend recalibration instead of buying a new meter. Unlike the Display 2/LT and Chroma 5 however, the filters on the Display 3 are completely enclosed so they are less likely to deteriorate as a result of exposure to environmental factors.
When someone needs to choose one single sub-$1000 meter for video calibrations, the Display 3 PRO is the meter that we HIGHLY suggest as it is fast reading, accurate, and suitable for all display types. The Display 3 PRO is a colorimeter that offers professional grade performance at a price affordable to the amateur hobbyist or enthusiast. Until the release of the SpyderX, no other single meter even comes close. This title used to be held by the Chroma 5, but with the introduction of the Display 3, we see no reason to suggest the Chroma 5 anymore.
How does the i1Display Pro (Display 3) compare to the SpyderX?
  • Use with projectors: Sometimes it is useful to take readings directly from the projector lens to get more light into the sensor. The i1 Display Pro includes a diffuser that is put into the light path whenever taking lens readings. The SpyderX does not as it has no illuminance mode, so all projector readings must be taken off the screen.
Why would I buy a Display 3 or Display 3 PRO instead of an EyeOne Pro?
The stock Display 3 is less expensive than the EyeOne Pro and may meet your needs, particularly if you are not a professional calibrator and only want to purchase one meter. The Display 3 PRO on the other hand increases the accuracy of the stock Display 3 such that it is more accurate than the EyeOne Pro in the majority of cases and still less expensive.
Why would I buy a Display 3 in addition to a EyeOne Pro?
If you are a professional calibrator, or even a hobbyist who spends a lot of time calibrating, you will find that the EyeOne Pro (being a spectrophotometer) is quite slow. This is particularly true at low light levels. If you're a pro you don't want to spend most of your time waiting for your meter. The Display 3 provides almost instantaneous results so you can perform the same readings over and over while adjusting the display's settings.
The ChromaPure meter offset feature allows Display 3 users to achieve even higher accuracy by creating an offset of your Display 3 using a spectroradiometer (such as the EyeOne Pro or even more accurate JETI Specbos 1201/1211 or Spectraval 15xx/25xx). ChromaPure compares the differences in readings and then allows you to automatically adjust what the Display 3 records as if it was the other meter. The end result is fast calibration increased accuracy.
More information on the Display 3 / Display 3 PRO »
X-Rite EyeOne Pro
The EyeOne Pro is a true spectroradiometer (spectrophotometer), and thus offers accurate readings for the widest range of displays at a reasonable affordable price.
The only drawback is relatively limited low-light sensitivity. It simply does not read as low (close to black) as most colorimeters - even the inexpensive ones! The EyeOne Pro alone is therefore not the perfect choice for gamma and contrast measurements that will generally require readings below the meter's effective operating range. For truly reference spectroradiometer performance, consider the JETI Specbos 1211 or JETI Spectraval 15xx/25xx (the meters that can 'do it all').
The EyeOne Pro is, however, a nearly ideal choice for use together with the Display 2/LT, Chroma 5, SpyderX, or Display 3 colorimeter, which can work well in very low light settings. Simply create an offset in ChromaPure using the EyeOne Pro as a reference and then use that offset to correct the response of the other meter.
Although the color performance of inexpensive meters is not as good as the EyeOne Pro, their luminance performance is remarkably accurate down to surprisingly low levels. Furthermore, once color corrected by a known reference, they maintain their accuracy down to very low levels as well.
The combination of the EyeOne Pro together with either of these colorimeters offers excellent accuracy, speed, and low-light sensitivity and is suitable for professional calibrations.
In addition to its superb accuracy it is the most versatile meter available anywhere due to the spectroradiometer technology used. It is able to read just about any kind of display accurately including CRT, plasma, LCD, the newest LED, front projector, rear projector, etc. If you own more than one meter, one of them should most likely be an EyeOne Pro.
Spectroradiometer technology is typically slow however: It takes longer for each read to come back and update the software that you happen to be using. Especially at the dark end of the grayscale. A reading that will take the Chroma 5 a couple of seconds might take the EyeOne Pro a good 30 or 60 seconds. There are faster spectro's however (such as the JETI Specbos 1211 or JETI Spectraval 15xx/25xx) but at much greater cost. This means that performing a calibration can take longer as you spend more time waiting for the readings to update. Whether the extra time is worth it or not is a call each person has to make for themselves. While most home users may not care, the professional who spends many hours a day doing calibration for a living would be pulling their hair out. This is one reason why pro's will typically use a faster colorimeter with an offset created against the EyeOne Pro to get the best of both worlds: Accuracy and speed.
