thermal compound and heatsinks....
benareeno
Posted: Mon Feb 23, 2009 10:07 pm    Post subject: thermal compound and heatsinks....
Has anyone added this to the stk chips or any other hot running chips on their pj's? This may allow me to pursue my fan mod in a slightly safer manner...Couldn't find much in the search function, so I thought I'd get some discussion through this thread.
Posted: Mon Feb 23, 2009 10:15 pm    Post subject:
Do you mean adding heatsinks to things that dont have them or using compound on a device that already has a heatsink ?
A whole bunch of sets are affected by poor quality thermal compound. Some of the boards end up with hardened compound and I attribute that to causing failures on the board. If a chip is bad, I take it off, chip off all the hardened material, wipe/sand down the heatsink block and put new stuff on. I've never had a repaired board fail a second time around. I think adding new compound t on top of old stuff is not a good idea, or at least it won't do anything.
Posted: Mon Feb 23, 2009 10:21 pm    Post subject:
Adding new compound on top of old is worse then none at all. Many people dont know how to use compound. Thinkness is bad. Its proper use is only to fill voids in the 2 surfaces to help in heat transfer. To apply properly you merely add a thin layer to cover the area in contact. When you place the component on the heatsink you move it back and forth to smear the compound until you hear the 2 scraping each other. That is the proper amount.
benareeno
Posted: Mon Feb 23, 2009 10:24 pm    Post subject:
Would the stk chips in an 808 already have heatsinks? I'm wondering if it would be worthwhile, or possible to add some...with thermal compound (if necessary).
Robert A. Hill
Posted: Mon Feb 23, 2009 10:33 pm    Post subject:
Like Mac said, a you should not apply a thick coating of any thermal grease. I have been trying to get a sample of Indium Corp. Heat Spring material to try with the power transistors on my Ampro 3600. This material would have superior thermal properties compared to standard silicon grease with lower thermal resistance being one property than could help in high thermal density areas. See their website for more info:
http://www.indium.com/TIM/solutions/heatspringtim1.php
DrKnow65
TV/Projector: Vidikron Vision One
Posted: Tue Feb 24, 2009 4:22 am    Post subject:
Just be careful that you don't get a conductive thermal paste (Arctic silver for example) it can cause you problems...
I haven't done any thermal stuff on my PJ, but I have done some extensive work on RC car speed controllers and voltage regulators. I use MX-2, it's a 2 part thermal epoxy that is di-electric, but expensive. The grease tends to lose it's bond with any kind of vibration even with a decent retainer.
www.arctic-cooling.com
Posted: Tue Feb 24, 2009 4:26 am    Post subject:
They have massive heat sinks with fan cooling. In all the 808 sets I've seen, only two STK chips have ever failed... and that's a lot of 808's that have been through here.
benareeno
Posted: Tue Feb 24, 2009 5:33 am    Post subject:
Interesting...so what chip or chips are at biggest risk if doing some sort of lowering of the fan voltages?
David_Web
Posted: Tue Feb 24, 2009 10:16 am    Post subject:
It's usually the caps that will go bad with heat.
RIFA has some good info on it's site. Although they are hight quality caps so the once in the PJ might be a lot worse.
Ile
Posted: Tue Feb 24, 2009 10:58 am    Post subject:
I'd leave back end side fans as is because Hsift, deflection and smps modules run pretty hot, maybe 10-20 resistor to middle fan at back. As you can see input and driver cards in the middle run pretty cold.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=13103.html
Convergence board can be made more silent and colder with bigger 120 mm fan (same as in back with 10-20 resistor).
http://www.curtpalme.com/forum/viewtopic.php?p=133856#133856
Posted: Tue Feb 24, 2009 11:13 am    Post subject:
As Curt is the one most likely to have them, I'd like him to perform a experiment. Take two identical projectors, mount one exactly per manufacturers instructions and the second, really F'd up running side by side on the same size screen.
Wanna bet which one runs way hot Laughing
The point is, if you take the time to mount them correctly you won't have to make the time to figure out how to get them to run cooler later. That and a little good house keeping...... Wink
Posted: Tue Feb 24, 2009 3:34 pm    Post subject:
Exactly. You're just trying to fill in any air gaps that may exist when the two metal surfaces are pressed against each other.
What I do is put VERY thin smear of compound on one of the two clean surfaces and then press the two together tightly and move them around a bit. Then I pull them apart. If the compound isn't over the entire surface of the clean surface you didn't use enough compound. Just put a tiny bit more and repeat....
Like quoted above, you're trying to use as little as possible - just enough to fill in any inperfections/cracks.
Posted: Tue Feb 24, 2009 4:48 pm    Post subject:
exactly, you want electrically insualting but Thermally conductive. I think that white stufff they used on our PJ's in the 90's is crap. Dow makes a good pure silicone paste for this purpose, i'ts called Dow Corning Molykote, Dow Corning 5 Dielectric Compound but it's not cheap, 5.3-oz Tube is $20.
