killed my G90, need some help
Hammer
Posted: Tue Feb 26, 2008 7:05 am    Post subject: killed my G90, need some help
Hi All,
I recently purchased a G90.
In order to fit it to my test application, (and get the wifes approval for the final positioning) I have spent a day or so (practicing, experimenting, and learning the CRT manuals’ lingo) setting the focus, scheimpflug, mg and registration.
It was great fun, and my wife thinks the DLP looks just fine BTW; all colors match up well in the test patterns, and the menus look great.
Along the way, however, I think I cleared something important.
Now, it won't project any real video source, just the menus and test patterns.
I can tell that it senses the inputs, as certain options not available unless specific inputs are live, are available, and if I shut off an input, it will display ‘no input’.
All video memory’s seem to have been cleared.
I have learned a lot, but am still trying to understand service data, factory data, video memory and input memory. I am also unsure where the switcher/video memory/index switch should be on the remote.
My current source is component from a PS3, and will be HDMI as soon as my Moome IFB-HD arrives.
Can anyone see what I overlooked, or broke?
Thank you very much for your help.
Dan
Brooklyn
Posted: Tue Feb 26, 2008 7:11 am    Post subject:
Some sort of picture mute option?
Hammer
Posted: Tue Feb 26, 2008 7:31 am    Post subject:
Thanks Brooklyn,
I have checked for PIC muting, I wish that was it.
I am hoping to find something simple like that!
Hammer
oliverg
Posted: Tue Feb 26, 2008 11:24 am    Post subject:
You wont be able to display 1080p over component (if that's what you're aiming for)
Have you tried using composite?
Posted: Tue Feb 26, 2008 4:20 pm    Post subject:
Dan,
Did you change any of the settings on the input signal settings page? Comp/RGB? Clamp, synch, etc.? Tell us what all those settings are.
So, where'd your G90 come from?
Welcome to the forum!
Hammer
Posted: Tue Feb 26, 2008 4:48 pm    Post subject:
1
1080p is the goal, but that will have to wait for the moome card and the HDMI cable.
Before I reset all of the settings, it did display through the component inputs.
I could not tell the quality since it was previously set up for a different screen size.
Currently composite does not project either, even though the unit ‘senses’ there is composite input.
2
Thanks for the welcome,
I did not intentionally ‘change’ the settings, but I believe I may have cleared them.
I will see post what those settings are when I get home tonight, CA time.
You can be more specific on the setting you would like to see so I make sure I get them all.
The unit came out of a private home theater in the Boston area.
hammer
Fujifrontier
Posted: Wed Feb 27, 2008 3:20 am    Post subject:
not fair
Hammer
Posted: Wed Feb 27, 2008 5:54 am    Post subject:
SC,
With either input 'A', component, or composite video, the following are of the some settings:
Input settings:
COLOR TEMP 6500 (green text selectable)
CLAMP (white text not available)
V SHIFT (white text not available)
SYNC SEL (white text not available)
SYNC ROUTE (white text not available)
VIDEO LOCK (white text not available)
Set Setting1
STATUS ON (green text selectable)PIC MUTINF OFF
INPUT-A COMPONENT (green text selectable)
INPUT-B (white text not available)
INPUT-C (white text not available)
USER MODE: PRO (green text selectable)
Input Info:
fH: 31.47 kHz (green text)
fV: 60.00 Hz (green text)
H/C:- V:- SonG:- (green text)
INPUT SIGNAL: DRC NTSC3. 58 (green text)
INPUT MEMORY No. 11
>No. 11 (green text)
VIDEO MEMORY: 4 (green text)
PICTURE SETTINGS1
D. PICTURE: OFF (green text selectable)
COLOR SYS: AUTO (green text selectable)
SET UP:O (green text selectable)
COMPONENT FORMAT:(white text not available)
PICTURE SETTINGS 2
With Composite input
COMB FILTER: 3D (green text selectable)
DRC:ON (green text selectable)
DRC LEVEL: (white text not available)
With Component input
COMB FILTER: 3D (white text not available)
PICTURE CRTL
VIDEO MEMORY > No. 4
Is this enough to see what I screwed up?
Hammer
Posted: Wed Feb 27, 2008 6:12 am    Post subject:
Hammer wrote:
1
2
hammer
Ahhh the Boston area. Are you still in the Boston area? There's only a few crt guys around here.
Hammer
Posted: Wed Feb 27, 2008 6:36 am    Post subject:
Nope,
I am in the SF bay area, San Mateo.
Hammer
Posted: Wed Feb 27, 2008 7:50 am    Post subject:
Dan,
First, try setting Input 1 to 'HDTV YPRPB'.
I think the 'component' setting is for 480i/p with standard sync, as opposed to the tri-level synch in HD.
Also, I think memory slot 11 and 31.47khz is the built in oscillator - which runs around 480p. Was the PS3 switched on?
I assume you've tried another source besides the PS3 to rule it out as a potential issue.
Posted: Wed Feb 27, 2008 3:24 pm    Post subject:
Worst case, it sounds like an issue with the RGB input board or the CPU board. I do have a test chassis here that I can test/repair those boards in.
I'll REALLY try and put some tech tips for the G90 on the site within the week...
