FAQ: Which meter is right for me?
Posted: Mon Jun 30, 2008 12:15 am    Post subject: FAQ: Which meter is right for me?
Which Meter Is Right for Me?
This guide has moved here: https://www.curtpalme.com/ChromaPure_which_meter_is_right_for_me.shtm
Cheers!
Westmd
Posted: Sun Jan 27, 2013 1:58 pm    Post subject:
I read above that Spyders 1-3 are not advisable. How would you rate the Spyder 4 Elte as it seems to be calibrated?
Posted: Sun Jan 27, 2013 2:35 pm    Post subject:
Where did you read that the Spyder 4 is calibrated?
Westmd
Posted: Sun Jan 27, 2013 4:44 pm    Post subject:
I would understand the section under "Full-spectrum color sensor" in that way @ http://spyder.datacolor.com/portfolio-view/spyder4elite/
Ingo
Posted: Sun Jan 27, 2013 4:53 pm    Post subject:
Thanks for the link.
They say:
Spyder4ELITE's patented 7-color sensor improves upon colorimeters that use 3-channel RGB sensors. Each Spyder4ELITE unit is individually tuned in the factory to accurately handle a variety of wide-gamut and normal gamut displays with ease.
"Individually tuned" doesn't mean it's necessarily accurate but it certainly sounds like a step in the right direction. You'd have to get a bunch and compare them to the older Spyders to really know if they're indeed more accurate out of the box.
Westmd
Posted: Wed Jan 30, 2013 5:51 pm    Post subject:
Kal,
any verdict on XRite's Colormunki? From the sheet it looks very similar on a hardware basis? (Software is not needed as I will most likely will use Calman v5)
Ingo
Posted: Wed Jan 30, 2013 5:55 pm    Post subject:
I've never used the Colormunki. Sorry.
roozbeh007
Posted: Sat May 25, 2013 4:37 pm    Post subject:
Hello,
Can we use Minolta CA-210 with ChromaPure?
We want to calibrate Barco grayscale lcds and Barco recommends CA-210 as prefered measurement sensor. is it compatible with your software? Thanks.
Posted: Sat May 25, 2013 8:28 pm    Post subject:
roozbeh007 wrote:
Hello,
I do not believe so.
A complete list of supported meters is on our ChromaPure order page is here: http://www.curtpalme.com/ChromaPure.shtm
Only some of the newer Minolta's are listed. The Minolta CA-210 is discontinued (no longer available).
The CA-210 was first introduced in 1991. I'm not sure when it was discontinued, but given how old it is I'm sure much better meter technology is available for considerably less. Something that old too will be considerably inaccurate if purchased today.
Are you sure Barco recommends this even today? Do you know why? Maybe you're reading something that is 10-15 years old?
roozbeh007
Posted: Sat May 25, 2013 11:37 pm    Post subject:
Hello.
no, the guide is recent. unfortunately, I am not sure why.
I have three options with them. Minolta CA-100, Minolta CA-210 and Tektronix J17.
I think that was CA-100 that came out in early 90s. maybe I'm wrong. I'm not sure.
I will keep you posted if I can get more info from Barco.
I just purchased a Minolta CA-210 and should receive it within next few days. I will check it with ChromaPure to see if it works.
Posted: Sun May 26, 2013 1:20 am    Post subject:
Email us at Chromapure@Curtpalme.com and this'll go off the authors of the software and keep me in the loop. I'll update the order page if it is indeed supported.
If you are interested in purchasing ChromaPure, we are associated with them directly and offer it at a discounted price. Exact same software and same support, just more money in your pocket at the end of the day. See: http://www.curtpalme.com/ChromaPure.shtm
Posted: Thu Feb 18, 2016 3:17 pm    Post subject:
The Display 3 PRO / ChromaPure combo is still the meter/software combo I recommend for the average user. There are better meters (see the main thread above) but you're looking at a massive price difference for what most people would consider a marginal improvement. For complete details see the first post above.
Good luck!
Posted: Wed Dec 14, 2016 1:12 pm    Post subject:
One thing to keep in mind with very old colorimeters like the Minolta/Tektronix ones mentioned is that they're so old that they have most most likely drifted considerably. They should be tested with a known (good) colorimeter and offset tables created, assuming they're not completely out of whack. Often using a VERY old meter like this 'as is' will likely only make things worse than not calibrating at all. There's a reason really old meters like this are available for cheap or free.
Posted: Tue Sep 03, 2019 6:53 pm    Post subject:
Added information on the Datacolor SpyderX.
The new SpyderX is by far the best Spyder colorimeter Datacolor has ever offered. It provides massive improvements in speed and low-light sensitivity over previous Spyders. It's our new recommended budget meter for those who do not need to calibrate projectors and want a slightly lower cost option to the Display 3 PRO. If you have been interested in calibrating your own displays but have been deterred by the high cost of color meters and good software, this meter is for you. Professional quality results at a non-pro price.
We offer the SpyderX PRO which takes the regular SpyderX one step further and offers professional grade accuracy at a price affordable to the amateur hobbyist or enthusiast. Only available when used with ChromaPure.
For complete details on the performance of the new SpyderX and how it compares to other popular lower priced meters like the X-Rite i1Display Pro (Display 3) see our new SpyderX order page: http://www.curtpalme.com/ChromaPure_SpyderX.shtm
Questions? Email kal@curtpalme.com.
Cheers!
