input panel for conf room
Joust
TV/Projector: Marquee 8501LC
Posted: Wed Mar 05, 2008 6:29 pm    Post subject: input panel for conf room
I have an architect friend designing an office. They want a setup to connect laptops etc to a TV/PJ in a conference room.
Is there standard panels for this sort of thing?
not sure if they are using Projector or LCD TV but I was thinking it would be slickest to have a hidden panel in a conference table that has the AV connections, power and LAN all there for the sources to plug in.
Posted: Wed Mar 05, 2008 6:35 pm    Post subject:
Depending on what they need, you can get premade ones. We usually custom made ours up at a local supplier. Check this out:
http://cgi.ebay.com/Extron-RGB-500-Series-5-Wall-Mounted-Video-Interface_W0QQitemZ110228537962QQihZ001QQcategoryZ21169QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That's typical of what's available. Check the Extron site for more options. Super pricy when new, but as you can see, for NOS, they are dirt cheap.
Chuck27
Posted: Wed Mar 05, 2008 9:02 pm    Post subject:
I've been to visit customers....granted, they tend to be megabucks big companies.....amd their laptops AND projectors are all on wireless.
It's pretty slick.
Chuck
using acreage for sound insulation since 1999
Posted: Wed Mar 05, 2008 10:13 pm    Post subject:
Chuck,
I think I've seen that before. Is it software that enables the projector to be a shared display over the network and they all connect through the wireless network into the projector.
I'm pretty sure they use something similar at the school where my Mom teaches
JustGreg
Posted: Wed Mar 05, 2008 10:33 pm    Post subject:
If I remember correctly (there's a first for everything I suppose) Clarence undertook the same task a year or so ago where he works or he had in the past and was helping somebody with the same question. I wonder if he went the wireless route??
Greg
Posted: Thu Mar 06, 2008 3:59 am    Post subject:
I was just going to mention that Greg. Good memory Thumbs Up
He was looking for a conference table wasn't he?
Edit: here's that thread:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=3171.html
Wow I searched as fast as....um....Clarence!
PS I narowed that down to one hit....I am SO awesum tonight!
Chuck27
Posted: Fri Mar 07, 2008 12:41 pm    Post subject:
Zebu Fellenz wrote:
Chuck,
I think it's some sort of a wireless router that work more or less in reverse....it has several nodes that can each be accessed by someone on the network, and the projector, in essence, can be switched between them depending on who's laptop is being used for the presentation.
It seems like the way one would select a printer across a network, except in this case it's video.
As you can probably tell, I'm not a computer guy in RL.......Shocked
Chuck
