How to hook up the Moome EXT
htmike
Posted: Tue Mar 18, 2008 7:29 pm    Post subject: How to hook up the Moome EXT
I just received my Moome EXT box, though i did not realize the output is RGBHV not VGA. I imagine not a problem. My connection is a 35' RGBHV to VGA from my Lumagen to my Marquee 8110.
Now how do i hook this up? Can I buy a 3' RGBHV with VGA end to connect to a genner changer, then connect it to my current VGA to Projector?
Will this work or do i need to purchase a new RGBHV to RGBHV cable. Confused
scottatl
Posted: Tue Mar 18, 2008 8:00 pm    Post subject:
this should work
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10203&cs_id=1020304&p_id=563&seq=1&format=2
Phil Smith
Posted: Tue Mar 18, 2008 11:48 pm    Post subject:
Mike,
If you or someone you know can cut the VGA plug off and replace it with BNC connectors, I think that would be the best way to go. Otherwise, the adapter Scott linked to should be fine.
htmike
Posted: Wed Mar 19, 2008 2:02 pm    Post subject:
Thanks for all the replies, i will order the cable today and start my road to blue ray
