mcm4u
| Posted: Tue Mar 11, 2008 11:38 pm Post subject: Please help- component imput & Extron DVS-150 |
Hello,
I have a Extron DVS-150 conected to a NEC 9PG projector.
The issue: the component imput is Y, B-Y, R-Y and will not work with component output from DVD player.
Looks like this imput is for Sony Betacam format.
What I have to do to connect the YPbPr output from the the DVD player at the Y, B-Y, R-Y imput from scaler?
A new firmware can solve the problem?
Any other solutions?
Thanks f.
_________________ mcm4u
louthewiz
| Posted: Wed Mar 12, 2008 10:08 pm Post subject: |
I used to have an extron scaler (204) and the input must be set as "YUV" and the output to whatever you want, But the input must be at 480i and not 480p otherwise it won't work.
Using advanced digital video scaling technologies, Extron's DVS 150 converts NTSC/PAL/SECAM video signals into high-resolution video for viewing on digital displays such as LCD, DLP, and plasma monitors and projectors. To optimize image quality on digital displays as well as maintain maximum image brightness and detail, lower-resolution NTSC/PAL/SECAM video signals should be scaled up to match the "sweet spot" or native resolution of digital displays. The DVS 150 accepts composite video, S-video, or component video and offers a wide variety of RGB resolution output rates to match different computer-video, progressive HDTV, and plasma resolutions. The DVS 150 combines video scaling with the ability to switch a computer video input on a 15-pin HD.
The rack-mountable DVS 150 features Extron's exclusive variable top and bottom vertical blanking. During scaling, captioning, and tapehead switching in the video's blanking area show up as picture noise. Using variable blanking, a user may add black lines at the top and bottom of the screen to eliminate edge noise.
Scaled RGB outputs are available simultaneously on a 15-pin HD connector and six BNCs. The DVS 150 offers scalable outputs at these computer-video rates: 640 x 480, 800 x 600, 832 x 624, 1024 x 768, and 1280 x 1024. Progressive HDTV output rates of 480p, 720p, and 1080p/60 are available. To match the resolutions and timings of plasma displays the DVS 150 provides these plasma output rates: 848 x 480, 852 x 480, 1280 x 768, and 1360 x 765.
An RGB input is provided as a pass-through to simplify system design.
http://www.extron.com/product/product.aspx?id=dvs150
