HDFury2 user manual V.2.3
Post new topic   This topic is locked: you cannot edit posts or make replies.   Printer-friendly view    CurtPalme.com Forum Index -> HDfury Products
Club Member
PostLink    Posted: Sun Jun 28, 2009 7:57 pm    Post subject: HDFury2 user manual V.2.3 Reply with quote
HDFury2 users manual
Thank you for purchasing the HDFury2 HDMI to RGB/YUV converter.
The HDfury2 is an HDMI to RGBHV or YUV/YPbPr ( component ) adaptor with two channel sound output in either digital optical S/PDIF or two channel analog.
Preface:
The Hdfury2 allows you to upgrade any TV/projector by adding an HDCP compliant HDMI digital video input! Works with any TV that accepts either Component (YPbPr/YCbCr) or RGB/VGA! Don't be stuck watching Blu-ray, DVD, Satellite/Cable at only 480p! Add an HDfury2, allowing you to watch hi-def content at up to FULL HD *1080p resolution!
*provided your display is capable of FULL HD
Table of Contents
Chapter 1
1-1. Getting Started - Unpacking your HDFury2 kit
1-2. What's included
Chapter 2
2-1. HDFury2 specifications
2-2. RGB/YUV switch
Chapter 3
3-1. Layout
3-2. Hooking it up
......1./Component
......2./VGA/RGB
......3./BNC/RGBHV
......4./BNC/RGBS
......5./VGA/YPbPr
......6./RGBHV to 9 pin Barco Port3
......7./HDFury2 and Box1020 or Box1040
......8./HDFury2 and GammaX
......9./Mitsubishi Rear Projection CRT televisions with 1080i HD input over RGBHV on 5 BNC or 5 RCA connectors.
.....10./ Switchers - Sony, NEC, Electrohome, Barco and others.
3-4. Long HDMI cable runs
3-5. Hooking your HDFury2 to an M1 cable
3-6. POWER SUPPLY UNIT ( PSU )
3-7. Color depth upscaling
Chapter 4
4-1. Frequently Asked Questions
Chapter 5
5-1. HDFury2 audio
Chapter 6
6-1. GammaX
6-2. GammaX and component signals
6-3. Hooking up your GammaX
6-4. Adjusting your GammaX
6-5. INV and PASS switch
NOTE: The contents of this manual are subject to change without notice.
Chapter 1
1-1.Getting Started:
Unpack your HDFury2 kit and ensure all the parts are there and none got damaged during shipping.
HDFury2 Basic kit:
-HDFury2 dongle
-5v power supply
-USB to power cable
-6" RGB cable (either VGA to VGA, VGA to 9pin or VGA to 5 BNC )
-6" VGA to 3 RCA cable
HDFury2 Advanced kit:
-HDfury2 dongle
-GammaX dongle
-2 pieces 5 volt power supply's
-2 pieces USB to power cables
-3, 6" RGB cables, 1 VGA to VGA, 1 VGA to 9pin, 1 VGA to 5 BNC
-1 piece, 6" VGA to 3 RCA component cable
-HDMI to HDMI 6' cable
-Mini S/PDIF to standard S/PDIF optical audio cable
1-2. What's included with your HDfury2?
Absolutely everything you need is included. You won't need to find any of the expensive extras to get up and running. Our kits include:
Component Extender Cable: For displays with standard RCA female component (YUV/YPbPr) input. Included with every order.
RGB Extender Cable: For displays with an RGB input. The Basic Kit gives you a choice of one of three RGB cables, the Advanced Kit includes all three (useful if you may need more than one or don't know which to order):
1. BLUE (VGA to VGA male cable): For displays with a standard female HD15 VGA connector. Used by most displays with an RGBHV/VGA input.
2. GREEN (VGA to 5-BNC male cable): For displays with 5-BNC input connectors. Used by most professional displays with an RGBHV input.
3. RED (VGA to Barco Port 3 cable): For Barco CRT projector Port 3 DB9 inputs. More info on Barco Port 3.
If your display only has component inputs you will not use the RGB Cable so it doesn't matter which you order. If your display has 5 RCA style connectors order the GREEN cable and use five BNC to RCA adapters (sold separately).
Power Supply (wall plug): Available in US, Euro, and UK configurations. A power supply is included with all our kits as most source devices do not supply adequate power to run the HDfury2. The Advanced Kit also includes a power supply for the GammaX.