How does the EyeOne Pro 3 compare to the EyeOne Pro 2 and the original?
From left to right: i1Pro 3, i1Pro 2, original i1Pro
In 2012 X-Rite released an updated version of the EyeOne Pro called the EyeOne Pro 2 (i1Pro 2). This version replaces the extremely stable revision D version that people have known and used for years. The accuracy of the EyeOne Pro 2 is the same for the original EyeOne Pro. It looks and feels like it is better built, and is heavier. It is better isolated from temperature (partially due to the aluminum outer shell) and it reads higher levels of luminance, but the vast majority of the improvements made are for reflectance readings for those who use it for photography and print work, not for the emissive mode that we use for calibrating displays. The EyeOne Pro 2 looks and behaves identically as the EyeOne Pro as far as supporting software is concerned. If software supports the EyeOne Pro, then it will also work with the EyeOne Pro 2. No software or driver changes are required.
The i1Pro 3 was released in 2020 and is the newest version (as of this writing). It supports higher levels of luminance (increased from 1200 to 5000 nit luminance limit). It was developed to accommodate the higher light output used by HDR.
Why would I buy a SpyderX or Display 3 in addition to an EyeOne Pro?
If you are a professional calibrator, or even a hobbyist who spends a lot of time calibrating, you will find that the EyeOne Pro (being a spectrophotometer) is quite slow. This is particularly true at low light levels. If you're a pro you don't want to spend most of your time waiting for your meter. The SpyderX or Display 3 provides almost instantaneous results so you can perform the same readings over and over while adjusting the display's settings.
The ChromaPure meter offset feature allows SpyderX or Display 3 users to achieve even higher accuracy by creating an offset of your SpyderX/Display 3 using a spectroradiometer (such as the EyeOne Pro ). ChromaPure compares the differences in readings and then allows you to automatically adjust what the SpyderX/Display 3 records as if it were the Eye One Pro. The end result is fast calibration with the accuracy of the EyeOne Pro
Why use an EyeOne Pro instead of a less expensive pod colorimeter?
A pod device such as the Spyder1/2/3/4/5/X, Eye-One Display 2/LT/3, DTP-94, or Chroma 5 measures light through filters and estimates the color based on a relatively small number of sensors, usually three and sometimes a few more. The EyeOne Pro uses a holographic diffraction grating with a diode array (no filters to degrade) similar to what is found in laboratory grade instruments. The EyeOne Pro samples with 100 sensors instead of three and uses the internationally recognized scientific standard method from CIE to calculate the x and y coordinates from those samples. The end result is increased accuracy (in some cases) that remains accurate over time. There's no filter to degrade.
Does the EyeOne Pro work with all displays?
Yes. The EyeOne Pro, being a spectrophotometer rather than a filter-based tristimulus colorimeter doe not have issues with certain display technologies.
More information on the EyeOne Pro »
The Hubble is a laser guided non-contact meter for calibrating light-controlled front projected displays. It's the most widely used non-contact colorimeter: Sencore has sold scores of them to professional calibrators as the rebadged OTC1000 (it's the exact same meter).
It is a high-end color analyzer for professionals, pro-sumers, and dedicated amateurs and offers the following advantages over other colorimeters:
  • The size of the Hubble allows it to use relatively large photo sensitive diodes. Coupled with this are the custom optics that span the entire diameter of the chassis. The lens focuses all of the collected light onto the diodes. The result is extremely effective low-light sensitivity. The Hubble will read down to 0.001 fL (same as the Display 3). This is ten-times the sensitivity of the Chroma 5 and sixty-times the sensitivity of the EyeOne Pro!
  • Because the filters are installed in a sealed environment, they are not subject to the same type of degradation in performance over time that is typical of less expensive contact meters. This means that the hubble needs to be recalibrated far less often than a typical colorimeter (same as the Display 3).
