Malakay
| Posted: Fri Mar 07, 2008 1:19 pm Post subject: Vertikal centering problem ECP 4100 |
i did a complete mechanical setup with my 4100 and all worked fine. I only got this problem:
As you can see, the red color is not in top of the green, as the guided install routine says it should be.
Is there any chance to change the vertical position of the tube without using the convergence menu? I cant find any information in my manual. But everyone say that i wil get many drift when adjusting it over convergence
thx
regards
Chris