6' USB 5V cable: An extra cable that can be used to supply power to the HDfury2 from any USB port if using the regular power supply is not convenient. (Useful if the HDfury2 is used with a PC or PS3).
(ADVANCED KIT ONLY) GammaX converter: On most TVs and projectors, movies and games are too dark or missing detail in dark scenes. Gamma-X to fixes this by adding a 'Gamma Boost' without washing out the picture. Simply plug the Gamma-X directly into the HDfury2, HDfury, HDfury Gamer Edition, or any device with RGB output and enjoy a more vibrant picture with perfect shadow details!
(ADVANCED KIT ONLY) 6' HDMI cable: For connecting your source device to the HDfury2.
(ADVANCED KIT ONLY) Optical audio cable: A mini-Toslink to regular Toslink/SPDIF (fiber optic) cable for connecting the HDfury2 sound output to your TV if you don't have a receiver/pre-amp.
Chapter 2
2-1. HDFury2 Specifications:
INPUT: Digital HDMI 19 pin FEMALE Port (100% digital)
OUTPUT: Analog RGBHV or Component (YPbPr/YCbCr) via HD-15 D-Sub (VGA style) MALE connector. Adaptor cables for Component and RGB included in every kit.
Supports *ANY* resolution and refresh rate in RGB mode up to 1920x1080 at 60Hz. Includes all of the popular HDTV resolutions including: 480i/480p/576i/576p/720p/1080i/1080p48/50/60
Supports the following HDTV resolutions in component mode: 480i/480p/576i/576p/720p/1080i/1080p48/50/60 compatible
User Selectable RGBHV / Component (YPbPr/YCbCr) output with a side switch
A HDMI -> HDMI cable is used to connect to an HDMI source
RGB 4:4:4 (8 bits) digital input
YCbCr 4:4:4 or 4:2:2 digital input
Compatible with non-HDCP (DVI-D) or HDCP sources
Compatible with most any RGB Display
Compatible with most any YUV Display
Directly connects to a display's VGA (RGB) 15 pin D-sub input
Directly connects to a display's Component (YPbPr/YCbCr) input using included breakout cable
can also be extended up to 35 feet.
Screen position adjustable through Firmware and Custom Profile ( RGB only )
11bit 200MHz data processing
Triple 11bit 200Mhz video DAC
RGB-H/V Male Port D-SUB 15 Output video analog signals (0.7Vpp (RGB) / 1Vpp (YPbPr) over 75 ohms impedance)
Ultra short internal Analog links (<1 cm) on the HDfury2 for optimal quality
HDMI video bandwidth: 25-165MHz (Single link)
HDMI Data Rate - Bandwidth 1.5 Gbit/sec (Single link)
Supports all HD/SDTV formats from 1080p down to 480i
HDTV ready (480i/480p/576i/576p/720p/1080i/1080p48/50/60 compatible)
DVI 1.0 compliant
HDMI 1.1 and 1.2 ready
HDMI 1.3 interoperable
HDCP compatible with embedded keys loaded
HDCP ready
Reprogrammable Firmware (with specialized tools)
Accepts third party accessories on output such as the GAMMA-X (Gamma Correction)
Automatic Input Format Detection: Digital YCbCr and RGBHV
Full dynamic range for all input modes to maximize the level of detail
Automatically switches color-spaces for both HDTV (Rec.709) and SDTV (Rec.601)
Precise black levels - no black crush in any standard mode
Stereo High-Quality Analog Audio Output
Stereo High-Quality Digital/Optical Audio Output (S/PDIF format)
HD-DVD, Blu-Ray Disc and upscalling DVD player compatible
Playstation3 and Xbox360 compatible
Satellite and Cable set-top box compatible for HDTV
HDMI or DVI-D video graphics card compatible
Energy management : DVI and VESA DPMS compatible
Ultra low power consumption in Standby (3,5mA)
Maximum power : 0.37A under 5V (at 1080p/60)
On-board DC/DC converter (1.8V) with extra-low EMI signature
Power +5V from DVI/HDMI
Blue LED to display active digital link and power status
Small size : 75x56mm cabinet
100% ROHS compliant (Restriction of Hazardous Substances Directive)
Installation: The HDfury2 module may be DIRECTLY screwed to the back of the display into the VGA SUB-D plug or connected with extension cable.
HDCP rules compliant: No end-user access to decrypted analog video. Once screwed, this module becomes "a part of the display itself".
Professional factory made (mass-production) using pick/place and reflow/wave solder pro equipment.