  • The speed at which the Hubble reads light and color is astonishing. Readings, even at low light levels, are nearly instantaneous (faster than the Display 3).
  • The non-contact design (same as the Display 3) means that the readings will not be affected by the heat a display might emit (plasmas are especially prone to this as previously mentioned), nor is there any danger of damaging the delicate surface of a flat panel. Also, because of the laser aiming device built-in to the unit, you can precisely aim the Hubble and even take readings off the screen of a front projector from very near the normal viewing distance.
The observant reader will note that a lot of these features are now available on the Display 3 meter, at 1/10th the cost. If the laser pointer or the faster low-light reading is going to be of use, consider the Hubble over the Display 3. If the meter needs to be used commercially in the field and will incur more rough handling, consider the Hubble.
More information on the Hubble »
There are two colour analyzers that professionals and dedicated enthusiasts generally seek: A reference spectroradiometer for the last word in colorimetric accuracy and a professional quality colorimeter. The Klein K-10a, previously the only professional quality colorimeter on the market, retails at $7,000 USD.
Now there is a new entry to the professional colorimeter market, the CR-100 from a new company called Colorimetry Research Inc. It is an incredibly fast reading colorimeter, reading more than twice as fast as the popular Display 3.
In our testing of the CR-100 we have found that it performs at least as well, and with respect at least to repeatability even better, than the Klein instrument. It does this at a significantly lower price point of $5490 USD.
The CR-100 is accurate enough to be used as a standalone color analyzer for professional applications. For the most demanding applications it can be profiled against a true reference spectroradiometer (such as the JETI 12xx/15xx/25xx). Either way, its speed, low-light sensitivity, and repeatability are world-class.
The CR-100 is the most affordable professional colorimeter available. Just mount either on a tripod, facing towards the source, connect to ChromaPure Professional, and then use as you would any other color analyzer.
For a complete set of performance results see our CR-100 page.
The CR-100 is supported by ChromaPure calibration software.
More information on the CR-100 »
The Specbos 1201 and 1211 are some of the most affordable true reference color analyzers available on the market today. Just mount either on a tripod, facing towards the source, connect to ChromaPure Professional and use as you would any other color analyzer. First introduced in 2005 (for the 1201) and 2009 (for the 1211) both units are now discontinued.
At some point many professionals conclude that their work requires a reference colour analyzer. SMPTE has established standards for such a device. It must measure color accurately to within +/- 0.002 xy at or above 10 cd/m2 and luminance accurately to within +/-0.5 cd/m2 for white field measurements. These are very exacting specifications that no tristimulus colorimeter can achieve, at least for chromaticity. For this level of accuracy you must have a 5nm spectroradiometer.
Unfortunately, such devices are not cheap. The Photo Research and Minolta reference devices start at about $15,000 and go up to near $30,000. The X-Rite EyeOne Pro is reasonably affordable, but it is a 10nm device that cannot routinely achieve +/- 0.002 xy accuracy. Furthermore, in addition to being expensive, true reference devices also often suffer from practical limitations. They can be slow and have problems with low-light readings.
Recently, a German company JETI Reference Instruments has developed two true reference spectroradiometers, the Specbos 1201 (also known in the U.S. as the Orb Optronics SP100 - same meter, different name) and the Specbos 1211, that solve most of these problems.
First, they are relatively affordable, that is at least what passes as "affordable" in the context of reference devices. Second, both are reasonably fast for higher luminance sources, and the 1211 is speedy even with low luminance sources. They are also amazingly compact and portable and both include a nifty laser spotter that allows for accurate aiming. The only feature these incredible devices give up to the established Photo Research and Minolta competitors is stand-alone operation. The Minolta and Photo Research alternatives allow for aiming through optical sights and readouts on a small LCD screen. They are fully functional devices without a PC. In contrast, the JETI devices work only when attached to a PC via USB with custom software (such as ChromaPure of course!). For display/home theater calibration this is none issue as you'll be using calibration software anyway.
