Scam or not?
David_Web
Posted: Wed Mar 12, 2008 6:49 pm    Post subject: Scam or not?
http://www.minhembio.com/thedaytrader/marknad/175288
He says that the tube pics is from the 9500LC.
I think it looks like a 808 or 1209 or 909 or similar. A Barco at least.
And it also looks like the wide shot is from a different proj than the tube shots.
Any one knows the original pics that I assume it stolen?
Posted: Wed Mar 12, 2008 6:56 pm    Post subject:
total scam, I thnik the first 2 machines are Antorsae in Spain with his 9500LC's?
Posted: Wed Mar 12, 2008 6:58 pm    Post subject:
the first pics are of two striped marquee's for sure the second of the tubes are not marquee's and then its a barco on the cieling.
Scam ? i think so or he was too lazy to take his own pics.
Bruce 09
Posted: Wed Mar 12, 2008 7:01 pm    Post subject:
Did you translate the page ? I haven't but it looks like he correctly lists the first pic as 2 9500's and the other pic is correctly a cine 9/909 He screws up one pic of the tubes but what makes you think it is scam ?
Dragan have you seen antorsae's 9500's or do you recognize the actual pics ? or are you guessing ?
http://www.minhembio.com/thedaytrader/175288/miniatyrer
You guys can for sure absolutely say this is a scam ? Dragan can you tell me what he is sayng in these pics? Is he saying on the pic of the 909 that it is better than a 9500 Smile
How much is he asking ?
Bruce
Moose
Posted: Wed Mar 12, 2008 7:02 pm    Post subject:
I have no idea if this is a scam or not, seeing as I don't understand the language, but the top pic certainly looks like a 9500LC, the second I can't tell and the others appear to be from a Barco Cine 9. The question is - why are photos from two different projectors combined if he is only selling the Barco? Or is he? I'd say this isn't a scam but the seller is somewhat goofed up.
David_Web
Posted: Wed Mar 12, 2008 7:12 pm    Post subject:
Well I asked for pictures of the tubes as it was obvious that it was not the right tubes. He replied and asked if I had not seen the pics of the tubes in the ad. That makes the impression that the images is in fact falsely put up as a 9500LC
The Cine 9 is apparently put up in the same room but not used and is available to compare to or something like that.
*edit* 2300$ or highest bid (a peace) but he said that there has been some interest so it's higher than that now.
*edit2*
Translation:
First pic:
"Two fresh Electrohome 9500LC to view"
Second:
"9500LC with nearly no wear on the tubes"
third:
"BARCO CINE 9 (not mine) that stands just beside Electrohome 9500LC"
And as a reply to my PM:
"It seems you have not seen the pictures in the ad of just the tubes?"