Gold Plated connectors, tracks and material
Full aluminium case with thermal dissipation
Optional +5v input and power supply
EDID detective feature: EDID eprom can be reprogrammed using a computer through the graphics card (feature
reserved for professionals)
Internal EDID EEPROM with complete CEA861 extension block
One year warranty
2-1.
RGB/YUV switch
The RGB and YUV switch controls the output signal type on the HD15 (VGA) analog connector of the HDFury2.
RGB:
RGB is Red, Green, Blue + Horizontal and Vertical sync.
In the RGB setting you can use this with VGA inputs ( as long as they are set to RGB or PC ) and you can also use the VGA to 5 BNC breakout cable available in the HDFury2 kit. Using this cable you can get RGBHV or RGBS. The HDFury2 does not support RGB sync on green (SYOG). For that application we recommend an external RGBHV to RGB-SYOG box.
Please note. Some VGA/HD15 pin inputs on displays will not support the full resolution of the display. Many older displays were 640x480 only on the VGA input. Check your owners manual for details on signal types your HD15 inputs can accept.
YUV:
YUV is also known as component or YPbPr. They are just different names for the same thing. Set the side switch to YUV if you need a Component output signal from the HDFury2. This is compatible with TV's and projectors with YUV/YPbPr/component inputs and will usually be used in conjunction with the VGA to 3 RCA cable included in your HDFury2 kit.
If you have a projector or TV that can handle YPbPr over an HD15 pin input you may plug the HDfury2 directly into the input, or use the 'blue' edition RGB VGA to VGA extension cable if your display's input jack is in a position where you can't plug the HDFury2 in directly. You may need to go into the menu of the TV or projector to set the HD15 pin input to YPbPr in order to get a picture.
If you are getting an all green screen with picture from the HDFury2 when hooked up to your display make sure the RGB/YUV swithc is in the proper position for the signal type you require.
Chapter 3
3-1. Layout:
3-2. Hooking it up:
The HDfury2 can be hooked up in a few different ways. Below are some typical examples:
1./Component
Component connections come in two common types. RCA/Phono jacks or BNC jacks.
Depending on what type of input your display has you will either need to use the VGA to 3 RCA cable or the VGA to 5 BNC cable, just using the 3 red, green and blue BNC connectors.
Set the side switch on the HDfury2 to YUV - this is component. Connect the Green wire to the Y jack, the Blue wire to the Pb jack and the Red wire to the Pr jack.:
RCA/Phono jacks:
BNC style jacks:
Please note. For high def you will be looking for the jacks labeled Y Pb and Pr. Not the ones labeled Y Cb Cr. Although as in the BNC case above, sometimes the jacks will do both types of signals.
2./VGA/RGB
HDFury2 to RGB input on TV or monitor.
Here is the HDFury2 connected to a PC computer monitor via the 6" VGA to VGA extender cable. Direct connection, will aslo work depending on the phsical space situation. In this case the extansion cable made the connection easier:
Set the side switch on the HDFury2 to RGB
HD15/VGA input
3./BNC/RGBHV
HDFury2 to RGBHV using the GREEN edtion extender cable. VGA to 5 BNC/RGBHV.
5BNC connections are common on many professional monitors and projectors. Here you see the HDFury2 hooked up to a RGBHV input.
Set the side switch on the HDfury2 to RGB.
4./BNC/RGBS
HDFury2 can also be utilised with the RGBS inputs on monitors and projectors. A simple BNC "T" fitting is all that's required to connect using the 5BNC cable. You T the black and white sync cables together.
5./VGA/YPbPr
HDFury2 can be connected to projectors that have a 15 pin VGA input jack that has a combination of inputs. Some projectors use this jack for RGBHV and YPbPr input.
You can either connect the HDFury2 directly to the input or use the 6" VGA to VGA extension cable.
Side switch on HDFury2 set to YUV for component/YPbPr and RGB for RGBHV.
HDFury2 can be connected to Barco projectors that have a 9 pin (DE9) interface. This uses the RED eidtion VGA to 9 pin cable supplied when ordered with your kit.
HDFury2 works in conjunction with the Box1020 and Box1040 from X-vue products. These two boxes offer an HD15 VGA port input. The HDFury2 must be set to RGB on the side switch when hooked up to the Box1020/1040 products.
HDFury2's advanced kit comes with the GammaX RGB gamma booster dongle. The HDFury2 plugs into the bottom ( wider end ) of the GammaX. The HDFury2 and GammaX may be powered from one power supply however we recommend using
both power supply units for the best possible picture.