Both units share a similar design and software support. Both achieve reference levels of accuracy. The differences? Well, the 1211 is larger than the 1201 and about 30% more expensive. But surely the most important difference is low-light sensitivity. The 1211 is MUCH more sensitive than the 1201. At light levels at or above 50 cd/m2 (14.6 fL) they perform similarly, but as you go lower than this the 1201 begins to take noticeably longer and longer to return a reading. At 4 cd/m2 (1.2 fL) the 1201 will take approximately a minute-and-a-half to return a reading. By way of contrast, at this level of stimulus, the 1211 chugs happily along returning a reading in about 5 seconds.
This has profound implications for day-to-day use when calibrating displays. For this reason, the 1201 is best used for color management, when light levels are generally high, or as a reference device employed to create an offset for a field colorimeter, such as the Chroma 5 or Hubble. The 1211, on the other hand, can be used as a working or field color analyzer (one that is not solely only used to create offsets to make other faster meters accurate). Its speed and low-light sensitivity make it suitable for any calibration task - except perhaps reading black level - where the light level is so low even the 1211 often cannot cope. Fortunately, very low light levels can be accurately read with quite inexpensive instruments, such as the AEMC CA813 illuminance meter. The Chroma 5 will read down to about 0.01 fL, and the Hubble will read down to 0.001 fL.
The JETI Specbos 1201/1211 are supported by ChromaPure calibration software.
More information on the JETI Specbos 1201/1211 »
The Spectraval 15xx/25xx are the most affordable true reference color analyzers available on the market today. Just mount either on a tripod, facing towards the source, connect to ChromaPure Professional and use as you would any other color analyzer. The 15xx series was first introduced in 2014-2015.
Coming off the enormous success of the JETI 1211, JETI has developed a new line of reference spectroradiometers that seek to offer equivalent performance to the 1211 at an even lower cost and with increased user flexibility. This effort has resulted in two new products, the Spectraval 1501 and Spectraval 1511. Each performs the same, but offer different user interfaces. The 1501 must be controlled by PC software, just like the JETI 1211. The 1511 adds a small LCD screen that allows the user to take measurements and view results without ever connecting to a PC.
Both the 1501 and 1511 offer built-in Bluetooth, which allows wireless connection to the PC for added user flexibility. Otherwise, the Spectraval units offer similar speed, accuracy, and repeatability to the 1211 in addition to offering even higher dynamic range through greater maximum luminance. The 1211 offers a wider spectral range, but this is unecessary for measurements in the visible range that we care about in home theater. To top it off, the Spectraval units are less expensive than the 1211.
The JETI Spectraval 1501 is the replacement of Specbos 1201. It covers the same spectral range (VIS), but is about ten times more sensitive. Therefore it can be used for low light applications in the same manner as Specbos 1211, where Specbos 1201 was not recommended for such as the calibration of monitors. Spectraval 1501 is intended for Radiance mode measurements only, a diffusor, which is included in the specbos 1201 delivery, has to be ordered separately (ACC 032). If a stand alone solution is needed, then spectraval 1511 can be used. It has the identical parameters as spectraval 1501, but is equipped with display and SD card reader.
Choose Spectraval 1501/1511 over of Specbos 1211 for the following reasons:
- If a wavelength range beyond visible is not needed (version of spectraval 15x1 up to 1 μm is planned)
- If no accessories other than a diffusor are needed (currently only a diffusor is available for spectraval)
- If a luminance measurement above around 3500 cd/m2 is needed (illum. A - 5000 cd/m2, typical white LED - 3500 cd/m2 for Specbos 1211, values up to 100 000 cd/m2 for spectraval)
- If a stand-alone operation is needed (spectraval 1511 is equipped with display and SC card slot)
- If a wireless connection is preferred (spectraval is equipped with Bluetooth interface by default)
For a more in-depth comparison, refer to the JETI 12x1 vs 15x1 document (PDF format): http://www.curtpalme.com/images/JETI12x1_vs_15x1.pdf
In late 2024 JETI discontinued the 15xx series replacing them by the newer 25xx series, which mostly adds features not relevant to home theater display calibration such as broader spectral capabilities (UV or NIR) and modern workflow upgrades (like USB-C, expanded storage, and VR/AR glass accessory compatibility).
The JETI Spectraval 1501/1511 are supported by ChromaPure calibration software. The 25xx series is not officially supported.
More information on the JETI Spectraval 15xx/25xx »
Still confused as to what's the right choice for you? We will help you choose! Email us at Kal@CurtPalme.com
