Gamby
| Posted: Mon Mar 03, 2008 3:40 pm Post subject: compatibility between 07MP and 07MSP ? One more question... |
Hello,
does anyone know if it's possible to replace a 07MP CRT with a 07MSP basicaly ?
and more precisely will it be possible for a sony 1271 to run properly with 2 07MP (G and R) and 1 07MSP (B) alltogether ? or will cause troubles as impossible G2 proper setup etc...
thanks to anyone that have some informations
JP
| Posted: Mon Mar 03, 2008 3:53 pm Post subject: |
Yes, you can do that no problem. The focus voltage is slightly different, but that will be adjusted by the focus controls.
| Posted: Mon Mar 03, 2008 4:00 pm Post subject: |
I've done the opposite - put 07mp's into a newer 1252 (originally 07msp's) and it worked perfectly. I had a focus issue, but it was only on one tube, so I assume it was just the tube (they were used). Other than that, it worked perfectly.
Gamby
| Posted: Mon Mar 03, 2008 4:04 pm Post subject: |
Thanks to you both...
Gamby
| Posted: Mon Mar 03, 2008 6:06 pm Post subject: |
Those 07MSP have been dedicated to Sony as well as Barco, so as other tubes I guess they were mounted with specific HT lead for Barco or Sony...
how can I recognise a Sony from a Barco HT lead..?
Gamby
| Posted: Mon Mar 03, 2008 6:15 pm Post subject: |
Don't waist time replying, I found some pictures....