The GammaX can be used in a couple different ways. The two main ones are:
a./ Connected directly to the male output of the HDFury2
b./ Connected after a switcher ( e.g. From the output of the Sony PC1271.switcher--->into.GammaX--->out to display )
Many of the Mitsubishi rear projection TV's have 1080i inputs over RGBHV. Please try your HDFury2 to see if you get a picture on this input. If you do not get a picture this input may need to be enabled in the service menu.
Please contact HomeTheaterExperts@curtpalme.com for further instructions
10./ Sony/Barco/NEC input switchers: ( Sony PC1271 shown )
The HDFury2 can be keep at the equipment end of things as well. If you already have an existing switch for your video your HDFury2 can be plugged into it either with RGBHV cables ( shown ) or 3 RCA YPbPr/component ( not shown )
3-3. Long analog cable runs
Please note, longer cable runs are permissable on the analog output side of the HDfury2. It includes an analog video driver stage that will drive either RGBHV or Component signals to approximately 35 feet. For longer cable runs than 35 feet the GammaX or other output driver device must be used. The GammaX in the Advanced kit is rated to drive analog signals to 50+ feet. Only for RGB output not component.
3-4.Long HDMI cable runs
The quality of the HDMI cable you use becomes more important the longer the cable runs and the higher the resolution you are trying to use. For instance, an inexpensive 6 foot HDMI cable will be fine in most cases even up to 1080p. However if you use a long bargain brand HDMI cable you may see signal dropouts, sparklies or even get no picture at all. The other phenomenon with HDMI cables over long runs is the ability to use lower resolutions or scan rates and get a picture but when you turn up the resolution to full 1080p you can not get a signal.
We recommend Bluejeans cables for longer cable runs.
3-5. Hooking your HDFury2 to an M1 cable.
For users with M1 connections on their projectors. The M1 RGB cable will not, in most cases allow the projector to see a component video signal. You will need to purchase a component to M1 adaptor for your projector from the manufacture, if you need to input Component/YUV/YPbPb signals. ( sold seperatly )
For RGB input you can connect the HDfury2 to your M1 cables VGA input.
3-6.
Please note: We recommend the power supply unit be used in every instance. The only two devices known to reliably power the HDFury2 without the power supply unit are the Xbox360 and the Sony PS3. The blue light in the HDfury2's window will only glow when an HDMI link has been established. Just plugging the power supply into the side of the HDFury2 will NOT cause the light to light. Likewise just plugging the HDMI cable into the HDFury2 may not cause the light to come on and stay lit or may not light the blue light in the HDfury2's window at all without the power supply plugged in.
The included power supply is of a 2 piece design. The power brick itself has a USB port on it. The power cable has a USB plug on one end and the plug for the HDFury2 on the other. You may power the HDFury2 from an available USB port. You may also power the GammaX the same way.
There are other ways to hook up your HDFury2. If you have any connection issues please email us at HomeTheaterExperts@curtpalme.com
__________________________________________________________________________________________________
3-7. Colour Depth Upscaling:
HDfury2 accepts both digital RGB and component (YCbCr) video over HDMI and automatically processes both correctly for zero loss of dynamic range. HDfury2 takes this HDMI standard 16-235 data and cleverly scales it to a fully maximized output dynamic range (0-255) before sending it out to the final DAC conversion stage. The result is a more colorfull and dynamic picture.
Image Centering Circuit in component mode:
Another world first! HDfury2 is the only device that recreates the sync and timing alignment completely and therefore perfectly centers the image according to the SMPTE standards in all component modes (when set to RGB output the signal is simply passed through unchanged). This is a major difference in the architecture. No other converter can compete against recreating the syncs completely.
Technical details: RGB as defined by CEA861A/B/C/D specification defines the leading edge of HSyncs at different locations than the SMPTE/ITU standard does for component (YPbPr). This is why ALL but one direct RGB to component converters fail to correctly center the picture. Others disregard time-domain correction placing the image too far "left" on the screen. This is the reason why people using the original HDfury coupled with a typical stand alone converter fail even though the original HDfury is not doing anything "incorrectly". It simply passes information which will be interpreted incorrectly by many TVs. As well, while less important (but still missing from other converters), HDfury2 outputs tri-level syncs in all HD modes as required by standards. Again, no standalone RGB-converter does this. We have never come across or heard from a customer of a TV that requires tri level sync but still it's nice to meet the spec and be able to claim compliance.
