NOW
SHIPPING!
The
new version 3 card adds HDMI 1.4 and Radiance 3D support as well as other
improvements. See the
manual for full details.
VOLUME
DISCOUNTS AVAILABLE:
5% off 5, 10% off 10, 15% off 20+.
Contact Us for special orders.
Sony
IFB-FULLHD v3 HDMI 1.4 Input Card with 3D & remote
Use in Sony CRT projectors except the
VPH-D50HTU |
Regular price: $410 USD
Our
price: $359 USD
YOU SAVE $51!
Sony
IFB-FULLHD v3 HDMI 1.4 Input Card with 3D, remote, and HTU adapter
Use in the Sony
VPH-D50HTU CRT projector |
Regular price: $499 USD
Our
price: $369 USD
YOU SAVE $130!
HTU adapter
Allows the IFB-FULLHD card to be used in the Sony
Our price: $89 USD
PREVIOUS VERSION / ONLY 3 LEFT:
Sony
IFB-FULLHD v2 HDMI 1.3 Input Card with remote |
Clearance price: $310USD
YOU SAVE $100!
Sign up
todayshtm">Sign up
today to receive the latest IFB-FULLHD news!
Free priority
shipping to anywhere in the world included!
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor
will automatically convert the
amount to
your local currency.
Orders ship direct from the
manufacturer in Taiwan.
Warranty: 1 year all parts and labour.
Upgrade your Sony CRT projector by adding
two HDMI 1.4 inputs with 3D support, gamma correction and infrared remote control!
Don't be stuck watching PS3, Blu-ray, HD-DVD, and DVD at only
480p! Add digital HDCP-compliant HDMI 1.4 inputs allowing you to watch hi-def
content at up to 1080p resolution!
Widescreen
Review Magazine uses Moome HDMI cards in their reference theaters featuring Sony
G90 and Runco 1200 CRT projectors. "We love our 9-inch CRT projectors,
even though we have our pick of the leading edge D-ILA, SXRD, and DLP
projectors." - Gary Reber, Editor-in-Chief and Publisher, Widescreen Review
The IFB-FULLHD card allows you easily add digital devices such as
Blu-Ray players, PS3, Xbox360, Satellite/Cable HDTV set-top boxes, and HTPCs with HDMI graphic cards (to name a few) to your
Sony CRT projector. Simply plug the card into your projector, your DVI/HDMI
devices into the card, and watch!
How does the 3D
work? When used together with a
Radiance video processor, the IFB-FULLHD v3 HDMI
card allows 3D movies, games, and other content to be viewed on your Sony CRT
projector. The Radiance does the processing to convert the 3D signal into
something your Sony CRT projector can understand and display, while the
IFB-FULLHD v3 HDMI card interfaces with and controls your 3D glasses. Enjoy 3D
at 720p120Hz or even at custom resolutions like 1080p75Hz.
The
Optoma 3D-XL or
Viewsonic VP3D1 3D video processors have also been tested with this HDMI
card. Unlike the Radiance however, the output resolution is fixed at 720p120Hz.
Any
Infrared (IR)
Active Shutter glasses or Radio Frequency
(RF) Active Shutter glasses that include an
emitter will work with the IFB-FULLHD v3 card as long as the emitter has
the standard 3-pin DIN connector.
Overview This product is a culmination of everything Moome has learnt
over years of building DVI/HDMI input cards for CRT projectors. It is by far the
highest end Sony card he has yet to offer with new features such as: Two 100%
HDMI
1.4 compliant inputs for Radiance 3D support (3D
glasses & emitter sold separately), Deep Colour support, better discrete 14bit D/A converters,
faster 1GHz
output buffer, and better op-amps for the best image quality possible!
Supply is limited and tends to sell out fast as this high-end
product for the discriminating videophile is only built in small batches.
This is the last HDMI input card you will ever buy for your Sony CRT projector!
Works with any Sony CRT projector, TV, or other product with an
IFB slot. This includes:
Sony VPH-1251, 1252, 1270, 1271, 1272, 1292 CRT projectors
Sony VPH-G70, VPH-G90 CRT projectors
Sony VPH-D50 CRT projectors (not all have IFB
slots - see below)
Sony PC-1270, 1271(M), 3000 switchers
Sony RVP-6010Q Rear projection TVs
Some Sony CRT projectors (most notably the Sony VPH-D50HTU) do not have an
IFB slot. The HTU adapter must be used in order to plug in the IFB-FULLHD board.
The HTU adapter board will also work with all earlier DVI/HDMI Sony cards by
Moome.
How can I tell if my Sony D50 has an IFB slot?
Unlike the other CRT projectors mentioned above, not all Sony D50 CRT projectors
have IFB slots.
The easiest way to tell is to simply look at the rear of your Sony D50 for a
slot that looks like the following:
In this picture the IFB slot is taken up by the remote
card. This (useless) remote card is removed via the two turn screws to allow the installation of the
IFB-FULLHD card. Other D50 projectors may have a blank faceplate instead that
can be removed in the same manner. If a card
is already installed in the slot but you have nothing connected to it, it may be
safely removed allowing the installation of the IFB-FULLHD card.
Typically the UK version of the Sony D50HT does not have an IFB
slot while other versions of the D50HT and all versions of the D50Q and D50GM do have IFB slots.
