Pick your location /
return shipping method:
Once your payment has been received, you will
be emailed with further instructions on how to remove your Low Voltage
Power Supply and the Arizona (USA) address to ship it to.
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor
will automatically convert the
amount to
your local currency.
Greatly reduce your Marquee, Vidikron Vision One/Two, or Madrigal CRT projector fan noise with
modifications designed by an acoustic engineer!
Customers of E-Tech Systems have mentioned that fan noise is distracting some
times, so an acoustic engineer was brought in and upgrades were developed to
greatly reduce fan noise without compromising projector reliability. Far too
many fan mods are simple untested 'hacks' that end up running the projector hotter
than it should, reducing lifespan. Here's how the E-Tech fan mod works:
The Marquee fan noise mod is done to your low voltage power
supply (LVPS), a ten pound metal box which is removable with a
screwdriver and sent to E-Tech Systems in Arizona (USA). Removal of the LVPS
takes 5 minutes.
See
here for instructions.
The mod employs two new high quality Papst 92mm fans and the strategic
application of acoustic foam material to dampen resonances in the sheet
metal.
The improvement is about 5-6db, with none of the metallic 'pepper
grinder' noise after.
Your LVPS is also tested remedied of the dreaded filament over-voltage
problem that is common to many LVPS's and can destroy a set of CRT tubes very quickly.
It takes E-Tech systems approximately 2-2.5 hours to apply
this modification to your LVPS and test the outcome.
Typical turnaround is 1-2 days.
This fan mod will help to increase the dynamic range of the audio portion of
your home theater. If you've already spent a considerable amount of time
and money tweaking the audio side of your home theater, you realize that a low
noise floor is an absolute requirement to maintain a high level of audio quality.
Less background noise results in a higher dynamic
range. This mod works on any projector
based on the Marquee chassis which includes: Marquee 7xxx/8xxx/9xxx,
Vidikron Vision One/Two, Madrigal MP8/MP9, Reference Imaging, Accurate Imaging,
and VDC series CRT projectors. E-Tech Systems in Scottsdale Arizona is the premier refurber of
the Marquee CRT projector chassis.
Similar fan mods for other makes and models is unfortunately not available at this
time.
Reviews/Testimonials
"I received the updated LVPS unit and I was able to install it first shot
like a charm. I could not believe how quiet this unit is. Usually, with the 9500
LC turned off it but the unit in standby it makes enough noise to prevent me
from listening to audio only in my room without turning off the circuit breaker.
Now, with the unit in standby, I cannot tell whether the circuit breaker is on
or off. I had to climb up on the ladder and place my ear next to the LVPS just
to be sure it was working. I Love IT! Very quiet. Now even with my projector
fully turned on, it is much quieter than before. Excellent. Thanks so very
much." - John Roberge
"E-Tech is one of the few CRT related companies who really do offer fast
turnaround times. Send in your LVPS today and you'll likely have it back within
just a few business days. I sent my LVPS to Tim at E-Tech for the fan/filament
mod. When I got it back, I immediately noticed how much quieter the fans were as
compared with before. And the P14 filament voltage was right at 6.3. I tested
the filament voltage again a year later (two weeks ago) and it was still sitting
right at 6.3. Good job, Tim!" - CZ Eddie
"I really recommend this fan mod. If you have a Marquee or similar PJ don't
hesitate to send your LVPS to Tim. He really is a great guy to do deal with. I
had no problem at all except that it was hard to live without the Marquee in the
turnaround period ( I live in Denmark so I have to live without the Marquee
running for about two weeks). BUT the noise reduction is no more that amazing.
Thank you Tim" - Henrik
"This is indeed a great mod. I've gotten a few off Tim over the years, and
while fan noise has never bothered me personally, I do have to check once in a
while in my own HT if the projector is on or off, the difference is THAT
dramatic between the modded LVPS and the original." - Curt Palme
More Information (Features, FAQ, Pictures,
Reviews)
Questions should be directed to the 3rd party seller (Tim
Martin) at: tim@curtpalme.com
When
purchasing you will be paying and
dealing directly with the third party
seller 'E-Tech Systems'.
This item is not sold or supported by
CurtPalme.com
DISCLAIMER: Any dealings with the third party seller/manufacturer listed here,
including the delivery of and the payment for goods and services, and any other
terms, conditions, warranties or representations associated with such dealings
or promotions, are solely between you and the third party seller/manufacturer.
Curtpalme.com shall not be responsible or liable for any part of any such
dealings or promotions.
CURTPALME.COM IS NOT THE SELLER OR MANUFACTURER OF THESE PRODUCTS OR SERVICES.
THE SELLER/MANUFACTURER MAY HAVE PROVIDED A WARRANTY ON THE GOOD(S) PURCHASED.
CURTPALME.COM HAS NOT MADE, AND DOES NOT MAKE, ANY REPRESENTATION, WARRANTY,
PROMISE OR COVENANT, EXPRESS OF IMPLIED, AS TO THE CONDITION, QUALITY,
DURABILITY, CAPABILITY, FUNCTION, PERFORMANCE, OR SUITABILITY OF THE EQUIPMENT,
ITS MERCHANTABILITY OR ITS FITNESS FOR ANY PARTICULAR PURPOSE. BUYER AGREES THAT
CURTPALME.COM SHALL NOT BE LIABLE FOR EITHER SPECIFIC PERFORMANCE OR ANY
LIABILITY, LOSS, TAMPERING, ABUSE, DAMAGE, INCLUDING CONSEQUENTIAL AND
INCIDENTAL DAMAGES, ARISING OUT OF BUYER'S PURCHASE OF THE EQUIPMENT, ANY
DEFECTS IN THE EQUIPMENT, OR FAILURE OF SELLER/MANUFACTURER TO TIMELY DELIVER
THE EQUIPMENT.
