paw
| Posted: Sat Mar 15, 2008 3:10 am Post subject: Resolution to use for PJ setup? |
OK! I think I remember reading that when you set of a PJ (NEC in particular) that you should use the highest resolution that you will ever use. If you used a lower resolution, you might run out of calibration range (horiztial raster/image) if you tried to setup a higher resolution in the future.
Correct?
I've got a NEC 9PG Xtra. The highest resolution I'm planning is 960p from a Momsitu. It's my understanding the Xtra can't fully resolve 1080p.
_________________ Aubrey
| Posted: Sun Mar 16, 2008 12:48 pm Post subject: |
Set it at your most common res IMO.
Gino
| Posted: Tue Mar 18, 2008 1:14 am Post subject: |
I agree with Mark, you want whatever you are using to look its best