____________________________________________________________________________________________________
Chapter 4
4-1. HDFury2 Frequently Asked Questions (FAQ's)
Why do i need HD (720p) or Full HD (1080p)?
Blu-Ray players, HDMI graphic cards, PS3, Xbox 360 Elite are all able to unleash their true potential (720p/1080p mode) only through the HDMI output. If you want a valid ticket to the Full HD world you either need a compatible display (with HDMI input) or an HDfury2 for your existing display. 1080p FULLHD as found on Blu-ray and HD has over 6 times the resolution as standard DVD and TV. For the best movie and and home theater experience, you *need* Blu-ray/HD.
Why do i need a HDCP compliant display?
HDMI is a new standard that comes with a form of hardware protection called HDCP. If your display doesn't have a HDMI input you won't be able to display 720p/1080p signal on it (from HDMI sources). Prior to exchanging Video data, the HDMI source exchanges HDCP keys with HDMI display. Both devices have a special HDCP chip embedded. If your display doesn't include an HDCP chip, even if it's technically able to display 720p or 1080p signal, it will display a BLACK SCREEN. On some devices (ex: Playstation3, Xbox360) 1080p mode is only available through the HDMI output!
Does the HDfury2 change the resolution? Upconvert or downcovert?
The HDfury2 does not change the resolution or refresh rate in any way. It converts the digital input signal to an analog RGBHV (VGA) or Component (YPbPr) signal. It also provides HDCP decryption if needed. The HDfury2 outputs whatever resolution you feed it.
What resolutions does the HDfury2 support?
The HDfury2 supports any resolution/refresh rate combination (interlaced or progressive) up to 1080p/60Hz. The only limitation is that your display must support the resolution/refresh rate as well.
I use component cables to connect my Blu-Ray or DVD player to my display device and it works just fine! Why do I need HDfury2?
Blu-Ray and many DVD players can also upconvert standard definition DVDs to higher resolutions (720p, 1080i, 1080p), but they only do this via the HDMI outputs (not component). So if you want to get the higher resolution benefits of your player's upconversion circuitry, you're forced to use HDMI. As well, in the future it may not be possible to pass certain high definition content over component video cables. A content flag called the ICT (Image Constraint Token) allows broadcasters and movie studios to limit or "down-res" the HD video signal to standard definition 480P resolution over component video cables. This is not something that has been activated yet, but it could be used at some point in the future. And the most important reason to use HDfury2: The picture quality is substantially better! (Sharper/cleaner/less noise/less ringing/etc). Talk to someone who uses one or read the reviews!
My display has composite (ie: combined) sync with only 4 BNC inputs not 5. (Examples: Barco 7xx/Cine7 or Ampro). What cable do I order? How do I hook it up?
Order the GREEN (5-BNC breakout cable) and combine the H/V sync lines using a $2 BNC T-connector like this. You could also use an Extron 109 or 202 box as well to combine the two sync lines.
My Barco requires negative sync to work. Does the HDfury2 output negative sync?
The HDfury2 does not alter the signal that it is fed in any way. If it is fed a negative sync signal, it will output a negative sync signal. If it is fed a positive sync signal, it will output a positive sync signal. You can use boxes from Extron or Altinex to invert the sync if required. To alter the sync to make it work with your projector, you can add an RTC2200 box or GammaX Gamma Boost product to your HDfury2 setup.
I have a scaler or doubler with DVI or HDMI inputs and an RGBHV output connected to my display device. I don't need an HDfury2 right? Incorrect. You still need the HDfury2 if you want to use HDMI sources such as Blu-Ray or DVD players that may have HDCP-protected content. The scaler, by law, is not allowed to output content via RGB if the source content is HDCP protected. The scaler will simply TURN OFF its analog RGB output. Only the digital DVI/HDMI outputs will remain on. To solve this, connect the HDfury2 to the DVI or HDMI output of your scaler, and then connect the HDfury2 to your display device. Simple!
I have a scaler or doubler with DVI or HDMI inputs and a DVI/HDMI output connected to my display device's DVI or HDMI input. I don't need an HDfury2 right?
Maybe. You still need the HDfury2 if you want to use HDMI sources such as Blu-Ray or DVD players that may have HDCP-protected content *and* your display device does not have an HDMI input. The scaler, by law, must pass the HDCP-protected content all the way to your display device. The display device must decrypt the content. If your display device only has a DVI input, it will not decode HDCP. To solve this, connect the HDfury2 to the DVI or HDMI output of your scaler, and then connect the HDfury2 to your display device. Simple!