It's always best to check your model to make sure you have a slot so that you
know if the HTU adapter is required.
Manuals
IFB-FULLHD v3 owners manual
(PDF format)
HTU adapter information sheet (PDF format)
How does the version 3 card compare to the older version 2 card?
Complete information on the changes can be found in the
manual (see above). Below is a quick summary:
Feature |
IFB-FULLHD v2 |
IFB-FULLHD v3 |
HDMI version |
HDMI 1.3 |
HDMI
1.4 |
3D support with sync output |
Yes |
Radiance sync support
(The Radiance can control the 3D sync timing on the card's 3-pin DIN
connector instead of the card) |
Yes
- Via Input 1 |
Gamma |
Improved Gamma for
more linear greyscale (changes suggested by Walter/WTS) |
Even
more advanced Opamp |
Sharpness |
Sharper Image (changes
suggested by Mike Parker) |
Even
Picture purity |
Cleaner/Less noise
(changes suggested by Mike Parker) |
Even
more advanced Opamp and new analog power supply design |
Range expansion |
Yes. Supports 0-255 RGB
level support for higher dynamic range (in addition to 16-235) |
Stability |
ESD enhanced to
prevent electrostatic discharge |
ESD enhanced to
Black boost |
Supported |
Supported |
Able to manually select colour space
with remote |
Supported |
Supported |
Sync polarity adjustment |
Yes |
Optional horizontal image shift |
Yes |
Features
Two HDMI 1.4 inputs. HDMI 1.0, 1.1, 1.2, 1.3,
1.4, HDCP 1.1, and DVI 1.0 compliant
14bit Data processing with three high precision 250MHz 14bit DACs
(previously 200Mhz)
for conversion to analog RGB
High speed 1.65GHz output Buffer
(previously 1.5Ghz)
Supports deep color mode for 10bit and 12bit
DTV mode support (480P,576P,720P,1080i,1080p) at 50, 60, 72,
and 75Hz refresh rates for all resolutions.
Supports 120Hz at 720P and 1080i
PC mode support VGA, SVGA, XGA, SXGA, UXGA etc.
Supports 4:4:4 RGB / YCbCr input
Supports 4:2:2 YCbCr input
Supports both 16-235 and 0-255 color rangee
Advanced gamma boost for perfect shadow details and gamma
tracking
Adjustable white level (contrast) boost for output from 0.7V-1.0V for
perfectly matching a display's expected input voltage
IR control for input selection and gamma boost
adjustment
Ultra
low ESR capacitors to filter noise providing an extremely clean image.
ESD
improved to prevent electrostatic discharge damage while plugging in HDMI
cables
Pictures
The IFB-FULLHD v3 card installed in a Sony G90 CRT projector:
New high bandwidth video opamp:
New14 bit video DACs (x3):
Reviews/Testimonials
"Moome's original design squashed (attenuated) 65% of
the full bandwidth when running 1080p 60Hz. With Mike's new circuit, the FULLHD
v2 now can resolve the entire 1080p 60Hz signal. With Moome's new design his
card is the first and only option that can do full 1080p and YCbCr... the image
is amazing!" - Craig Rounds, official FULLHD v2 tester, professional
calibrator (www.cir-engineering.com)
"In a word - fantastic. I don't really have the vocabulary or
breadth of equipment knowledge to properly express what I am seeing. But the
card puts me in the studio with CNN, FOX, MSNBC. It puts me on the field with
the Cowboys. It puts me next to the telecine operators on "Ironman" and "The
Fifth Element" and "The Dark Knight" and "Casino Royal." I can not only see the
layers and outlines and overly-smooth makeup on broadcasters' faces, I can see
flakes of it trying to break away. Hair is wispy and delicate and multicolored
as it drifts away from faces. It's like a few breakthroughs I have
experienced in decades of audio - a real game changer... DO THIS, FOLKS!!!"
- Hlmiii "I received my card yesterday afternoon (Tuesday, 10/27/09). It was
installed to replace the prior version from last year, which was itself an
"upgrade" from Moome's first Sony card. Reference: (source) > Lumagen Radiance >
G-90 @ 1080p 60Hz. The new card is a definite and noticeable improvement.
The most obvious difference is the reduced noise - the existence of which wasn't
apparent until made (in)visible by the new card. Along with that is an image
with improved resolution and better-defined contrast transitions. My guess is
that these latter two improvements are due to faster step response (?). White -
black dynamic range is also increased. In short the card provides the
improvements as claimed in its product descriptions. I was hesitant to believe
and see improvement - and spend money yet again on the same general product. But
now having seen the results I am very happy with Moome's effort in reworking his
previous product and would definitely classify it as worth every penny.
Highly recommended. Thanks." - Hlmiii "Received my v2 card
yesterday and installed it right away inside my VPH-G90 projector after removing
the older IFB-FULLHD card from the B slot. I'm running an HTPC and the Oppo
BDP-83 Blu-ray player on a 3m wide 16:9 screen. Tested with the High Definition
Benchmark Blu-ray Disc from Spears and Munsil. I've used the low level test
patterns (with BTB information) and the improvement on video noise figure is
clearly seen." - JohnHWman
Need more information? See the Sony IFB-FULLHD FAQ!
Visit the Moome Discussion/Support Forum
Questions should be directed to the PJI-HD company (Moome) at:
moome@curtpalme.com
