FAQ: Colorimetry Research CR-100 Professional Colorimeter
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Posted: Fri Oct 03, 2014 5:06 pm    Post subject: FAQ: Colorimetry Research CR-100 Professional Colorimeter
Order today! GO »
Confused about meters? See our FAQ: Which meter is right for me?
There are two colour analyzers that professionals and dedicated enthusiasts generally seek: A professional quality colorimeter for every day work (the "field" meter) and a reference spectroradiometer to keep the colorimeter accurate (the "reference" meter).
Unfortunately, such devices are not cheap. The Photo Research and Minolta reference spectros start at about $15,000 USD and go up to near $30,000 USD. The Klein K-10a, previously the only professional quality colorimeter on the market, retails at $7,000 USD.
There is a new entry to the professional colorimeter on the market, the Colorimetry Research CR-100.
In our testing of the CR-100 we have found that it performs at least as well, and with respect at least to repeatability even better, than the Klein instrument. It does this at a significantly lower price point of $4995 USD.
The CR-100 is accurate enough to be used as a standalone color analyzer for professional applications. For the most demanding applications it can be profiled against a true reference spectroradiometer (such as the JETI 1211). Either way, its speed, low-light sensitivity, and repeatability are world-class.
The CR-100 is the most affordable professional colorimeter available. Just mount either on a tripod, facing towards the source, connect to ChromaPure Professional, and then use as you would any other color analyzer.
For complete details see our order page.
Order today! GO »
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