I want to connect a longer cable to the output of the HDfury2. Can I do that?
Yes. The HDfury2 supports analog output cables up to 25-35 feet in length.
Does the HDfury2 support 24fps found in next generation Blu-Ray and HD DVD players?
Yes! While the HDfury1 does not, the HDfury2 does support 24fps. With cathodic displays such as CRT projectors or CRT based RPTVs or tube TVs, 24fps is too low of a frequency. The image will flicker like crazy and will not be watchable. You must turn off 24fps support in the source when using a CRT based display. You can however use 24fps on a plasma or LCD display and it will be displayed nicely using the HDfury2!
Note however that that most displays that do not have HDMI inputs do not work at 24 Hz however. Make sure to set your source devices to 50 or 60 Hz output and not 24 frames (Hz) or "Automatic".
My display only has component (YPbPr) inputs. Does the HDfury2 support component output?
Yes! Unlike the original HDfury, HDfury2 has a user selectable Component (YPbPr) or VGA (RGBHV) output to ensure that it will work with any display device.
Will the HDfury2 shift the image to the left or cropped (cut off) in any way like some other converters?
No. Unlike some of the other converters, the HDfury2 includes advanced features to ensure that at all display resolutions, the image stays perfectly centered (in component mode) and not cropped in any way for any display device.
In RGB mode the image is passed directly through so make sure your display has image shifting controls if RGB is to be used.
My projector or display device has a 3-prong power cable with a ground [earth] pin. I've bypassed the the ground pin. Is this a problem?
YES! Not only is this very dangerous to you (the homeowner) you may damage your HDfury2 and/or your display. Your HDfury2 warranty is null and void if you bypass the grounding of your display device. Please do not do this! Bypassing ground pins because of ground loop problems, hum problems, or other reasons is very dangerous and only masks the problem. You need to fix the source of the problem. The ground pin is there for your safety and for the safety of your equipment.
I need an HDMI cable. Can you recommend one?
Blue Jeans Cable make good quality thicker HDMI cables with good shielding (for less loss over long runs).
I can only get lower resolutions to work. When I set my source to high resolutions like 1080p I don't get an image!
(1) Your source device likely doesn't provide enough power to the HDfury2. Make sure to use the included HDfury2 power supply and ensure that your display supports 1080p FULLHD if you want to use 1080p.
(2) Many TVs do not support 1080p and must be fed a 1080i signal instead. Make sure to set your source to 1080i unless your display's manual specifically states that it supports 1080p. Please note. On some flat panel displays sold in PAL territories the panel will sync to 576p ( line doubled/progressive PAL resolution ) but nothing higher. Some of the manufacturers did not include support for the 50Hz signals used in PAL countries beyond 576P. So while 720p60Hz will work 720p50Hz will not. Likewise 1080i60Hz will work but 1080i50Hz will not. This is a limitation of the flat panel display and not the HDFury2
The picture is blank! I don't get an image at all from my PS3, Blu-ray player, or other source!
(1) Make sure your display supports the resolution the source is feeding it. If your TV does not support 1080p, set your sources to 1080i. Some sources will automatically use the highest resolution available to them based on what they see connected, and since they see the HDfury2 which supports 1080p FULL HD, the source will 'think' you have a 1080p capable TV and is most likely feeding the HDfury2 a 1080p signal. You need to lower this to 1080i in the source device.
(2) Make sure that the 24fps output option in the source device is set to OFF or DISABLED and not AUTOMATIC unless your TV specifically supports 24fps. Most do not, especially older TVs that do not have HDMI inputs.
(3) Make sure you're using the HDfury2 power supply.
I'm still getting a black screen from my PS3 when using the HDfury2. How can I fix this?
The problem is that you likely connected the HDfury2 to the HDMI port while the PS3 was still setup to output by another port (component or composite). The result is no picture over HDMI. The PS3 will output low resolution on every output when you reset the display settings this way: PS3 in stand by mode, hold on power for 5 sec until you heard 3 beeps.
The PS3 restarts and you can than access low resolution through both HDMI and/or other ports and perform the display test to choose your preferred resolution.
