raytoms
Joined: 06 Sep 2006 Posts: 27 Location: Coopers Gully, Australia
TV/Projector: JVC 950 D-ILA projector
| Posted: Mon Mar 03, 2008 9:58 pm Post subject: Barco Projector control software |
I am having problems using the Barco projector control software.
I have checked several sources and the only version of the software seems to be 1.0.
When I start it up, I get Error 3, followed by Error 45, then it scans but does not find any projectors.
I am connecting to my Barco 708.
I have tried two different laptop/OS combinations under Windows 98 and Vista, with different cables.
ANY IDEAS? 1.
The reason I am doing this is that I am having problems with my IR remote control:
- over a couple of weeks it became less effective until it would not work at all
- change batteries and tried another remote - no go
- tried to use the built-in controller, but it had stopped working too - unless I put a jack into the Remote socket on the PJ
- tried connecting with a cable - no go (the lights lit up on the remote, but the keys did not work)
(tried both mono and stereo cables - no difference - the manual shows a mono cable)
ANY IDEAS? 2.
_________________ JVC 950 projector, PS3-3D, Roland TD20 drums, Sony HD camcorders and Steadicam, living on 13 rural acres in south-east Australia.
jask
| Posted: Wed Mar 05, 2008 5:53 pm Post subject: |
bad IR board? Curt probably has a box full of them.
comm
| Posted: Wed Mar 05, 2008 6:01 pm Post subject: |
My 801s had a similar problem when I first got it. Taking out the convergence board and reseating it a few times fixed the issue. Might be worth a try. As far as the software I am not sure, It worked fine for me on XP. Did it give you the same errors on both 98 and Vista?
raytoms
| Posted: Thu Mar 06, 2008 11:17 am Post subject: |
OK, thanks for the tip. I will try re-seating the convergence board.
As to the Barco software, problem now solved.
I am running on a Vista machine, which did not work, so I tried a Win98 machine which was OK.
I then tried running in Backward Compatibility mode (right click the app, go to properties, compatibility, and choose the OS). That still didn't work. I could see the PJ but it thought it was in standby.
I then ticked Run as Adminstrator and all was fine - Yeh!!
