Converting a VGA breakout RGBHV cable to a component cable.
whats6x7
Posted: Wed Mar 26, 2008 7:28 pm    Post subject: Converting a VGA breakout RGBHV cable to a component cable.
Can it be done? The cable already breaks out the R,G and B. Is there any way to add the H and V to one of the 3 color wires and make it component? I know you can buy a VGA to RGB cable.
CRT_Ben
Posted: Wed Mar 26, 2008 7:38 pm    Post subject: Re: Converting a VGA breakout RGBHV cable to a component cab
You don't need a cable, you need a transcoder, like Kim's TC1500 or TC2000. Component video is very different from RGB.
whats6x7
Posted: Wed Mar 26, 2008 8:27 pm    Post subject:
So what is this? This is what my flashlight, I mean projector says I needs to connect a component out from a DVD player to its vga input.
http://cgi.ebay.com/3FT-VGA-HD15-RGB-to-3-RCA-COMPONENT-FOR-TV-HDTV-CABLE_W0QQitemZ120238087082QQihZ002QQcategoryZ41999QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
It says . . .
This cable is used to connect the component video (Y-Pb-Pr or Y-Cb-Cr) output of a DVD player or HDTV receiver to a projector or plasma TV that accepts 15 pin component video input.
Elaine Benes
Posted: Wed Mar 26, 2008 8:29 pm    Post subject:
Your digital likely has Y Cb Cr on the R B G lines of a normal RGB-VGA cable, I had an NEC MT1050 which was like that, the same cable/VGA input could be used for either component or RGB, it was just very convenient.
Posted: Wed Mar 26, 2008 8:55 pm    Post subject:
Exactly.
Some devices can output (or input) component or RGB over a VGA connector. You set within the device whether the VGA connector is doing RGB or component.
This cable is just breaks out the VGA connector to 3 RCA connectors. It does not convert RGB to component or vice versa. You need a $150+ box to do that properly. (Like the RTC2200 or TC1500).
whats6x7
Posted: Wed Mar 26, 2008 9:08 pm    Post subject:
My question still stands though. Does anyone know if the VGA to Component cable use the same pins and pairs as the VGA to RGBHV breakout cable?
Elaine Benes
Posted: Wed Mar 26, 2008 9:23 pm    Post subject:
Yes. Usually. Check the manual for your projector, it should tell you for sure there. Or just try it, it won't hurt anything.
Posted: Thu Mar 27, 2008 1:12 am    Post subject:
Exactly.
This cable is just breaks out the VGA connector to 3 RCA connectors. It does not convert RGB to component or vice versa. You need a $1500+ box to do that properly. (Like the RTC2200 or TC1500).
Yikes! Did Kim have a price increase I didn't know about? Shocked
Posted: Thu Mar 27, 2008 2:39 am    Post subject:
There's no such thing as a "VGA to component" cable.
That is a VGA to RGsB cable.
Your flashlight is doing some very, very non-standard if it uses a HD-15 for a component input.
whats6x7
Posted: Thu Mar 27, 2008 2:46 am    Post subject:
I bought a cheap, chaeap, cheap, cheap, cheap, cheap, cheap assed flashlight. Still, check the bold section below. . . .
VIEWSONIC PJ503 DLP PROJECTOR
RESOLUTION 800X600, 1600X1200 COMPRESSED
LAMP 160W/3000 HOURS RATING 1500 LUMENS 2000:1
263mm (W) x 108mm (H) x 218mm (D) 2.6KG FULL-FEATURED PROJECTOR IS AN IDEAL CHOICE FOR PROFESSIONAL PRESENTATIONS
PI DATE: FEBRUARY 2007
LCD TYPE: 0.55" SVGA (DLP)
RES: 800x600, 1600x1200 compressed
LENS: Digital zoom, manual focus
DISPLAY SIZE: 37 - 150 inch (measured diagonally)
THROW DISTANCE: 1.5 - 6.0m
LAMP: 160W /3000 hour rating
BRIGHTNESS: 1500 Lumens (typ)
CONTRAST RATIO: 2000:1 (typ)
KEYSTONE CORR: Yes
INPUT SIGNAL: Video: RGB analogue, NTSCM, NTSC 4.43, PAL, SECAM,
HDTV (480i, 480p, 576i, 576p, 720p, 1080i)
Sync: H/V separated; Freq: Fh: 15-92KHz; Fv: 56-120Hz
COMPATIBILITY: PC: from VGA to UXGA (scaled)
Mac: up to SXGA (may require Mac Adapter)
CONNECTOR: RGB Input: 15-pin HD D-sub cable (x1)
Composite Video: RCA jack (x1)
S-Video: Mini-DIN 4 pin (x1)
Component Video: VGA DB-15 to component adpater Control: RS-232 (8 Pin D-sub) x1, USB: x1
POWER: Voltage: 100-240VAC; 50/60Hz (universal)
POWER CONSUMPTION: 250W (typ)
DIMENSIONS: 263mm (W) x 108mm (H) x 218mm (D) WEIGHT: 2.6 kgs
REGULATIONS: CSA, TUV-GS, CB, FCC-B, CE, C-Tick
Posted: Thu Mar 27, 2008 3:06 am    Post subject:
Exactly.
Oops - that was supposed to be $150+. Smile Fixed!
dculberson
Posted: Thu Mar 27, 2008 2:54 pm    Post subject:
Most of the projectors with component over DB15HD use the same pinout as the R-G-B pins on the VGA->RGBHV cables. You don't need to do anything with the H or V leads. Just adapts the R, G, and B to RCA (or whatever your component source uses) and connect thusly:
Red: Pr
Green: Y
Blue: Pb
I made a cable by hand for my Epson "flashlight" and it worked great.
I'm a stuffaholic.