On my PS3 I can see the menu, play games and blu-ray discs, but I get a blank screen or an out of range error message when I play a DVD
You need to change a setting in your PS3: In addition to setting up the HDMI resolution on the PS3 as outlined above, you also have to go under the Blu-Ray playback settings and adjust the DVD upscale feature because by default it will also be 1080p. Another hint: When you first connect an HDfury device to the PS3 (such as the original HDfury, HDfury Gamer Edition, or the HDFury2) the PS3 will ask: "A new HDMI device has been detected, do you want to use it?" Answer 'YES' ONLY if your TV is 1080p capable. Otherwise answer 'NO', and you will be presented with another screen where you will be able to change the resolution settings and set them manually to whatever your TV supports.
My Sony G90 CRT projector looks funny when I use the HDfury2
Go into the G90 service menu "Input Setting" with the fury installed and set the "Clamp" to HP or H/C from auto. This should straighten out the picture if it is varying in brightness and getting weird bands of dark as scenes change.
My picture 'blanks out' from time to time when using the HDfury2. Why is this happening?
Some of the very early HDfury2 units had a defect and these units were replaced. To determine if the issue is with the HDfury2 or elsewhere, use the following logic:
- If the HDfury2 blue LED is OFF during the picture blanking, the problem is with the HDfury2 or the power supply. We will replace them for you.
- If the HDfury2 blue LED is ON during the picture blanking, the problem is with the the component (YUV) cable, RGB cable or the display.
My picture is all green! What's going on?
You likely have a display that only accepts RGB and you have the switch on the side of the HDfury2 set to component output (YUV). Switch it to RGB.
What sort of power supply does the HDfury2 use? When is it needed?
While the HDfury2 can draw power from the HDMI line, our experience has been that most devices simply do not supply enough power so an external power supply is needed. This is why all of the CurtPalme.com HDfury2 kits come with a power supply by default. An extra power supply for the HDfury2 may be ordered on the HDfury2 order page. If you want to source your own, the power supply must adhere to these requirements:
- Provide REGULATED (+/- 5%) 5VDC power with 0.5A min DC current
- Deliver the power through a small 0.65mm diameter center pin / 2.6mm outer diameter DC plug (like the one often used in cellular phone AC adaptor)
- Provide the correct polarity with 'plus' on the OUTER part of the plug and 'minus' (ground) on the small center pin of the DC jack.
Trying to use an AC/DC adaptor that doesn't adhere to these three requirements may destroy the HDFury2.
Why don't all HDMI source devices provide enough power to run the HDfury2 properly?
At maximum resolution (1080p/60Hz) the HDFury2 requires 370mA of current to function correctly (more if the GammaX is also used in conjunction with the HDfury2). The HDfury2 can be powered by the HDMI cable, however the HDMI standard states that it HDMI should provide 'at least 50mA and at max 500mA'. This means the manufacturers are not required to provide more than 50mA of current on their HDMI outputs which is not enough to power the HDfury2. Less current means cheaper manufacturing costs which means that 99% of manufacturers opt to just meet the requirement of 50mA. Therefore most sources are close to the lower end at 50mA and very few are near the upper end at 500mA (PS3/Xbox360). This is why it is always recommended that the HDfury2 power supply by used in all setups other than when running directly from a PS3 or Xbox360. This is why all CurtPalme.com HDfury2 kits come with the much needed power supply.
The HDfury1, HDfury2, and GammaX power supplies all look the same. Are they interchangeable?
Yes. The power supply shipped with our HDfury1, HDfury2, and GammaX kits are all the same.
I couldn't get the original HDfury1 to work with my Dell 2405FPW display because the Dell doesn't like HD resolutions. Will the HDfury2 work?
Yes. The HDfury2 supports the Dell 2405FPW display up to 1080i as long as you use the component input. 1080i is also 1920x1080 resolution just like 1080p so your are sending your TV a Full-HD resolution.
My display is RGB only (no component input) and I don't have any image adjustments to compensate for image shifting. What can I do?
Do have an RGB only display and are experiencing image shifting and can't compensate with your display adjustment? Your solution is to set the HDfury2 to component output and plug it into a Box1040 or leave the HDFury2 in RGB mode and use the Box1020. Both will provide image alignment along with other features such as a cable driver, gamma boost, and switching.
My picture is blank when I play back Blu-ray discs but not when I play DVDs. What's going on??
Blu-ray discs are natively 1080p/24Hz. You likely have your Blu-ray player set to 24Hz or "Automatic" frame rate output so that it is outputting a 24 Hz (fps) signal. Most displays that do not have HDMI inputs do not work at 24 Hz so you need to turn this off. Either set your Blu-ray player to 50 or 60Hz or set 'Automatic Frame Rate' to off. See your Blu-ray manual.
