Dwin LD-2
philm
Posted: Mon Mar 24, 2008 4:31 pm    Post subject: Dwin LD-2
I have this line doubler I want to try with an XG110, but it's only got four bnc connections and the NEC has five. I just want to try it with cable tv to start. It has no remote but powers on. I don't know much about Dwin except they are hard to contact.
Anyone use a Dwin with XG or PG?
Philip
Posted: Mon Mar 24, 2008 4:41 pm    Post subject:
That will work fine, just connect the 'S' output to the 'H' input of the NEC. Program in a new memory location and you're good to go. Down the road you can do a lot better than the LD2, but it's fine to get started with.
philm
Posted: Mon Mar 24, 2008 4:48 pm    Post subject: Dwin LD-2
Thanks again Curt.
Philip
Posted: Mon Mar 24, 2008 5:39 pm    Post subject:
Yes, you'll want to use at least line tripling (720p) for an XG.
Or just connect a Blu-ray or HD DVD player directly - no line doubler/scaler needed as the players will do it all for you (this is what I do).
philm
Posted: Mon Mar 24, 2008 6:04 pm    Post subject: Dwin LD-2
Thanks Kal,
I have not made the plunge to Hd dvd/bluray yet, the XG does not have good tubes and the Dwin is all I have to try on this particular projector which will likely be parted out in the not too distant future.
Philip
