BD 801S Negative sync work around
BigDLondon
Posted: Sun Mar 02, 2008 2:24 am    Post subject: BD 801S Negative sync work around
Hi everybody
I've tried using a roger's hd cable box into my Iscan HD box with the roger's set at 720p and the Iscan passes the signal through. But my BD 801s won't show anything because it needs negative sync and I believe the roger's hd box is putting out positive sync. Is there a way around this like a new board or device? Thanks BigD P.S. the roger's box worked at 480p.
Posted: Sun Mar 02, 2008 2:33 am    Post subject:
I'd suggest the RTC2200. I used with my BG800 for the same reason (well one of the reasons) as it allows you to force negative sync. The main reason was for great component to RGB transcoding and gamma adjustment.
scotha
Posted: Sun Mar 02, 2008 3:23 am    Post subject:
I use an extron sc210 sync combiner off ebay for 20.00 to run my bd801s.
pj. BD808s, BD801s
BigDLondon
Posted: Sun Mar 02, 2008 1:49 pm    Post subject:
Thanks for the GREAT replys and now I know there is help for my Barco projector.Thanks BigD
wireburn
Posted: Wed Mar 05, 2008 2:33 pm    Post subject:
Use port 3 which accepts the pos. sync.
-Mike
Posted: Wed Mar 05, 2008 4:45 pm    Post subject:
-Mike
Good point. The 801s accepts positive on port 3. More info: http://www.curtpalme.com/Barco_Port3_Input.shtm
BigDLondon
Posted: Wed Mar 05, 2008 10:17 pm    Post subject:
Ok thanks guys.Please can someone help me find a cable to run from my Iscan Hd to port 3?Thanks again.BigD
wireburn
Posted: Fri Mar 07, 2008 5:56 pm    Post subject:
Just lop one end off a VGA cable and solder on a DB9 connector.
-Mike
BigDLondon
Posted: Fri Mar 07, 2008 11:11 pm    Post subject:
Thanks Mike.I'll give that a try.BigD AKA Darryl
BigDLondon
Posted: Sat Mar 08, 2008 4:01 pm    Post subject:
Hi
I've bought a Startech mxt915hmm vga to db9 cable for my Iscan HD and I've used my trusty Radio-Shack multimeter and traced which wires we're which and soldered them the way that Kal pointed me to and it works with my IScan in positive sync.Now to find a 720p device to try it.Thanks Darryl
BigDLondon
Posted: Tue Mar 11, 2008 10:43 pm    Post subject:
Thanks to everyone especially Kal and Mike for your wonderful help.Darryl in London,Ontario, Canada
I Love My Barco BD801s and not just because my wife tells me I do.
BigDLondon
Posted: Fri Mar 14, 2008 11:53 pm    Post subject:
Well I tried a Sony BDP-S1 Blue Ray player into my Iscan Hd at 720p and 1080i and all I got was a green picture. When I go through the formats and hit 480i or P the picture is in full colour. My Iscan HD is putting out 1080i so why a green picture at 720p or 1080i? Any body else using the VGA to DB9 into port 3? Thanks Darryl P.S. I found this While all "s" model projectors (except the 801s) will accept a component signal via port 4/5, the same is not true for port 3. Please explain.
Posted: Sat Mar 15, 2008 2:48 pm    Post subject:
You started a separate thread about this... so I answered there.