How do I hook up the audio from the HDfury2? Do I really need it?
The HDfury2 supports 2 channel audio up to 192Khz sampling rate per channel. The HDFury2 does not support 5.1 or 7.1 sound output from the HDFury2. The audio output of the HDfury2 is only meant as a convenience feature if you do not have a home theater receiver or preamp with separate speakers. If all you have are the speakers in your TV you can use the 2-channel audio output of the HDfury2 as a covenient way to feed audio directly into your TV without having to run an extra set of long cables to your TV. Anyone with a home theater receiver/pre-amp and separate speakers should instead connect their source devices directly to the receiver/pre-amp and not use the HDfury2 sound output. There is no need to use the audio features of the HDfury2 with a home theater setup.
NOTE: Please connect directly to your souround sound system from your sources to get 5.1 or 7.1 sound. The primary use of the sound output of the HDfury2 is to provide sound to the inputs of a television set directly.
The audio output of the HDfury2 gets all distorted after a while. What's wrong?
The HDfury2 only supports 2 channel audio up to 192Khz sampling rate per channel. You've got the sound output set to multi-channel (more than 2) on your source device. While passing more channels may seem to work the sound will get distorted after a while. For multi-channel home theater setups connect your source devices directly to your receiver or pre-amp (see previous question).
My screen's all green!
Check the RGB/YUV switch. If you are plugged into the component inputs you should be set to YUV. If you are running into an RGBHV or RGBS input with the H+V lines T'd together you need to set the switch to RGB. If your screen is still green after the switch, unplug the HDMI cable and plug it back in, give it about 10 seconds. You can also flip the YUV/RGB switch back and forth a few times to make sure you are getting a good contact on the switch.
Chapter 5
5-1. Audio output
You will need either a 3.5mm (1/8") stereo to 2 RCA analog audio cable
OR
a mini SPDI/F to standard SPDI/F optical audio cable to hook your sound from the HDFury2 to your TV or Receiver.
The audio output of the HDFury2 is two channel only. This is the two front L+R suround channels. The HDFury2 does not do audio mix down to stereo audio.
We recommend connecting your sources to a sound receiver directly for sound. The audio output is intended mainly for people that want to hook sound up to their TV's.
Please see section 4-1 FAQ's for more details on audio
Chapter 6
6-1. GammaX
The GammaX add on dongle, included in the HDFury2 Advanced kit, or available separately, provides you with a method to boost the low level gamma ( shadow details ) to your display when the HDFury2 is running in RGB mode ONLY.
6-2.
NOTE:
The GammaX does not support YUV/YPrPb/Component mode.
The GammaX may be powered by the HDFury2's power supply when plugged into the HDFury2 directly but we recommend using both power supply units, one for the HDFury2 and one for the GammaX for the best picture quality.
6-3.
Hooking up your GammaX:
The GammaX plugs directly into the VGA HD15 male output of the HDFury2. Once attached the thumbscrews should be tightened to ensure a good connection.
6-4.
Adjusting your GammaX.
Adjustment for the GammaX is done via the slider on the front of the unit.
The Gamma slider should be set to a point where the shadow details are just becoming apparent. If you set it too high you will notice the whole of the picture brightening up and the black level will shift towards grey.
Once you have the gamma adjusted you can go into the menu on your TV/Monitor/projector and adjust the brightness. You may find a couple of clicks darker looks better. You can experiment with the GammaX's slider and the brightness control on your display to tweak the best looking picture for your display.
6-5.
INV and PASS switch
This switch is uses to invert the sync of the incoming signal. For example: If your Bluray player is sending a positive sync signal and your projector needs negative sync ( as most Barco and Dwin projectors do ) then you would flip the side switch on the GammaX to "INV".
Likewise if you have a negative sync signal coming into the GammaX and you want positive you can flip the side switich to "INV"
If the side switch is set to "PASS" the GammaX will pass the sync signal through unaltered. If a positive sync signal is sent to the GammaX with the side switch set to "PASS" then the sync will be positive
If a negative sync signal is sent to the GammaX with the switch set to "PASS" the sync signal will be negative. You can not lock the signal sync to one or the other. Only invert it with the GammaX
Post new topic   This topic is locked: you cannot edit posts or make replies.   Printer-friendly view    CurtPalme.com Forum Index -> HDfury Products All times are GMT
