How to adjust tube focus
timf
Posted: Fri Mar 21, 2008 6:22 am    Post subject: How to adjust tube focus
the green tube of my BD808s pj seems to me to be quite soft and not as shap as the red rube when displaying a crosshatch pattern
Reading Curts Barco guide indicates i can adjust this using the tube focus yoke.
As I dont want to make it worse I thought I'ld best ask the question on how to do this.
To make the lines sharper do I slide the yoke front to back or is it meant to rotate around the tube neck?
Jesse S
Posted: Fri Mar 21, 2008 8:30 am    Post subject:
Did you already get the optical focus as good as possible? After that, adjust the electronic focus from the barco menus. Maybe after that you can adjust the actual yokes.
Ile
Posted: Fri Mar 21, 2008 10:35 am    Post subject:
Full tube alignment procedure is in last two pages.
http://www.curtpalme.com/docs/BarcoGraphics808s_CRTReplacementProcedure.pdf
